Micro SD issues [Official disccusion]
Discussion in 'Troubleshooting' started by andcmp, Oct 31, 2013.
  1. andcmp
    andcmp New Member
    161
    Hi all!
    This topic gathers users with UDOOs that won't boot because of bad flashed micro SD cards, typically corrupted memory cards or when the image file isn't properly flashed (e.g. was written in a partition).
    If your UDOO won't boot, first follow our troubleshooting procedure: Why my UDOO won't boot? http://www.udoo.org/faq-items/why-my-udoo-wont-boot/ and then post the results here before asking for support so we can better understand what's going on with your UDOO and help you out.
    Here you can find a step by step guide about how to create a bootable micro SD card: http://www.udoo.org/getting-started/cre ... rom-image/
    Video tutorial "Creating a bootable Micro SD card with Linux Ubuntu from image": http://www.udoo.org/ProjectsAndTutorial ... lioID=1394
    Video tutorial "Creating a bootable Micro SD card using Windows from image": http://www.udoo.org/ProjectsAndTutorial ... lioID=1394
    Video tutorial "Creating a bootable Micro SD card with Mac OS X from image": http://www.udoo.org/ProjectsAndTutorial ... lioID=1394
  2. freedomotic
    freedomotic Member
    Oct 19, 2013
    77
    Hi all,
    I posted this in another topic some days ago (I hope you don't consider it cross-posting)
    I can't boot with Linaro Dual version.
    After downloaded it:
    on Windows XP and 8
    - winrar warning message (corrupted file) but extraction OK
    - winzip no extraction corrupted file
    - 7zip extraction OK no error message
    on Linux
    - unzip OK and also dd writing
    But in every case my udoo doesn't boot. I tried with different sd cards (Transcend, Kingston). Also no boot with Android. The power seems ok, led green on. In debug mode (connecting microusb to CN6 port) black screen on Teraterm (Windows). On Linux after powered the board
    [ 3211.260065] usb 3-1: new full speed USB device number 4 using uhci_hcd
    [ 3211.439429] cp210x 3-1:1.0: cp210x converter detected
    [ 3211.552074] usb 3-1: reset full speed USB device number 4 using uhci_hcd
    [ 3211.699657] usb 3-1: cp210x converter now attached to ttyUSB0
    [ 3212.096712] usb 3-1: usbfs: interface 0 claimed by cp210x while 'brltty' sets config #1
    [ 3212.101831] cp210x ttyUSB0: cp210x converter now disconnected from ttyUSB0
    [ 3212.101863] cp210x 3-1:1.0: device disconnected
    On Windows using Putty I saw once some data in the terminal log but I can copy only the last part. Then always black screen.
    The putty log is
    [ 0.000000] .bss : 0x80b63b24 - 0x80bb2480 ( 315 kB)
    [ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [ 0.000000] Preemptible hierarchical RCU implementation.
    [ 0.000000] NR_IRQS:624
    [ 0.000000] MXC GPIO hardware
    [ 0.000000] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
    [ 0.000000] Set periph_clk's parent to pll2_pfd_400M!
    [ 0.000000] arm_max_freq=1GHz
    [ 0.000000] MXC_Early serial console at MMIO 0x21e8000 (options '115200')
    [ 0.000000] bootconsole [ttymxc1] enabled
    [ 0.000000] Console: colour dummy device 80x30
    [ 0.228382] Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
    [ 0.316708] pid_max: default: 32768 minimum: 301
    [ 0.321573] Mount-cache hash table entries: 512
    [ 0.326773] CPU: Testing write buffer coherency: ok
    [ 0.331727] Unable to handle kernel paging request at virtual address 016c5b88
    [ 0.338973] pgd = 80004000
    [ 0.341689] [016c5b88] *pgd=00000000
    [ 0.345292] Internal error: Oops: 5 [#1] PREEMPT SMP
    [ 0.350271] Modules linked in:
    [ 0.353349] CPU: 0 Not tainted (3.0.35 #1)
    [ 0.357824] PC is at __rmqueue+0xe4/0x3bc
    [ 0.361855] LR is at get_page_from_freelist+0x498/0x538
    [ 0.367098] pc : [<800bf74c>] lr : [<800c1e9c>] psr: 800001d3
    [ 0.367103] sp : 80b05d68 ip : 016c5bb4 fp : 00000000
    [ 0.378618] r10: 80b62d80 r9 : 00000000 r8 : ffffff80
    [ 0.383858] r7 : 00000001 r6 : 8bc80900 r5 : 80b62e34 r4 : 8bc80918
    [ 0.390403] r3 : 00000002 r2 : 016c5bb4 r1 : 00000003 r0 : 00000004
    [ 0.396950] Flags: Nzcv IRQs off FIQs off Mode SVC_32 ISA ARM Segment kernel
    [ 0.404454] Control: 10c53c7d Table: 1000404a DAC: 00000015
    [ 0.410216] Process swapper (pid: 0, stack limit = 0x80b042f0)
    [ 0.416066] Stack: (0x80b05d68 to 0x80b06000)
    [ 0.420439] 5d60: 8bc80918 80b62ddc 00000001 00000002 80b62d80 00000000
    [ 0.428643] 5d80: 80b19b30 00000001 80b04000 00000000 00000001 800c1e9c 00000041 00000041
    [ 0.436846] 5da0: 80b62d80 40000153 00000001 800c1e54 00000008 00025200 00020000 00100100
    [ 0.445049] 5dc0: 4f72c235 00000000 80b63864 80b62da4 00000000 00000000 80b05f33 80b05e2c
    [ 0.453253] 5de0: 00000000 80a45cf2 00000001 fffffffe 00000000 80b62d80 00000008 000000d0
    [ 0.461456] 5e00: 80b63860 00000000 80b19b30 00000001 80b63864 00000000 00000001 800c2224
    [ 0.469659] 5e20: 00000001 00000041 80b62d80 00000000 00000000 8be0c210 00000000 00020000
    [ 0.477862] 5e40: 60000153 8003a210 80b19c88 800ee3b4 00000003 00000000 80070320 00000704
    [ 0.486066] 5e60: 00004027 a4003280 000000d0 00000000 80b1be90 80b19c88 80b05e88 00000000
    [ 0.494269] 5e80: 80070320 800ee7e8 00000000 80b62d80 00000041 a4044000 00800b00 80b64dc0
    [ 0.502474] 5ea0: 80b1be90 00000000 80b05f60 00000000 00000000 8007033c 00000d83 80072450
    [ 0.510676] 5ec0: 80b63864 80b65240 80b65300 00000000 80b65300 80b65303 80b2a37c 00000003
    [ 0.518880] 5ee0: 80b2a37c 00800b00 00000000 80b05f60 00000000 1000406a 412fc09a 00000000
    [ 0.527082] 5f00: 00000000 80071088 00000000 00000000 00000000 80b65240 00000000 3b9aca00
    [ 0.535285] 5f20: 10624dd3 60000153 a4006240 b0802000 00000000 00000308 00205d33 a400c7a0
    [ 0.543489] 5f40: a400c7a0 800082d4 00000000 80b05f60 00000a00 8003f2a4 00000000 00000000
    [ 0.551692] 5f60: 00000000 00000000 00000000 00000000 00000000 800082d4 8003f080 00000013
    [ 0.559894] 5f80: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 8003f070
    [ 0.568097] 5fa0: 00000093 00000000 1000406a 80b04000 80b63b40 8002d2dc 00000000 805596b4
    [ 0.576300] 5fc0: 80b19b50 80b63b40 8002d2dc 800088a4 80008418 00000000 00000000 8002d2dc
    [ 0.584503] 5fe0: 00000000 10c53c7d 80b19a60 8002d2d8 80b1cf4c 1000803c 00000000 00000000
    [ 0.592714] [<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (_]rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x1bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bc) from [<800bf74c>] (__rmqueue+0xe4/0x3bc[<800bf74c>] (__rmqueue+0xe4/0x3bcpS) from [<800bf74c>] (__rmqueue+0xe4/0x3bcpS[<800bf74c>] (__rmqueue+0xe4/0x3bcpS) from [<800bf74c>] (__rmqueue+0xe4/0x3bcpS[<800bf74c>] (__rmqueue+0xe4/0x3bcpS) from [<800bf74c>] (__rmqueue+0xe4/0x3bcpS[<800bf74c>] (__rmqueue+0xe4/0x3bcpS) from [<800bf74c>] (__rmqueue+0xe4/0x3bcpS[<800bf74c>] (__rmqueue+0xe4/0x3bcpS) from [<800bf74c>] (__rmqueue+0xe4/0x3bcpS[<800bf74c>] (__rmqueue+0xe4/0x3bcpS) from [<800bf74c>] (__rmqueue+0xe4/0x3bcpS[<800bf74c>] (__rmqueue+0xe4/0x3bcpS) from [<800bf74c>] (__rmqueue+0xe4/0x3bcpS[<800bf74c>] (__rmqueue+0xe4/0x3bcpS) from [<800bf74c>] (__rmqueue+0xe4/0x3bcpS[<800bf74c>] (mapping_tagged+0xe4/0x3bcpS) from [<800bf74c>] (mapping_tagged+0xe4/0x3bcpS[<800bf74c>] (mapping_tagged+0xe4/0x3bcpS) from [<800bf74c>] (mapping_tagged+0xe4/0x3bcpS[<800bf74c>] (mapping_tagged+0xe4/0x3bcpS) from [<800bf74c>] (mapping_tagged+0xe4/0x3bcpS[<800bf74c>] (mapping_tagged+0xe4/0x3bcpS) from [<800bf74c>] (mapping_tagged+0xe4/0x3bcpS[<800bf74c>] (mapping_tagged+0xe4/0x3bcpS) from [<800bf74c>] (mapping_tagged+0xe4/0x3bcpS[<800bf74c>] (mapping_tagged+0xe4/0x3bcpS) from [<800bf74c>] (mapping_tagged+0xe4/0x3bcpS[<800bf74c>] (mapping_tagged+0xe4/0x3bcpS) from [<800bf74c>] (mapping_tagged+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpSY<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizgendQvmtp_atetfQ)0xe4/0x1bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsixeendQvmtr_atetfQ+0xe4/0z3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS[<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpS) from [<800bf74c>] (urQtr_atecpypsizeendQvmtr_atetfQ+0xe4/0x3bcpSY<800bf74c>] (lock_vma_p_nesnangeynQmunlock_vma_page_fiQmunlock_vtep_pagesnange_htmlock_fixupendtdo_mlockall_deTsys_munlockallendTsys_mlockall_htdo_mlockivTsys_munlock_hTsys_mlockyn+0xe4/0x3bcpS) from [<800bf74c>] (lock_vma_p_nesnangeynQmunlock_vma_page_fiQmunlock_vtep_pagesnange_htmlock_fixupendtdo_mlockall_deTsys_munlockallendTsys_mlockall_htdo_mlockivTsys_munlock_hTsys_mlockyn+0xe4/0x3bcpS)
    Thanks for support
  3. Mozer
    Mozer New Member
    Jun 19, 2013
    42
    Just for info for anybody who had the same problem as me today: I had an issue when I formatted one of the SD cards I got with my UDOO, for some weird reason after the formatting only 12.6MB was available (quick or full formatting made no difference). I think this is an issue with Windows, but in case anybody else had the same problem: I've fixed this by formatting the SD card with a program called SDFormatter, if you have the same problem you should try this! :)
  4. dkonhauser
    dkonhauser New Member
    Oct 28, 2013
    11
    My UDOO Quad won't boot. I initially tried both the Android Quad and Linux Quad cards (AND the reset button).
    I followed the troubleshooting procedure using serial debug, downloaded Android Quad and created a new SD card image.
    Still wouldn't boot.
    I tested the SD card media by making a Raspberry Pi image on it- which worked fine on the Pi. Figured the media itself was OK
    I tried a new 12Vdc supply - still nothing on HDMI or serial debug.
    Am running out of ideas...
  5. powerage
    powerage New Member
    Nov 1, 2013
    I have trouble booting the Linaro Ubunto image. I have tried the Android image without any problems, using the same SD card.
    The Micro SD card used is a Kingston MicroSDHC, type SDC10/8GB. I have transferred the image to the SD card on a windows 7 platform, 64 bit, via the Win32DiskImager software.
    The log from the serial debug connection is shown below:
    U-Boot 2009.08-svn82 (Oct 07 2013 - 13:43:50)
    CPU: Freescale i.MX6 family TO1.2 at 792 MHz
    Thermal sensor with ratio = 180
    Temperature: 46 C, calibration data 0x57250069
    mx6q pll1: 792MHz
    mx6q pll2: 528MHz
    mx6q pll3: 480MHz
    mx6q pll8: 50MHz
    ipg clock : 66000000Hz
    ipg per clock : 66000000Hz
    uart clock : 80000000Hz
    cspi clock : 60000000Hz
    ahb clock : 132000000Hz
    axi clock : 264000000Hz
    emi_slow clock: 132000000Hz
    ddr clock : 528000000Hz
    usdhc1 clock : 198000000Hz
    usdhc2 clock : 198000000Hz
    usdhc3 clock : 198000000Hz
    usdhc4 clock : 198000000Hz
    nfc clock : 24000000Hz
    Board: i.MX6Q-UDOO: unknown-board Board: 0x63012 [POR]
    Boot Device: NOR
    I2C: ready
    DRAM: 1 GB
    MMC: FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3
    In: serial
    Out: serial
    Err: serial
    Net: got MAC address from IIM: 00:c0:08:88:17:02
    FEC0 [PRIME]
    Hit any key to stop autoboot: 3  2  1  0
    mmc2 is current device
    Loading file "/boot/uImage" from mmc device 2:1 (xxc1)
    4119112 bytes read
    ## Booting kernel from Legacy Image at 10800000 ...
    Image Name: Linux-3.0.35
    Created: 2013-10-12 12:05:37 UTC
    Image Type: ARM Linux Kernel Image (uncompressed)
    Data Size: 4119048 Bytes = 3.9 MB
    Load Address: 10008000
    Entry Point: 10008000
    Verifying Checksum ... OK
    Loading Kernel Image ... OK
    OK
    Starting kernel ...
    [ 0.000000] Linux version 3.0.35 (udoo@ubuntu) (gcc version 4.4.4 (4.4.4_09.06.2010) ) #1 SMP PREEMPT Sat Oct 12 14:05:30 CEST 2013
    [ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
    [ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [ 0.000000] Machine: SECO i.Mx6 UDOO Board
    [ 0.000000] Kernel ver: v. 83
    [ 0.000000] Ignoring unrecognised tag 0x41000901
    [ 0.000000] Memory policy: ECC disabled, Data cache writealloc
    [ 0.000000] CPU identified as i.MX6Q, silicon rev 1.2
    [ 0.000000] PERCPU: Embedded 7 pages/cpu @8be08000 s5440 r8192 d15040 u32768
    [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 162304
    [ 0.000000] Kernel command line: console=ttymxc1,115200 root=/dev/mmcblk0p1 rootwait rw fixrtc rootflags=barrier=1 mem=768M arm_freq=996 video=mxcfb0:dev=hdmi,1920x1080M@60,if=RGB24
    [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [ 0.000000] Memory: 640MB = 640MB total
    [ 0.000000] Memory: 636288k/636288k available, 150144k reserved, 0K highmem
    [ 0.000000] Virtual kernel memory layout:
    [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
    [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
    [ 0.000000] DMA : 0xf4600000 - 0xffe00000 ( 184 MB)
    [ 0.000000] vmalloc : 0xb0800000 - 0xf2000000 (1048 MB)
    [ 0.000000] lowmem : 0x80000000 - 0xb0000000 ( 768 MB)
    [ 0.000000] pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
    [ 0.000000] modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
    [ 0.000000] .init : 0x80008000 - 0x80038000 ( 192 kB)
    [ 0.000000] .text : 0x80038000 - 0x80b03e8c (11056 kB)
    [ 0.000000] .data : 0x80b04000 - 0x80b63b00 ( 383 kB)
    [ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [ 0.222824] Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
    [ 0.311161] pid_max: default: 32768 minimum: 301
    [ 0.316043] Mount-cache hash table entries: 512
    [ 0.321262] CPU: Testing write buffer coherency: ok
    [ 0.326409] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
    [ 0.426939] CPU1: Booted secondary processor
    [ 0.506936] CPU2: Booted secondary processor
    [ 0.586939] CPU3: Booted secondary processor
    [ 0.626445] Brought up 4 CPUs
    [ 0.642270] SMP: Total of 4 processors activated (6324.22 BogoMIPS).
    [ 0.665725] print_constraints: dummy:
    [ 0.669715] NET: Registered protocol family 16
    [ 0.678446] print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal
    [ 0.685896] print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
    [ 0.693640] print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
    [ 0.701333] print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
    [ 0.709095] print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
    [ 0.716746] print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
    [ 0.725735]
    [ 0.725740] > UDOO quad
    [ 0.729533] > rev C Called set_gpios_direction
    [ 0.734192] Test and set gpios directions and values by Gionji feat. Ekirei test
    [ 0.765134] Resetting ethernet physical layer.
    [ 0.813008] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
    [ 0.819842] hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
    [ 0.827202] hw-breakpoint: maximum watchpoint size is 4 bytes.
    [ 0.833089] L310 cache controller enabled
    [ 0.837130] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x02070000, Cache size: 1048576 B
    [ 0.870427] bio: create slab <bio-0> at 0
    [ 0.878493] mxs-dma mxs-dma-apbh: initialized
    [ 0.883175] print_constraints: vmmc: 3300 mV
    [ 0.888241] vgaarb: loaded
    [ 0.891765] SCSI subsystem initialized
    [ 0.896637] usbcore: registered new interface driver usbfs
    [ 0.902265] usbcore: registered new interface driver hub
    [ 0.907767] usbcore: registered new device driver usb
    [ 0.912838] Freescale USB OTG Driver loaded, $Revision: 1.55 $
    [ 0.936441] imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
    [ 0.956441] imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
    [ 0.964321] MIPI CSI2 driver module loaded
    [ 0.968664] Advanced Linux Sound Architecture Driver Version 1.0.24.
    [ 0.975870] Bluetooth: Core ver 2.16
    [ 0.979585] NET: Registered protocol family 31
    [ 0.984043] Bluetooth: HCI device and connection manager initialized
    [ 0.990428] Bluetooth: HCI socket layer initialized
    [ 0.995320] Bluetooth: L2CAP socket layer initialized
    [ 1.000469] Bluetooth: SCO socket layer initialized
    [ 1.005781] cfg80211: Calling CRDA to update world regulatory domain
    [ 1.013190] i2c-core: driver [max17135] using legacy suspend method
    [ 1.019488] i2c-core: driver [max17135] using legacy resume method
    [ 1.025706] Switching to clocksource mxc_timer1
    [ 1.042634] NET: Registered protocol family 2
    [ 1.047189] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
    [ 1.055115] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
    [ 1.064449] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
    [ 1.072185] TCP: Hash tables configured (established 131072 bind 65536)
    [ 1.078821] TCP reno registered
    [ 1.081992] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [ 1.087959] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [ 1.094708] NET: Registered protocol family 1
    [ 1.099366] RPC: Registered named UNIX socket transport module.
    [ 1.105327] RPC: Registered udp transport module.
    [ 1.110047] RPC: Registered tcp transport module.
    [ 1.114777] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [ 1.122097] PMU: registered new PMU device of type 0
    [ 1.127196] Static Power Management for Freescale i.MX6
    [ 1.132457] wait mode is enabled for i.MX6
    [ 1.136752] cpaddr = b0880000 suspend_iram_base=b08fc000
    [ 1.142180] PM driver module loaded
    [ 1.146065] IMX usb wakeup probe
    [ 1.149754] add wake up source irq 75
    [ 1.157057] IMX usb wakeup probe
    [ 1.160576] cpu regulator mode:ldo_enable
    [ 1.164847] i.MXC CPU frequency driver
    [ 1.192264] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
    [ 1.198915] msgmni has been set to 1242
    [ 1.204297] alg: No test for stdrng (krng)
    [ 1.208551] io scheduler noop registered
    [ 1.212506] io scheduler deadline registered
    [ 1.216872] io scheduler cfq registered (default)
    [ 1.222652] MIPI DSI driver module loaded
    [ 1.226850] mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver hdmi
    [ 1.233370] mxc_hdmi mxc_hdmi: Detected HDMI controller 0x13:0xa:0xa0:0xc1
    [ 1.240297] fbcvt: 1920x1080@60: CVT Name - 2.073M9
    [ 1.251823] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines
    [ 1.270364] imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
    [ 1.303674] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines
    [ 1.329124] Console: switching to colour frame buffer device 160x64
    [ 1.377724] mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver ldb
    [ 1.384141] _regulator_get: get() with no identifier
    [ 1.396307] fbcvt: 1920x1080@60: CVT Name - 2.073M9
    [ 1.401818] mxc_sdc_fb mxc_sdc_fb.2: register mxc display driver ldb
    [ 1.519151] imx-sdma imx-sdma: loaded firmware 1.1
    [ 1.523849] imx-sdma imx-sdma: initialized
    [ 1.550279] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines
    [ 1.649098] Serial: IMX driver
    [ 1.649227] imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
    [ 1.649603] imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
    [ 1.702028] console [ttymxc1] enabled, bootconsole disabled
    [ 1.713786] imx-uart.3: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
    [ 1.725587] loop: module loaded
    [ 1.728735] request BOSSA_CLK IRQ
    [ 1.732061] registering IRQ 419 for BOSSAC Arduino erase/reset operation
    [ 1.782404] No sata disk.
    [ 1.786306] GPMI NAND driver registered. (IMX)
    [ 1.791708] vcan: Virtual CAN interface driver
    [ 1.796158] CAN device driver interface
    [ 1.799996] flexcan netdevice driver
    [ 1.803737] FEC Ethernet Driver
    [ 1.809081] fec_enet_mii_bus: probed
    [ 1.813828] usbcore: registered new interface driver rt2800usb
    [ 1.819670] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [ 1.826332] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
    [ 1.832985] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
    [ 1.870320] fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
    [ 1.890309] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
    [ 1.896498] hub 1-0:1.0: USB hub found
    [ 1.900262] hub 1-0:1.0: 1 port detected
    [ 1.904391] add wake up source irq 72
    [ 1.908090] fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
    [ 1.914760] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
    [ 1.950318] fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
    [ 1.970309] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
    [ 1.976437] hub 2-0:1.0: USB hub found
    [ 1.980200] hub 2-0:1.0: 1 port detected
    [ 1.984486] Initializing USB Mass Storage driver...
    [ 1.989541] usbcore: registered new interface driver usb-storage
    [ 1.995565] USB Mass Storage support registered.
    [ 2.000521] usbcore: registered new interface driver usbserial
    [ 2.006462] USB Serial support registered for generic
    [ 2.011651] usbcore: registered new interface driver usbserial_generic
    [ 2.018181] usbserial: USB Serial Driver core
    [ 2.022659] USB Serial support registered for debug
    [ 2.027655] usbcore: registered new interface driver debug
    [ 2.033158] ARC USBOTG Device Controller driver (1 August 2005)
    [ 2.039822] mousedev: PS/2 mouse device common for all mice
    [ 2.046421] i2c-core: driver [isl29023] using legacy suspend method
    [ 2.052705] i2c-core: driver [isl29023] using legacy resume method
    [ 2.059568] snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
    [ 2.066246] i2c /dev entries driver
    [ 2.070478] Linux video capture interface: v2.00
    [ 2.075464] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
    [ 2.083083] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
    [ 2.090714] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18
    [ 2.098318] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video19
    [ 2.105936] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video20
    [ 2.113724] vivi-000: V4L2 device registered as video0
    [ 2.118868] Video Technology Magazine Virtual Video Capture Board ver 0.8.0 successfully loaded.
    [ 2.128045] i2c-core: driver [mag3110] using legacy suspend method
    [ 2.134242] i2c-core: driver [mag3110] using legacy resume method
    [ 2.140743] imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
    [ 2.148866] Bluetooth: Virtual HCI driver ver 1.3
    [ 2.153789] Bluetooth: HCI UART driver ver 2.2
    [ 2.158236] Bluetooth: HCIATH3K protocol initialized
    [ 2.163216] Bluetooth: Generic Bluetooth USB driver ver 0.6
    [ 2.168924] usbcore: registered new interface driver btusb
    [ 2.174610] sdhci: Secure Digital Host Controller Interface driver
    [ 2.180808] sdhci: Copyright(c) Pierre Ossman
    [ 2.185478] mmc0: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA
    [ 2.192823] mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
    [ 2.200876] VPU initialized
    [ 2.204673] mxc_asrc registered
    [ 2.225167] Thermal calibration data is 0x57250069
    [ 2.229980] Thermal sensor with ratio = 180
    [ 2.254755] Anatop Thermal registered as thermal_zone0
    [ 2.264013] anatop_thermal_probe: default cooling device is cpufreq!
    [ 2.271414] usbcore: registered new interface driver usbhid
    [ 2.276989] usbhid: USB HID core driver
    [ 2.281243] usbcore: registered new interface driver snd-usb-audio
    [ 2.287984] mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
    [ 2.293464] Cirrus Logic CS42888 ALSA SoC Codec Driver
    [ 2.298730] i2c-core: driver [cs42888] using legacy suspend method
    [ 2.304953] i2c-core: driver [cs42888] using legacy resume method
    [ 2.304965] usb 2-1: new high speed USB device number 2 using fsl-ehci
    [ 2.339533] mmc0: new high speed SDHC card at address 0002
    [ 2.345406] mmcblk0: mmc0:0002 SD8GB 7.43 GiB
    [ 2.358213] mmc0: Controller never released inhibit bit(s).
    [ 2.363931] mmcblk0: error -5 sending status command, retrying
    [ 2.369794] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
    [ 2.385574] mmc0: Controller never released inhibit bit(s).
    [ 2.391279] mmcblk0: error -5 sending status command, retrying
    [ 2.397139] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
    [ 2.412894] mmc0: Controller never released inhibit bit(s).
    [ 2.416403] audio_codec_ac97_cold_reset
    [ 2.422513] mmcblk0: error -5 sending status command, retrying
    [ 2.428372] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
    [ 2.444139] mmc0: Controller never released inhibit bit(s).
    [ 2.449856] mmcblk0: error -5 sending status command, retrying
    [ 2.455727] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
    [ 2.471491] mmc0: Controller never released inhibit bit(s).
    [ 2.477193] mmcblk0: error -5 sending status command, retrying
    [ 2.483080] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
    [ 2.493450] Found Audio codec AC97 vt1613, [ID = 5649 - 4123]
    [ 2.498859] mmc0: Controller never released inhibit bit(s).
    [ 2.498986] mmcblk0: error -5 sending status command, retrying
    [ 2.499017] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
    [ 2.499080] end_request: I/O error, dev mmcblk0, sector 0
    [ 2.499090] Buffer I/O error on device mmcblk0, logical block 0
    [ 2.507178] mmc0: Controller never released inhibit bit(s).
    [ 2.507320] mmcblk0: error -5 sending status command, retrying
    [ 2.507353] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
    [ 2.507522] hub 2-1:1.0: USB hub found
    [ 2.515424] mmc0: Controller never released inhibit bit(s).
    [ 2.515555] hub 2-1:1.0: 4 ports detected
    [ 2.515573] mmcblk0: error -5 sending status command, retrying
    [ 2.515606] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
    [ 2.523680] mmc0: Controller never released inhibit bit(s).
    [ 2.523818] mmcblk0: error -5 sending status command, retrying
    [ 2.523849] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
    [ 2.531927] mmc0: Controller never released inhibit bit(s).
    [ 2.532072] mmcblk0: error -5 sending status command, retrying
    [ 2.532117] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
    [ 2.540198] mmc0: Controller never released inhibit bit(s).
    [ 2.540334] mmcblk0: error -5 sending status command, retrying
    [ 2.540365] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
    [ 2.548444] mmc0: Controller never released inhibit bit(s).
    [ 2.548555] mmcblk0: error -5 sending status command, retrying
    [ 2.548588] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
    [ 2.548643] end_request: I/O error, dev mmcblk0, sector 0
    [ 2.548652] Buffer I/O error on device mmcblk0, logical block 0
    [ 2.556729] mmc0: Controller never released inhibit bit(s).
    [ 2.556852] mmcblk0: error -5 sending status command, retrying
    [ 2.556884] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
    [ 2.564949] mmc0: Controller never released inhibit bit(s).
    [ 2.565072] mmcblk0: error -5 sending status command, retrying
    [ 2.565102] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
    [ 2.573166] mmc0: Controller never released inhibit bit(s).
    [ 2.573286] mmcblk0: error -5 sending status command, retrying
    [ 2.573317] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
    [ 2.581381] mmc0: Controller never released inhibit bit(s).
    [ 2.581502] mmcblk0: error -5 sending status command, retrying
    [ 2.581533] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
    [ 2.589596] mmc0: Controller never released inhibit bit(s).
    [ 2.589706] mmcblk0: error -5 sending status command, retrying
    [ 2.589737] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
    [ 2.597800] mmc0: Controller never released inhibit bit(s).
    [ 2.597920] mmcblk0: error -5 sending status command, retrying
    [ 2.597951] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900
    [ 2.598005] end_request: I/O error, dev mmcblk0, sector 0
    [ 2.598013] Buffer I/O error on device mmcblk0, logical block 0
    [ 2.598037] mmcblk0: unable to read partition table
    [ 2.811112] asoc: vt1613 <-> imx-ssi.0 mapping ok
    [ 2.817317] imx_3stack asoc driver
    [ 2.821967] usb 2-1.3: new high speed USB device number 3 using fsl-ehci
    [ 2.822764] asoc: mxc-hdmi-soc <-> imx-hdmi-soc-dai.0 mapping ok
    [ 2.823390] ALSA device list:
    [ 2.823396] #0: vt1613-audio
    [ 2.823402] #1: imx-hdmi-soc
    [ 2.823609] NET: Registered protocol family 26
    [ 2.824125] TCP cubic registered
    [ 2.824132] NET: Registered protocol family 17
    [ 2.824147] can: controller area network core (rev 20090105 abi 8)
    [ 2.824220] NET: Registered protocol family 29
    [ 2.824226] can: raw protocol (rev 20090105)
    [ 2.824231] can: broadcast manager protocol (rev 20090105 t)
    [ 2.876525] Bluetooth: RFCOMM TTY layer initialized
    [ 2.881438] Bluetooth: RFCOMM socket layer initialized
    [ 2.886580] Bluetooth: RFCOMM ver 1.11
    [ 2.890358] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [ 2.895671] Bluetooth: BNEP filters: protocol multicast
    [ 2.900908] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [ 2.906971] lib80211: common routines for IEEE802.11 drivers
    [ 2.912700] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    [ 2.920738] Bus freq driver module loaded
    [ 2.924754] Bus freq driver Enabled
    [ 2.930022] mxc_dvfs_core_probe
    [ 2.933372] DVFS driver module loaded
    [ 2.938553] snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:47:50 UTC (2870)
    [ 2.947378] VFS: Cannot open root device "mmcblk0p1" or unknown-block(179,1)
    [ 2.954443] Please append a correct "root=" boot option; here are the available partitions:
    [ 2.962813] b300 7794688 mmcblk0 driver: mmcblk
    [ 2.968141] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,1)
    [ 2.976658] [<800455b4>] (unwind_backtrace+0x0/0xfc) from [<8056c48c>] (panic+0x74/0x19c)
    [ 2.984858] [<8056c48c>] (panic+0x74/0x19c) from [<80008cb8>] (mount_block_root+0x16c/0x220)
    [ 2.993312] [<80008cb8>] (mount_block_root+0x16c/0x220) from [<80008e44>] (mount_root+0xd8/0xf4)
    [ 3.002129] [<80008e44>] (mount_root+0xd8/0xf4) from [<80008f80>] (prepare_namespace+0x120/0x178)
    [ 3.011019] [<80008f80>] (prepare_namespace+0x120/0x178) from [<800083dc>] (kernel_init+0x108/0x144)
    [ 3.015721] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
    [ 3.017365] Registered led device: rt2800usb-phy0::radio
    [ 3.017496] Registered led device: rt2800usb-phy0::assoc
    [ 3.017635] Registered led device: rt2800usb-phy0::quality
    [ 3.043087] [<800083dc>] (kernel_init+0x108/0x144) from [<8003f080>] (kernel_thread_exit+0x0/0x8)
    [ 3.051984] CPU1: stopping
    [ 3.054712] [<800455b4>] (unwind_backtrace+0x0/0xfc) from [<8003826c>] (do_IPI+0x120/0x14c)
    [ 3.063077] [<8003826c>] (do_IPI+0x120/0x14c) from [<8003dfcc>] (__irq_svc+0x4c/0xe8)
    [ 3.070909] Exception stack(0xa4067f90 to 0xa4067fd8)
    [ 3.075964] 7f80: 80b6b0c0 20000093 00000001 00000000
    [ 3.084146] 7fa0: a4066000 80b63be4 80571534 80b1cf54 1000406a 412fc09a 00000000 00000000
    [ 3.092328] 7fc0: 00000000 a4067fd8 8004d35c 8003f124 40000013 ffffffff
    [ 3.098949] [<8003dfcc>] (__irq_svc+0x4c/0xe8) from [<8003f124>] (default_idle+0x24/0x28)
    [ 3.107133] [<8003f124>] (default_idle+0x24/0x28) from [<8003f7e0>] (cpu_idle+0xc8/0x108)
    [ 3.115318] [<8003f7e0>] (cpu_idle+0xc8/0x108) from [<10569594>] (0x10569594)
    [ 3.122457] CPU3: stopping
    [ 3.125180] [<800455b4>] (unwind_backtrace+0x0/0xfc) from [<8003826c>] (do_IPI+0x120/0x14c)
    [ 3.133540] [<8003826c>] (do_IPI+0x120/0x14c) from [<8003dfcc>] (__irq_svc+0x4c/0xe8)
    [ 3.141372] Exception stack(0xa4077f90 to 0xa4077fd8)
    [ 3.146427] 7f80: 80b6b0c0 60000093 00000001 00000000
    [ 3.154609] 7fa0: a4076000 80b63be4 80571534 80b1cf54 1000406a 412fc09a 00000000 00000000
    [ 3.162790] 7fc0: 00000000 a4077fd8 8004d35c 8003f124 40000013 ffffffff
    [ 3.169412] [<8003dfcc>] (__irq_svc+0x4c/0xe8) from [<8003f124>] (default_idle+0x24/0x28)
    [ 3.177596] [<8003f124>] (default_idle+0x24/0x28) from [<8003f7e0>] (cpu_idle+0xc8/0x108)
    [ 3.185779] [<8003f7e0>] (cpu_idle+0xc8/0x108) from [<10569594>] (0x10569594)
    [ 3.192916] CPU0: stopping
    [ 3.195637] [<800455b4>] (unwind_backtrace+0x0/0xfc) from [<8003826c>] (do_IPI+0x120/0x14c)
    [ 3.203998] [<8003826c>] (do_IPI+0x120/0x14c) from [<8003dfcc>] (__irq_svc+0x4c/0xe8)
    [ 3.211829] Exception stack(0x80b05f68 to 0x80b05fb0)
    [ 3.216885] 5f60: 80b6b0c0 60000093 00000001 00000000 80b04000 80b63be4
    [ 3.225067] 5f80: 80571534 80b1cf54 1000406a 412fc09a 00000000 00000000 00000000 80b05fb0
    [ 3.233247] 5fa0: 8004d35c 8003f124 40000013 ffffffff
    [ 3.238306] [<8003dfcc>] (__irq_svc+0x4c/0xe8) from [<8003f124>] (default_idle+0x24/0x28)
    [ 3.246490] [<8003f124>] (default_idle+0x24/0x28) from [<8003f7e0>] (cpu_idle+0xc8/0x108)
    [ 3.254674] [<8003f7e0>] (cpu_idle+0xc8/0x108) from [<800088a4>] (start_kernel+0x248/0x288)
    [ 3.263032] [<800088a4>] (start_kernel+0x248/0x288) from [<1000803c>] (0x1000803c)
  6. firehopper
    firehopper Member
    Jun 10, 2013
    154
    reading that it seems like its having issues reading the filesystem. something either didnt get written properly or the card has bad spots on it somehow..
  7. DracoLlasa
    DracoLlasa UDOOer
    Oct 15, 2013
    417
    i would have to agree, that log is full of filesystem level errors.
    I would suggest using SDFormatter http://goo.gl/hxtjB
    Performa full format of the SD card (enable the 'resize' option)
    When its done re-image the SD card with the Linaro image and try again
  8. ji11x38
    ji11x38 New Member
    Nov 4, 2013
    22
    Hi Guys,
    Before making a hustle on doing some serial reads and stuff, i just wanted to know if image of the yocto-os available on the website actually works?
    Did not read anything on the forums about it! Just wanted to give it a try and it turned out as a bad idea..
    By the way: Would be cool if you guys could setup a better structure in the forum!
    sub-topics would be a great way to give an easy overview.
    e.g.
    Programming ->
    C | Python | IDE | Libraries
    samples samples qt OpenCv
    Ideas Getting things done processing Augemented Reality
    Thought about about topic concerning each os might be wise,too! (And what about stickies? e.g. tutorial that are read-only?)
  9. dtirados
    dtirados New Member
    Oct 30, 2013
    I have the same problem as dkonhauser. I tried both preloaded images with negative result.
    I followed estrictily step by step the troubleshoting guide, but still nothing happened. It's not just the hdmi not showing anything, it's just that even the serial port does not show anything at all. I also wrote an email to udoo support but I still have no response. Honestly, I think my udoo was dead on arrive and it won't boot anyway at all.
  10. maurizio
    maurizio Administrator
    Jul 1, 2013
    35
    Hi dtirados,
    Please provide your address using the contact form http://www.udoo.org/support/contact-us/ so we can ship the replacing UDOO, I'll be back to you as soon as possible with instruction for the return of the broken UDOO you received. Please, provide also the information about your tests.
    Sorry for the inconvenient.
  11. Black_Magic
    Black_Magic New Member
    Nov 5, 2013
    I just downloaded the Ubuntu image via bit torrent, and then tried from sourceforge as well - I have the same problem with each file.
    Windows 7 tells me that I do not have enough drive space to unzip it... not surprising as I couldn't afford to but the 807,167,508,041,846 kB it tells me is the file size (~800 Petabyte)
    The compressed size is 733,757 kB
    I suspect this is related to the issues the person above is having.
  12. powerage
    powerage New Member
    Nov 1, 2013
    @firehopper
    What excactly do you mean with bad spots? Do you mean that the card is physically defective? I have tried the Android image on the same card with no problems.
    @DracoLlasa
    I have tried SDFormater tool without any luck.
    After looking at the log file once more the line
    triggered me and by googling I found out that the Raspberry Pi had issues with the mmc driver issues in the beginning especially with Kingston SD cards. Newer kernel realeases seemed to remove the mmc driver issue from the Raspberry Pi.
    So the solution at this point is to find a new SD Card from another manufacturer.
    Regards
    Powerage
  13. DracoLlasa
    DracoLlasa UDOOer
    Oct 15, 2013
    417
    You have to unzip with 7zip, built in windows extract will fail
  14. Xykon
    Xykon Member
    Nov 1, 2013
    64
    20
    After thinking for almost 24h that my udoo had died, I bought a total of four microSD cards, 2x16GB Optima class 4 cards, 1x16GB SanDisk Ultra HC I and 1x32GB SanDisk Ultra HC I.
    After putting the Ubuntu 1.2 image onto the SanDisk 16GB card using a Win7 64bit Notebook and the integrated SDCard reader with an SD-mSD adapter, at least I got some output on the serial console though neither a login prompt nor the gui showed up.
    I deleted my post "udoo appears to be dead" which I posted in this forum yesterday as it now clearly seems to be an sdcard issue and not a hardware issue as I previously feared.
    I am now trying the various cards with various images and software (I use Win32 disk imager normally but also have cygwin installed to use dd) in the hopes to get a system booting.
    It would be good if someone could post (or better yet put on the download page) the md5sums of the zip and extracted images (not everyone has sha-1 on windows). This way we could at least check that the images extracted without errors. I'm currently running md5sum on my quad images and will post them later along with my latest findings in getting my udoo to boot again.
    Update2:
    It seems the Ubuntu image I downloaded previously was corrupt. I have now downloaded the images again and get the following:
    410f7cb1927650019774b9ba730bb623 *udoo_quad_android_1.1.img
    cd666c4f884cea1a1972f3e42462198a *udoo_quad_android_1.1.zip
    d8606a2e0960a3759fc3d93b943bdb0c *udoo_quad_ubuntu_1.2.img
    7a94fce0579404ba55189903615d02ae *udoo_quad_ubuntu_1.2.zip
    2697bc31233d97151e815d2a45dc354d4625e69a *udoo_quad_android_1.1.img
    029aa9a2227e4663bf3710e6d722087e41eb212e *udoo_quad_android_1.1.zip
    7b8329c948a7fa50f8666e172ffd43f7a4f86194 *udoo_quad_ubuntu_1.2.img
    eb5d7b03c58b2151d41bf309cc3ead7e5632e5aa *udoo_quad_ubuntu_1.2.zip
    Here is the serial log of my current card, Ubuntu Image 1.2 downloaded from SF image (same as before, no GUI):
    Thermal sensor with ratio = 185
    Temperature:   37 C, calibration data 0x59451a69
    mx6q pll1: 792MHz
    mx6q pll2: 528MHz
    mx6q pll3: 480MHz
    mx6q pll8: 50MHz
    Boot Device: NOR
    I2C:   ready
    DRAM:   1 GB
    In:    serial
    Out:   serial
    Err:   serial
    Net:   got MAC address from IIM: 00:c0:08:88:17:f5
    FEC0 [PRIME]
    4119112 bytes read
    OK
    Starting kernel ...
    [    0.222822] Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
    [    0.311155] pid_max: default: 32768 minimum: 301
    [    0.316040] Mount-cache hash table entries: 512
    [    0.321254] CPU: Testing write buffer coherency: ok
    [    0.326407] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
    [    0.426935] CPU1: Booted secondary processor
    [    0.506934] CPU2: Booted secondary processor
    [    0.586942] CPU3: Booted secondary processor
    [    0.626442] Brought up 4 CPUs
    [    0.642266] SMP: Total of 4 processors activated (6324.22 BogoMIPS).
    [    0.665752] print_constraints: dummy:
    [    0.669739] NET: Registered protocol family 16
    [    0.678453] print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal
    [    0.685905] print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
    [    0.693654] print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
    [    0.701346] print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
    [    0.709111] print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
    [    0.716764] print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
    [    0.725754]
    [    0.725761] > UDOO quad
    [    0.729553] > rev C Called set_gpios_direction
    [    0.734213] Test and set gpios directions and values by Gionji feat. Ekirei test
    [    0.765204] Resetting ethernet physical layer.
    [    0.812956] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
    [    0.819790] hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
    [    0.827149] hw-breakpoint: maximum watchpoint size is 4 bytes.
    [    0.833035] L310 cache controller enabled
    [    0.837077] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x02070000, Cache size: 1048576 B
    [    0.870441] bio: create slab <bio-0> at 0
    [    0.878313] mxs-dma mxs-dma-apbh: initialized
    [    0.882996] print_constraints: vmmc: 3300 mV
    [    0.888059] vgaarb: loaded
    [    0.891588] SCSI subsystem initialized
    [    0.896471] usbcore: registered new interface driver usbfs
    [    0.902099] usbcore: registered new interface driver hub
    [    0.907589] usbcore: registered new device driver usb
    [    0.912658] Freescale USB OTG Driver loaded, $Revision: 1.55 $
    [    0.956440] imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
    [    0.964320] MIPI CSI2 driver module loaded
    [    0.968663] Advanced Linux Sound Architecture Driver Version 1.0.24.
    [    0.975878] Bluetooth: Core ver 2.16
    [    0.979594] NET: Registered protocol family 31
    [    0.984052] Bluetooth: HCI device and connection manager initialized
    [    0.990435] Bluetooth: HCI socket layer initialized
    [    0.995328] Bluetooth: L2CAP socket layer initialized
    [    1.000484] Bluetooth: SCO socket layer initialized
    [    1.005793] cfg80211: Calling CRDA to update world regulatory domain
    [    1.013192] i2c-core: driver [max17135] using legacy suspend method
    [    1.019491] i2c-core: driver [max17135] using legacy resume method
    [    1.025707] Switching to clocksource mxc_timer1
    [    1.042719] NET: Registered protocol family 2
    [    1.047269] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
    [    1.055198] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
    [    1.064539] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
    [    1.072280] TCP: Hash tables configured (established 131072 bind 65536)
    [    1.078915] TCP reno registered
    [    1.082091] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    1.088057] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    1.094808] NET: Registered protocol family 1
    [    1.099460] RPC: Registered named UNIX socket transport module.
    [    1.105423] RPC: Registered udp transport module.
    [    1.110142] RPC: Registered tcp transport module.
    [    1.114874] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.122226] PMU: registered new PMU device of type 0
    [    1.127329] Static Power Management for Freescale i.MX6
    [    1.132593] wait mode is enabled for i.MX6
    [    1.136887] cpaddr = b0880000 suspend_iram_base=b08fc000
    [    1.142334] PM driver module loaded
    [    1.146223] IMX usb wakeup probe
    [    1.149907] add wake up source irq 75
    [    1.157199] IMX usb wakeup probe
    [    1.160735] cpu regulator mode:ldo_enable
    [    1.165010] i.MXC CPU frequency driver
    [    1.192803] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
    [    1.199459] msgmni has been set to 1242
    [    1.204858] alg: No test for stdrng (krng)
    [    1.209122] io scheduler noop registered
    [    1.213078] io scheduler deadline registered
    [    1.217447] io scheduler cfq registered (default)
    [    1.223239] MIPI DSI driver module loaded
    [    1.227432] mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver hdmi
    [    1.233951] mxc_hdmi mxc_hdmi: Detected HDMI controller 0x13:0xa:0xa0:0xc1
    [    1.240875] fbcvt: 1920x1080@60: CVT Name - 2.073M9
    [    1.252519] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines
    [    1.270361] imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
    [    1.303669] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines
    [    1.329122] Console: switching to colour frame buffer device 160x64
    [    1.377760] mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver ldb
    [    1.384177] _regulator_get: get() with no identifier
    [    1.397617] mxc_sdc_fb mxc_sdc_fb.2: register mxc display driver ldb
    [    1.407955] fbcvt: 1920x1080@60: CVT Name - 2.073M9
    [    1.414117] imx-sdma imx-sdma: loaded firmware 1.1
    [    1.418394] imx-sdma imx-sdma: initialized
    [    1.625287] Serial: IMX driver
    [    1.625410] imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
    [    1.625792] imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
    [    1.683094] console [ttymxc1] enabled, bootconsole disabled
    [    1.694643] imx-uart.3: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
    [    1.706474] loop: module loaded
    [    1.709625] request BOSSA_CLK IRQ
    [    1.712952] registering IRQ 419 for BOSSAC Arduino erase/reset operation
    [    1.762314] No sata disk.
    [    1.766221] GPMI NAND driver registered. (IMX)
    [    1.772551] vcan: Virtual CAN interface driver
    [    1.776999] CAN device driver interface
    [    1.780848] flexcan netdevice driver
    [    1.784584] FEC Ethernet Driver
    [    1.789917] fec_enet_mii_bus: probed
    [    1.794652] usbcore: registered new interface driver rt2800usb
    [    1.800506] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    1.807151] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
    [    1.813798] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
    [    1.850323] fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
    [    1.870315] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
    [    1.876510] hub 1-0:1.0: USB hub found
    [    1.880273] hub 1-0:1.0: 1 port detected
    [    1.884388] add wake up source irq 72
    [    1.888088] fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
    [    1.894759] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
    [    1.930327] fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
    [    1.950311] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
    [    1.956450] hub 2-0:1.0: USB hub found
    [    1.960213] hub 2-0:1.0: 1 port detected
    [    1.964497] Initializing USB Mass Storage driver...
    [    1.969557] usbcore: registered new interface driver usb-storage
    [    1.975580] USB Mass Storage support registered.
    [    1.980518] usbcore: registered new interface driver usbserial
    [    1.986460] USB Serial support registered for generic
    [    1.991655] usbcore: registered new interface driver usbserial_generic
    [    1.998186] usbserial: USB Serial Driver core
    [    2.002664] USB Serial support registered for debug
    [    2.007664] usbcore: registered new interface driver debug
    [    2.013166] ARC USBOTG Device Controller driver (1 August 2005)
    [    2.019853] mousedev: PS/2 mouse device common for all mice
    [    2.026422] i2c-core: driver [isl29023] using legacy suspend method
    [    2.032708] i2c-core: driver [isl29023] using legacy resume method
    [    2.039552] snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
    [    2.046241] i2c /dev entries driver
    [    2.050456] Linux video capture interface: v2.00
    [    2.055439] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
    [    2.063066] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
    [    2.070687] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18
    [    2.078288] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video19
    [    2.085896] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video20
    [    2.093699] vivi-000: V4L2 device registered as video0
    [    2.098841] Video Technology Magazine Virtual Video Capture Board ver 0.8.0 successfully loaded.
    [    2.108005] i2c-core: driver [mag3110] using legacy suspend method
    [    2.114203] i2c-core: driver [mag3110] using legacy resume method
    [    2.120718] imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
    [    2.128825] Bluetooth: Virtual HCI driver ver 1.3
    [    2.133741] Bluetooth: HCI UART driver ver 2.2
    [    2.138188] Bluetooth: HCIATH3K protocol initialized
    [    2.143167] Bluetooth: Generic Bluetooth USB driver ver 0.6
    [    2.148872] usbcore: registered new interface driver btusb
    [    2.154527] sdhci: Secure Digital Host Controller Interface driver
    [    2.160724] sdhci: Copyright(c) Pierre Ossman
    [    2.165392] mmc0: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA
    [    2.172740] mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
    [    2.183929] VPU initialized
    [    2.187721] mxc_asrc registered
    I had the same issue before that udoo was hanging at this point when I didn't have a keyboard and mouse connected. However this time I do have them both directly connected but they don't seem to be recognized at this point because neither the numlock nor the mouse optical led are coming on. It's hanging here forever.
    What I don't understand is that the first SDcard I tried (which is a Lexar 16GB class 4 card), suddenly didn't work any more while the system was actually running. And I checked the card with dd if=/dev/sdb of=/dev/null bs=512k and dd if=/dev/zero of=/dev/sdb bs=512k multiple times and no read/write errors were reported so I don't see how the card could be damaged. Is there any windows tool that can read the list of bad blocks from SD/mSD cards? But even if there are some corrupted blocks on the card, uboot should still come up unless the very first sectors of the card are actually faulty...
    In case this is somehow relevant, I'm using WinRAR 5.0 64bit edition for which I have a valid (personally paid for) license to unzip the images
    [Update4] I also tried 7zip but the sha1 sum is the same as when using WinRAR to extract the image file. So I believe it's not a problem unpacking the image
    Update3:
    Now none of my cards give any serial output, even those that I had confirmed to work previously. It's starting to get really frustrating :(
    One minute I see serial output and the next minute the serial console stays black and no matter what I do I don't get it back to doing anything. Maybe if I wait again until tomorrow evening I will be able to continue...
  15. Xykon
    Xykon Member
    Nov 1, 2013
    64
    20
    I start to believe that one of the issues I am having is with my mSD card reader. It looks like a USB stick with a mSD card slot at the end. It doesn't seem to work with all of my cards. I also got a SanDisk SD <-> mSD adapter with my new cards today and when I use the SD card reader built into my Notebook at least I seem to get better results. I'm still not able to get the GUI up but at least I see some output on the serial port now.
    I'll continue updating my previous post with further results but wanted to post this for others having problems with no output to try another card reader. This might solve your problem so you don't have to wait for another udoo to arrive as your board may be fully functional.
  16. powerage
    powerage New Member
    Nov 1, 2013
    Hi all,
    Just an update regarding my trouble getting the Linaro image running on my Udoo quad. Earlier today I purchased a Transcend Micro SD card (8 GB, class 4) . I am now able to boot the Linaro image with no problems at all. Seems like the Kingston SD card isn't at good match with the Udoo board.
    Regards,
    Powerage
  17. dtirados
    dtirados New Member
    Oct 30, 2013
    Thank you very, very much for your help maurizio.
    I'm writing an email at this moment to give my address.
  18. Xykon
    Xykon Member
    Nov 1, 2013
    64
    20
    I checked on argos.co.uk but the only 8GB cards they have are SanDisk. I have a 16GB and 32GB SanDisk card and while they seemed to work initially they stopped working now (at least in the udoo, on Windows and Linux they still work like a charm).
    Is there any reason why udoo wouldn't be able to load u-boot from cards bigger than 8GB? My udoo was working fine on a Lexar 16GB card for several days (I created a 2nd partition to mount as /home instead of expanding the root partition) before it stopped working completely. And my 16GB sandisk card at managed to load u-boot and the kernel several times before stopping completely again, though I'm sure it wasn't able to mount the rootfs which is why neither the serial login prompt nor the gui ever showed up.
    I'm wondering if udoo is actually "eating" my mSD cards, i.e. somehow alters them in a way that makes them unusable again on the udoo. But on the other hand my 32GB card never worked on the udoo... and the 16GB cards I loaded with yocto would at least load u-boot (although the board kept resetting shortly after the autoboot counter expired no matter if I tried to interrupt autoboot or not). Now that card, which I didn't modify after that one test, doesn't work either.
    I'm starting to think that my udoo is actually broken and that it's not related to the mSD card image. I even tried just loading u-boot onto a card using dd if=u-boot-q.bin of=/dev/sdb bs=512 seek=2 skip=2; sync which I believe should make udoo at least give the u-boot output on the serial terminal even though it won't be able to load the kernel and rootfs; but even that doesn't seem to work.
    In a last hope effort I ordered a microSD card sniffer from Sparkfun to see if udoo is actually trying to read from the mSD card. Unfortunately these were out of stock at the usual Sparkfun dealers in the UK so I had to order directly using USPS First-Class Mail International Package (all other shipping options were too expensive for a $10 item).
    I'm wondering if it is possible to boot from the secondary SD card interface that is available on the headers? Or if it is possible to equip udoo with an i²c or spi boot flash chip. These chips might not be big enough to hold u-boot but maybe I could at least boot a little self test binary that would tell me if my udoo is damaged or not.
    I also checked voltages on the 1st and 2nd pin on the jtag header J17A1 which is at 3.3V so I assume that the voltage regulators are working and the udoo is getting power. I haven't had a chance yet to connect any jtag adapter. The jlink arm I usually use is limited to Atmel (oem license) and I haven't unpacked my olimex arm jtag adapter yet which is still somewhere inside one of my moving cartons. So I can't check at this time if the cpu is functioning properly.
    The only other thing I can think of to try at this time is to reflow the iMX6 and the ram chips in case they haven't been properly soldered to the board. It might explain why the udoo stopped working after letting it run for a whole day while I was at work. Maybe when I then left it alone for a night and a day it semi-reconnected to the board but got disconnected again after heating up during my test session yesterday. Unfortunately I don't have a professional rework station but only a hot air station so I'd risk disconnecting some of the passive parts around the chips. It's certainly not something I'd like to risk if the solution could be much simpler.
    Maybe I should just forget about the udoo for a few days and wait until more tips are posted with things I could try that don't involve destroying the board. :D Or at least wait for that mSD sniffer to arrive to see if udoo is actually trying to read the sd card which should proof if this is indeed a card or hardware issue.
  19. Xykon
    Xykon Member
    Nov 1, 2013
    64
    20
    I think I found something... either my udoo just reset itself magically after almost 24h or there is a problem with the mbr on the sdcard.
    When I got the new cards they seemed to work for a while before everything stopped working and I no longer got any output on the serial console. Now I tried a program called MiniTool Partition Wizard for Windows. I deleted all partitions on the SDCards, told it to rebuild the mbr and create a single partition with fat32 fs. I did the mbr rebuild again after that just to be sure. Now I loaded the ubuntu image onto the card again and at least I get u-boot and the kernel to boot. Unfortunately I still don't get to the prompt but at least I again have some hope that my udoo board isn't 100% fried.
    I have an important meeting at work tomorrow morning so I can't continue troubleshooting this right now but this might be a viable solution for some booting problems. The only thing I don't understand is that the card images should normally start at the first sector and therefore contain the mbr... so even though it doesn't make sense to me right now I'm happy to get back to where I was earlier...
    Update:
    Or maybe not. Maybe it really just magically resets itself every night because now it's dead again after booting u-boot & kernel just two minutes ago. I even ran the whole mbr rebuild procedure again and it doesn't work now :(
  20. dkonhauser
    Oct 28, 2013
    11
    I am not a very happy UDOOer at this point.
    I have posted twice in the forum about my UDOO Quad not booting AND sent a contact form and have gotten NO response. Yet when another user said they had the same problem as me - you offered them an UDOO swap.
    What do I need to do for you to address my issue?
