MIDI configuration
Discussion in 'Linux Ubuntu' started by killkrt, Mar 20, 2014.
  1. killkrt
    killkrt New Member
    Nov 1, 2013
    22
    I'm trying to connect my Line 6 Keys 25 (and also an Axiom Pro 49).
    This the output of amidi -l:
    Dir Device    Name
    IO  hw:2,0,0  Mobile Keys 25 MIDI 1
    So the keyboard seems to be recognised, but I got the following problems:
    ubuntu@udoo:~$ ls -al /dev/snd/seq
    ls: cannot access /dev/snd/seq: No such file or directory
    ubuntu@udoo:~$ aconnect -i -o
    ALSA lib seq_hw.c:457:(snd_seq_hw_open) open /dev/snd/seq failed: No such file or directory
    can't open sequencer
    ubuntu@udoo:~$ lsmod | grep snd
    ubuntu@udoo:~$
    As you can see it seems that there is something wrong with the sequencer configuration... But I don't know how to fix! :(
    I'm running Ubuntu 12.04 LTS (Linux udoo 3.0.35 #1 SMP PREEMPT Mon Mar 3 15:17:07 CET 2014 armv7l armv7l armv7l GNU/Linux), but I'm quite sure to remember that I got the same problem on Debian Wheezy Beta 1 (but at the moment I cannot make a test).
    Could you help me?
    Thank you.
  2. photuris
    photuris New Member
    Mar 31, 2014
    11
    I'm trying to get a Roland UM-ONE midi interface working on my UDOO.
    it's not listed by amidi -l
    though the UM-1's 'USB' led is lit, which afaik means that it is recognised.
    (e.g. connecting the UM-ONE to a windows or macintosh machine without installing its drivers does not light up the USB led)
    from aconnect -lio, I also get:
    I'm running Ubuntu Studio 12.04 armHF
    On my laptop, running ubuntu Ubuntu 13.10, the UM-ONE 'just works'
    (here amidi -l gives IO hw:2,0,0 UM-ONE MIDI 1)
    any help appreciated!
  3. killkrt
    killkrt New Member
    Nov 1, 2013
    22
    Hi photuris,
    I still have this problem! :-(
    I think, but I'm not sure (I didn't yet check it), that the problem is due to fact that the kernel has not been compiled with the MIDI module selected, so as far as I know we have to compile the MIDI module (I don't know which one exactly) and then use something like insmod or modprobe to load it.
    The other solution could be to compile the official kernel selecting the MIDI module.
    Anyway, as I said, those are only speculations... I'll check it in the next days.
    Maybe someone could confirm my assumption... In case I'd understand why this module has not been included in the kernel.
    Ciao!
  4. photuris
    photuris New Member
    Mar 31, 2014
    11
    oh too bad!
    unfortunately I have little to no experience in compiling kernels...
    compiling the midi module separately might be something I could look into, but I would need some more info...and time...
    greetings
  5. photuris
    photuris New Member
    Mar 31, 2014
    11
    the module that is missing is snd_seq
    can someone add this, or show us how?
    thanks
  6. ms20mini
    ms20mini New Member
    Apr 13, 2014
    Hi there,
    I use Linaro Ubuntu 12.04 LTS v2.1 with an UDOO Quad.
    Same problem here with my synthesizer Korg MS-20 mini pluged in USB with my UDOO Quad.
    "amidi -l" in my terminal give this:
    Dir Device     Name
    IO  hw:2,0,0  MS-20 mini MIDI 1
    But when I launch QjackCtl to root Pure Data and my MS-20 mini, I have this:
    16:03:55.391 Patchbay deactivated.
    16:03:55.497 Statistics reset.
    16:03:55.545 Could not open ALSA sequencer as a client. ALSA MIDI patchbay will be not available.
    16:04:13.147 D-BUS: Service is available (org.jackaudio.service aka jackdbus).
    Cannot connect to server socket err = No such file or directory
    jack server is not running or cannot be started
    Can you fixe it please!
    Thanks in advance
  7. photuris
    photuris New Member
    Mar 31, 2014
    11
    just a small note;
    I installed the midisport firmware loaders
    the midisport 2x2 firmware loads (its led glows on/off)
    the 2x2 also gets listed by amidi -l
    if only alsa could talk to it now...!
  8. ms20mini
    ms20mini New Member
    Apr 13, 2014
    What I understand is that we have to rebuild the kernel :? (I'm incapable of it)
    Because "sudo modprobe snd_seq" give this
    FATAL: Module snd_seq not found.
    FATAL: Error running install command for snd_seq
  9. delba
    1,063
    Thank you guys for reporting that. The current kernel doesn't have the midi modules enabled. We'll recompile it including the missing modules, once done that it will be sufficient for you to upgrade to the latest kernel as described here:
    http://www.udoo.org/update-procedure/
  10. killkrt
    killkrt New Member
    Nov 1, 2013
    22
    This is a great news! I was thinking to try by myself, but since I've never done this before it could end in a terrible experience! ;-)
    Please keep us updated!
    Thank you very much!
  11. photuris
    photuris New Member
    Mar 31, 2014
    11
    great! looking forward :)
  12. ms20mini
    ms20mini New Member
    Apr 13, 2014
    I was waiting for this... ;)
  13. ms20mini
    ms20mini New Member
    Apr 13, 2014
    Do you know when it is going to be ready?? I really need this functionality!! :mrgreen:
  14. ektor5
    Jul 1, 2013
    97
    48
    Hi all,
    I've done a brief recompilation.
    Try this binaries unpacking them on the right locations.
    sudo tar -xvf uImage*.tar.gz  -C /
    sudo tar -xvf modules*.tar.gz -C /
    Reboot and enjoy. I'll wait for feedback, if it's positive, we'll set this config as default.
    Ek5
    PS: Mind learning how to recompile your own kernel, someday. It's not this difficult, ok? Have a nice day
  15. photuris
    photuris New Member
    Mar 31, 2014
    11
    hello,
    I tried this out.
    It's one step closer, but not there yet, for me at least.
    aconnect -lio now lists some things, namely Timidity, System, and software alsamidi ports that I create internally...
    however, USB midi devices don't show up and can not be connected to.
    thanks
  16. danomatika
    danomatika New Member
    Feb 3, 2014
    I just built a custom kernel for the Udoobuntu beta with midi support. Here are my notes:
    Adapted from this Udoo forum post.
    Make sure gcc, git, & ncurses-dev are installed:
    sudo apt-get install build-essential git-core libncurses5-dev
    Download, build, & install u-boot:
    wget ftp://ftp.denx.de/pub/u-boot/u-boot-2014.01.tar.bz2
    bzip2 -cd u-boot-2014.01.tar.bz2 | tar xvf -
    cd u-boot-2014.01
    make -j5 tools
    sudo cp tools/mkimage /usr/local/bin/
    Download Udoo kernel sources & configure:
    git clone https://github.com/UDOOboard/Kernel_Unico.git
    cd Kernel_Unico
    make UDOO_defconfig
    make menuconfig
    Enable ALSA sequencer & midi support in menuconfig. This may or may not be different as I see the Udoo guys are adding some Midi stuff to the default options. Just make sure the following are checked as either * or M:
    Device Drivers --->
    	<*> Sound card support --->
    		<*> ALSA --->
     			<*> Sequencer support
        			<*> Sequencer dummy client
        			[*] OSS Sequencer support
        			<*> Generic sound devices --->
        				<M> Virtual MIDI soundcard
    Build & install. You might want to make a backup of the existing uImage in /boot (*the following does not do this*):
    Note: make sure to set the KDIR directory correctly or the uImage won't work .. at least it didn't for me when I forgot that line :p
    export KDIR=/home/USERNAME/Kernel_Unico
    make -j5 uImage modules
    sudo make modules_install
    sudo cp arch/arm/boot/uImage /boot/
    Reboot:
    sudo reboot
    If everything built correctly, running
    aconnect -lio
    should work without and snd_seq errors.
  17. photuris
    photuris New Member
    Mar 31, 2014
    11
    hi danomatika,
    thanks for this, I'm trying it out
    however I'm stuck at:
    make UDOO_defconfig
    *** Can't find default configuration "arch/x86/configs/UDOO_defconfig"!
    make[1]: *** [UDOO_defconfig] Error 1
    make: *** [UDOO_defconfig] Error 2
    any hints?
    thanks
  18. photuris
    photuris New Member
    Mar 31, 2014
    11
    is this to be done on the UDOO itself?
    I'm trying it at my laptop, because on UDOO I get:
    [sudo] password for ubuntu:
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    Package build-essential is not available, but is referred to by another package.
    This may mean that the package is missing, has been obsoleted, or
    is only available from another source
    E: Package 'build-essential' has no installation candidate
    E: Unable to locate package git-core
    E: Unable to locate package libncurses5-dev
    on the first step
  19. photuris
    photuris New Member
    Mar 31, 2014
    11
    ok, I discovered the first step has to be:
    sudo apt-get update
    after that it seems to work
    sorry for the noise
