My mega thread on regular sized PCIe slot
Discussion in 'UDOO X86' started by ccs_hello, May 11, 2017.
Tags:
  1. ccs_hello
    536
    194
    I think it is the time to explain the step-by-step on how to convert UDOO x86's NGFF M.2 B-key (a.k.a. NGFF socket 2) to a regular sized PCIe slot.
    Step 0) buy the following adapter card from fleaBay. The $9 one shipped faster (in about 3 weeks.) The $3 one took longer (about 50 days.)
    Here is the board close-up. The M.2 connector is M-key (socket 3) and the PCIe connector is PCIe x4 (only 2 lanes are used even the board is for M-key 4-lane PCIe.)
    I'll explain the rationale in later posts.
    ccs_hello
    (In fleaBay, search
    PCI-E 4X Female to NGFF M.2 M Key Male Adapter Power Cable with Converter Card
    http://www.ebay.com/itm/311414541676?
    Quotic, Gronis, diglo and 2 others like this.
  2. ccs_hello
    536
    194
    Step 1) cut a slot (blue shaded one) using Dremel saw wheel. Cut the center line first. then gradually move sideways to create the "B" slot.
    Make sure the 6 gold fingers on the left edge are not removed.
    P.S. originally one only has the "M"-slot.
    ccs_hello
  3. ccs_hello
    536
    194
    As you see see in the first pic in post 1, there is a 4-pin Molex mini power socket (the one used in 3.5" floppy drive.)
    It will be needed to supply 12V to some PCIe card which requires 12V. Some don't (just 3.3V powered and supplied thru M.2 socket.)
    Example is a Marvell SATA controller with 4 SATA ports and supports hardware RAID 0, 1, and 1+0.
    This specific board is a unusual PCIe x2 adapter (11 gold fingers on left and 11 on right.)
    See resulted configuration.
    The card itself:
    ccs_hello
  4. ccs_hello
    536
    194
    Use
    sudo lspci -vv
    to show that the controller indeed is taking advantage of PCIe x2 (2 lane bus)
    ccs_hello
  5. ccs_hello
    536
    194
    Now step 2) -- create a 12V power cable for this PCIe adapter.
    Find a scrap old 3.5" floppy disk power cable. Only use the Yellow and Black wires.
    Connect these two wires to UDOO x86's own power supply lines.
    (Sorry in my picture, my "Yellow" color wire is actually colored red.)
    Example use case: add a Gigabit Ethernet card.
    ccs_hello
  6. ccs_hello
    536
    194
    Some might ask why another Ethernet card?
    Reason one: VMware vSphere does not support Realtek RT8111 chip. There are ways to work around it (inject 3rd party driver to ISO image) but is ugly.
    Reason 2: besides, two-NIC is better than 1.
    (Picture showing the other side of the gigE card.)
    ccs_hello
  7. ccs_hello
    536
    194
  8. Triodefreak
    Triodefreak Active Member
    Jun 7, 2016
    104
    30
    Thanks for this!
  9. elefas
    elefas New Member
    May 1, 2017
    Great work! Thanks a lot for showing the way.
  10. Quotic
    Quotic UDOOer
    Apr 13, 2017
    12
    Thanks, i ordered it :)
