Got my Neo today. When I connect it to USB a green light comes on and that is all? Should I follow the instructions on the box instead of the ones in the email that said to read instructions from the USB.
I read as well as the USB mass storage emulation it is supposed to serve web pages, etc. Is this all without an SD card or was it supposed to come with one?
I tried a different USB cable and now it does appear as a USB device in Win7, but an HID input device, not an RNDIS network device or mass storage.
So I ignored the email and followed the instructions on the packet which are to download an image and put it on an SD card. Works fine then. The only reason I didn't do this in the first place was the update email that says we put instructions inside the package: don't follow the instructions about udooneo.local; instead, when you connect the MicroUSB you'll see UDOO Neo as it was an USB key. Open the unit. Inside you'll find a file named "quickstart.html" with all the instructions to start playing; for the documentation, open the "docs" folder and click on the file named "index.html"; This makes no sense because it doesn't do anything without an SD card.
Hi there nophead, if you actually follow the abovementioned instructions you'll end up writing an image on your Micro SD as well. Give a look at the Docs and you'll see I'm not wrong on this.
Sorry I interpreted the email as ignore everything written on the box and follow the instructions on the USB instead. Actually it means follow the box steps 1 - 3 and just ignore step 4. I was surprised that you could have docs on the board without an SD card and indeed they aren't.
