I just received a new BOLT v3. I can’t get it to do anything. When I turn it on, LED 13 blinks, nothing appears on the monitor and the fan doesn’t run. If I boot with the Restore To Factory Settings switch in the other position, the result is exactly the same. I can’t find any way to reprogram the eMMC ROM to install the BIOS. Is there anything I can do about it?
It sounds like there may be an issue with the BOLT v3 hardware. You can try contacting the manufacturer for assistance, or returning the device if it is still under warranty. It may also be helpful to check online forums or support communities to see if other users have experienced similar issues and have found solutions.
