new OpenELEC
Discussion in 'XBMC' started by vpeter, Dec 12, 2014.
  1. vpeter
    vpeter Active Member
    Nov 29, 2014
    303
    62
    Maybe it boot to fast or splash is disabled. Check file /storage/.kodi/userdata/advancedsettings.xml for splash node inside.
  2. idorel77
    idorel77 Member
    Jul 25, 2014
    131
    /storage/.kodi/userdata/advancedsettings.xml is not exist :D
    but is /storage/.kodi/userdata/guisettings.xml now, and nothing about splash settings :)
    Instead on my pc working if i put spleash on /.kodi/media/Splash.png.
    This in not problem i will search more :)
    It is true, openelec not support dongle 3g?
    Thanks.
  3. vpeter
    Nov 29, 2014
    303
    62
    Then create it with correct content. But probably will not help to get splash visible.
    Probably doesn't have drivers enabled.
  4. jerichodee
    jerichodee UDOOer
    Jan 5, 2014
    19
    Is it possible to setup this Openelec to work with LVDS screens or both the HDMI and LDVS at the same time? After I run the U-boot commands to switch to 15" LVDS touch I just get a blank screen. I would prefer to do dual screen at the same time.
  5. vpeter
    Nov 29, 2014
    303
    62
    I don't know for both at the same time but LVDS is probably different video output set in uEnv.txt. Check that file in /flash folder.
    Not sure if device tree supports that. Don't have any display to test.
  6. Pikmin
    Pikmin New Member
    Jan 25, 2015
  7. vpeter
    Nov 29, 2014
    303
    62
    Interesting. I though it would not. But seems I'm wrong ;)
  8. volc
    volc New Member
    Nov 27, 2014
    Anyone got the analog output running? Seems that the Procto Openelec supported this very well, did you get those drivers Vpeter?
  9. vpeter
    Nov 29, 2014
    303
    62
    Just today the kernel sources were updated and now everything is there. Just need to port this driver to our kernel. Will continue work in next days.
    I though I will continue this evening but instead I'm helping my friend to make EoIP tuner to work on Mikrotik router. But of course because I newer did such thing it doesn't go according to plan.
  10. volc
    volc New Member
    Nov 27, 2014
    Okay sounds awesome! Good luck with EoIP :)
  11. vpeter
    Nov 29, 2014
    303
    62
    Can you tell me exactly what you did so I can investigate little more? I assume that Arduino starts as soon power is applied to a board and doesn't reset and then must be powered again from userspace?
    Currently I'm working on a analog output and would like to fix two things at a time ;)
    Update: doesn't look good :( I really need some help on this...
  12. idorel77
    idorel77 Member
    Jul 25, 2014
    131
    ''Currently I'm working on a analog output and would like to fix two things at a time ;)''
    Good news :)
  13. vpeter
    Nov 29, 2014
    303
    62
    Sadly there will be no analog sound output with openelec. I'm trying to port the vt1613 driver from 3.10.9 to 3.14.xy kernel unsuccessfully. So I tried original udoo kernel with openelec and on my surprise analog output didn't work. That's why I'm not working on this thing anymore. Maybe one day someone will pick this again. On newer kernel...
  14. Shevonar
    Shevonar New Member
    Jan 10, 2015
    What solved the problem for me in the end is basically this
    --- a/arch/arm/mach-imx/gpc.c	2014-11-02 14:07:57.000000000 +0100
    +++ b/arch/arm/mach-imx/gpc.c	2015-01-11 18:15:51.884614624 +0100
    @@ -390,7 +390,7 @@
     static const struct of_device_id imx_pudummy_ids[] = {
     	{ .compatible = "fsl,imx6-dummy-pureg" },
    -MODULE_DEVICE_TABLE(of, imx_pudummy_ids);
    +//MODULE_DEVICE_TABLE(of, imx_pudummy_ids);
     static struct platform_driver pu_dummy_driver = {
     	.probe	= pu_dummy_probe,
    @@ -467,7 +467,7 @@
     module_platform_driver(imx_gpc_platdrv);
    -module_platform_driver(pu_dummy_driver);
    +//module_platform_driver(pu_dummy_driver);
     MODULE_AUTHOR("Anson Huang <b20788@freescale.com>");
     MODULE_DESCRIPTION("Freescale i.MX GPC driver");
    This is surely not a proper fix. The problem is that this driver is setting GPIO pin 0 to high which is the arduino reset line and makes the arduino stop.
  15. volc
    volc New Member
    Nov 27, 2014
    Thats too bad! I'll keep waiting ;) thanks for tour effort!
  16. salouma
    salouma Member
    Jan 24, 2014
    49
    Hi Vpeter,
    I'm using your OpenElec image for weeks now. This is really a stable image, i'm really pleased with it.
    What is the future of your image ? Is it going to reach an official release ?
    To me the image is perfect, don't get any bug. Now it would be nice to have sort of an "official support" with updated image a each OpenElec version.
    I hope that the Udoo Team will put this image in the official distribution of UDOO, many user have been waiting for a stable image of Kodi and now it is here, it is a big achievement.
    Thank you so much
  17. vpeter
    Nov 29, 2014
    303
    62
    Just today I ask on github the last time if this will be merged or not. In any way I will continue working on it. But it will take more time for new images (like with 5.0.1 and 5.0.2 which I didn't build yet).
    Update: seems there is no interest in imx6 support for openelec according to github silence.
  18. vpeter
    Nov 29, 2014
    303
    62
    Shevonar, I finaly touch the problem with resetting arduino. Instead of your patch I created another regulator in device tree imx6q-udoo.dts
    		reg_sam3x_reset_disable: sam3x_reset_disable {
    			compatible = "regulator-fixed";
    			regulator-name = "sam3x_reset_disable";
    			gpio = <&gpio1 0 0>;
    			enable-active-low;
    which drives reset pin. With this arduino is not reseted when imx6 kernel starts or system reboots.
    But there is one small side effect: I don't know how to manually drives this gpio pin to reset arduino. Don't know if this is even needed. What do you think - I'm not familiar with arduino part? Also it doesn't stop when imx6 kernel stops. With your patch it restarts - so still runs after system is halted.
  19. Pikmin
    Pikmin New Member
    Jan 25, 2015
    When it works, it works great. But I'm having issues with the WiFi. Sometimes it doesn't connect, just keeps failing :/
    I had the same problem with the official distro of Linux last time I had it installed
    EDIT: It appears I have the quad not dual, so my mistake!
  20. sirrab
    sirrab UDOOer
    Jul 26, 2014
    263
    32
    I recently installed an external antenae for Wi-Fi, because getting onto the Internet was slow/drops/no connect. And the antenae makes a huge difference. Connects easily and stays connected. Very happy!
