Hi guys, I'm trying to load udoobuntu 12.04 version 2.1 with NFS support through nfs. I've configured correctly nfs server. I can confirm it because I can mount an exported directory through network. My question is the following: how can I run udoobuntu 12.04 through nfs? I untar the file system on the following directory /home/zamu/qt5_build/rootf and put /home/zamu/ on /etc/exports for NFS service. Then I stop the boot of Udoo and set the environment with the next two commands Code: setenv bootargs 'console=ttymxc1,115200 root=/dev/nfs rw nfsroot=192.168.0.113:/home/zamu/qt5_build/rootfs,v3,tcp ip=dhcp video=mxcfb0:dev=ldb,LDB-WVGA,if=RGB666,bpp=32' setenv bootcmd 'tftpboot 0x12000000 192.168.0.113:/srv/tftpboot/uImage ; bootm' saveenv After that I reboot UDoo and it starts but stops to load with the following dmesg Code: [ 7.677905] PHY: 1:06 - Link is Up - 1000/Full [ 63.437926] phy0 -> rt2x00lib_request_firmware: Error - Failed to request Firmware. [ 63.445605] IP-Config: Failed to open wlan0 [ 63.467544] Sending DHCP requests ., OK [ 63.607566] IP-Config: Got DHCP answer from 0.0.0.0, my address is 192.168.0.163 [ 63.617663] IP-Config: Complete: [ 63.620910] device=eth0, addr=192.168.0.163, mask=255.255.255.0, gw=192.168.0.254, [ 63.628752] host=192.168.0.163, domain=ecs.local, nis-domain=(none), [ 63.635566] bootserver=0.0.0.0, rootserver=192.168.0.113, rootpath= [ 63.673108] VFS: Mounted root (nfs filesystem) on device 0:13. [ 63.680261] devtmpfs: mounted [ 63.683408] Freeing init memory: 200K [ 64.414154] init: mounted-tmp main process (1615) terminated with status 1 On the server if I check syslog I've the following message Code: rpc.mountd[1142]: authenticated mount request from 192.168.0.163:791 for /home/zamu/qt5_build/rootfs (/home/zamu) that seems to be good because the same message is showed when I try to mount a directory through nfs. How can I solve this problem? Many thanks in advanced Zamu
