Node.js not working in Linaro Ubuntu 12.04 LTS
Discussion in 'Linux Ubuntu' started by timbergus, Jan 27, 2014.
  1. timbergus
    timbergus New Member
    Jan 27, 2014
    Hi all,
    I am a JavaScripter that works with Node.js and Johnny-Five library to create servers to control hardware remotely, and when I installed Node.js in my Udoo Quad with Ubuntu 12.04 LTS, I did not be able to make it work. When I try to use the node console, it freezes and the same happens with npm. I have installed everything as usual, and I even reinstalled the operative system, but it does not work. The weird thing is that I have tried the same in the beta of Debian, and all worked like a charm. Do you know any solutions to fix Node.js in Linaro Ubuntu 12.04 LTS?
    Installation process:
    wget http://nodejs.org/dist/v0.10.25/node-v0.10.25.tar.gz
    tar -zxvf node-v0.10.25.tar.gz
    cd node-v0.10.25
    ./configure --without-snapshot
    make
    sudo make install
    cd ..
    rm node-v0.10.25.tar.gz
    rm -r node-v0.10.25
  2. rootScript
    rootScript Member
    Jan 11, 2014
    44
  3. timbergus
    Jan 27, 2014
    I have tried what is in that thread only with Node.js 0.10.25, but still not working. I will try to obtain an older version, but I'm not sure if it will work. I think the problem could be in missing libraries, but I can't find which one are missing. Libraries that are installed in Debian but not in Ubuntu.
  4. Capstan
    Capstan New Member
    Feb 14, 2014
    18
    Did you manage to get node.js going? I did, what you want is pilwon's nodejs-for-linaro-ubuntu-master.zip available on github. No compile required, unzip it to get the binaries and you should be in business.
  5. aterocana
    aterocana New Member
    Mar 1, 2014
    Same problem. I had to compile v0.10.22, it seems it's last one working with Ubuntu LTS 12.04. :(
  6. TomFreudenberg
    TomFreudenberg Member
    May 12, 2014
    56
    Hopefully this message is still interesting for you:
    It is a problem based on the standard gcc 4.x which is installed on the lubuntu image by default.
    Please check out my guide to get an up-to-date nodejs running on your systems:
    http://meteor-universal.tumblr.com/post ... untu-12-04
    Tom
