OpenEmbedded/Yocto for UDOO Boards
Discussion in 'Yocto' started by graugans, Nov 7, 2015.
  1. graugans
    Sep 17, 2015
    328
    141
    OpenEmbedded/Yocto support for the UDOO Boards
    In the following description I do use Yocto as reference but the same concepts should apply to the pure OpenEmbedded layers. The provided meta-udoo layer depends on the Freescale arm layer For an easy start I do provide a patched version of fsl-community-bsp-platform this repo manifests is for cloning all needed layers.
    The Yocto project organizes its releases in different branches. Each branch is related to a Release version. The ongoing development takes place in the master branch. It is recommended that every layer which stacks on top of this should follow this convention. Thus I decided to provide support for the latest release of Yocto "jethro"
    Recommendation for the build host
    The OpenEmbedded buildsystem builds everything from source. So it is recommended to have at least 50GB of free disk space. Better is 100GB. The recommended Distribution to build on is the latest Ubuntu LTS Release for jethro this is Ubuntu 14.04.
    When it comes to CPU power of the buildhost more is always better. I do my builds on a quadcore intel i5 with 3.2GHz. The less CPU cores the more time it will last.
    My experience is when it comes to RAM you should not go below 8GB.
    For faster builds a SSD is recommended but this may stresses your SSD.
    Build the BSP
    You`ll find the complete build instructions on the meta-udoo github wiki page
    Burning the image to the SD-Card
    Please double check the device of your SD-Card. This can corrupt your installation
    I do the following on my Linux box
    $ umount /dev/sdd?
    $ zcat tmp/deploy/images/udooneo/udoo-image-full-cmdline-udooneo.sdcard.gz | sudo dd of=/dev/sdd bs=16M
    Qt5
    If you are interested in Qt5 support for your image it is recommended to read Qt for Embedded Linux first. I have tested Qt5 support on both the Neo and the Quad/Dual family without X11 and EGLFS support. This tutorial is based on the Qt5 on wandboard tutorial
    1. Clone the meta-qt5 layer into your source dir
      $ cd ${BSPDIR}/sources/
      $ git clone -b jethro https://github.com/meta-qt5/meta-qt5.git
    2. Prepare your build environment
      $ source ./setup-environment build
    3. Add the Qt5 Layer to your con/bblayers.conf file
      ${BSPDIR}/sources/meta-qt5 \
      ${BSPDIR}/sources/meta-openembedded/meta-ruby \
    4. Modify the conf/local.conf for EGLFS accelerated Framebuffer only
      DISTRO_FEATURES_remove = "x11 wayland"
    5. Build the Qt5 image
      $ MACHINE=udooneo bitbake udoo-image-full-cmdline
    Cross compile a Qt5 SDK to use in QtCreator
    The recommended way to build a fully featured toolchain for your image is to use the populate_sdk target for building a toolchain installer
    $ MACHINE=udooneo bitbake udoo-image-qt5 -c populate_sdk
    Grab a good book and wait until the task is finished.... After the builds has finished you can install the toolchain like this:
    $ sudo tmp/deploy/sdk/poky-glibc-x86_64-udoo-image-qt5-cortexa9hf-vfp-neon-toolchain-2.0.sh
    [sudo] password for chris:
    Poky (Yocto Project Reference Distro) SDK installer version 2.0
    Enter target directory for SDK (default: /opt/poky/2.0):
    You are about to install the SDK to "/opt/poky/2.0". Proceed[Y/n]?
    Extracting SDK....................................................................................................................................................done
    Setting it up...done
    SDK has been successfully set up and is ready to be used.
    Each time you wish to use the SDK in a new shell session, you need to source the environment setup script e.g.
    $ . /opt/poky/2.0/environment-setup-cortexa9hf-vfp-neon-poky-linux-gnueabi
    QtCreator set-up
    Run qtcreator from the terminal after running the setup environment script
    $ source /opt/poky/2.0/environment-setup-cortexa9hf-vfp-neon-poky-linux-gnueabi
    $ qtcreator
    • In the QtCreator go to Tools > Options > Devices and add your UDOOBoard as a generic linux device.
      Screenshot from 2016-01-24 21:15:27.png
    • go to Tools > Options > Build & Run
    1. Add a new compiler. Select your poky compiler: /opt/poky/2.0/sysroots/x86_64-pokysdk-linux/usr/bin/arm-poky-linux-gnueabi/arm-poky-linux-gnueabi-g++
      Screenshot from 2016-01-24 21:17:27.png
    2. Add your new cross compiled Qt version by selecting the qmake located in /opt/poky/2.0/sysroots/x86_64-pokysdk-linux/usr/bin/qt5/
      Screenshot from 2016-01-24 21:18:08.png
    3. Add a new kit selecting your new Qt5 version and compiler and setting the sysroot to /opt/poky/2.0/sysroots/cortexa9hf-vfp-neon-poky-linux-gnueabi/ and leave the Qt mkspec empty. Finally select your UDOOBoaard for the device.
      Screenshot from 2016-01-24 21:19:03.png
    !!! ATTENTION !!!
    To have a fully working UDOO board you have to use udoo-image-full-cmdline instead of core-image-full-commandline. Because core-image-full-commandline lacks packagegroup-base which uses MACHINE_EXTRA_RRECOMMENDS I know this is a bit disapointing because the name core-image-full-commandline implies it is fully bloated command line image. To get more details on this I suggest to read the Yocto Reference Manual ​
    takeshi6, secuflag and modjo like this.
  2. graugans
    Sep 17, 2015
    328
    141
    [UDOO Neo] Uploading Arduino Sketches
    Please read this Posting how to upload Arduino Sketches to the Cortex M4 on the UDOO Neo Board when running a Yocto Image.
    WiFi on UDOO Neo/Quad/Dual
    Ensure your image support Wifi and all drivers are loaded
    root@udooqdl:~# ifconfig wlan0 up
    root@udooqdl:~# iw wlan0 scan
            TSF: 2455654730245 usec (28d, 10:07:34)
            freq: 2452
            beacon interval: 100 TUs
            capability: ESS Privacy ShortPreamble ShortSlotTime (0x0431)
            signal: -41.00 dBm
            last seen: 160 ms ago
            Information elements from Probe Response frame:
            SSID:  TOP-SECRET
            Supported rates: 1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0
            DS Parameter set: channel 9
            Country: DE     Environment: Indoor/Outdoor
                    Channels [1 - 13] @ 20 dBm
            ERP: <no flags>
            RSN:     * Version: 1
                     * Group cipher: TKIP
                     * Pairwise ciphers: CCMP
                     * Authentication suites: PSK
                     * Capabilities: 1-PTKSA-RC 1-GTKSA-RC (0x0000)
            Extended supported rates: 24.0 36.0 48.0 54.0
            HT capabilities:
                    Capabilities: 0x18e
                            HT20/HT40
                            SM Power Save disabled
                            TX STBC
                            RX STBC 1-stream
                            Max AMSDU length: 3839 bytes
                            No DSSS/CCK HT40
                    Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
                    Minimum RX AMPDU time spacing: 8 usec (0x06)
                    HT RX MCS rate indexes supported: 0-15
                    HT TX MCS rate indexes are undefined
            HT operation:
                     * primary channel: 9
                     * secondary channel offset: below
                     * STA channel width: any
                     * RIFS: 0
                     * HT protection: non-HT mixed
                     * non-GF present: 0
                     * OBSS non-GF present: 1
                     * dual beacon: 0
                     * dual CTS protection: 0
                     * STBC beacon: 0
                     * L-SIG TXOP Prot: 0
                     * PCO active: 0
                     * PCO phase: 0
            WPA:     * Version: 1
                     * Pairwise ciphers: TKIP
            WMM:     * Parameter version 1
                     * BE: CW 15-1023, AIFSN 3
                     * BK: CW 15-1023, AIFSN 7
                     * VI: CW 7-15, AIFSN 2, TXOP 3008 usec
                     * VO: CW 3-7, AIFSN 2, TXOP 1504 usec
    Okay lets assume we want to connect to the network TOP-SECRET we have to change two files
    root@udooqdl:~# vi /etc/network/interfaces
    Change the WLAN block to this:
    # Wireless interfaces
    iface wlan0 inet dhcp
            wireless_mode managed
            wireless_essid any
            wpa-driver nl80211
            wpa-conf /etc/wpa_supplicant.conf
    The important part is the line
            wpa-driver nl80211
    After this we have to change the wpa_supplicant config
    root@udooqdl:~# vi /etc/wpa_supplicant.conf
    To something like this
    ctrl_interface=/var/run/wpa_supplicant
    ctrl_interface_group=0
    update_config=1
    network={
            ssid="TOP-SECRET"
            scan_ssid=1
            proto=WPA
            key_mgmt=WPA-PSK
            pairwise=TKIP
            group=TKIP
            psk="<Insert your top secret key here>"
    For more details about wpa_supplicant.conf please check for example the wpa_supplicant manpage
    Now we can test if everything works fine:
    root@udooqdl:~# ifdown wlan0
    [ 2156.644323] wlan0: deauthenticating from 9c:c7:a6:16:XX:XX by local choice (reason=3)
    [ 2156.709390] cfg80211: Calling CRDA for country: DE
    root@udooqdl:~# ifup wlan0
    Successfully initialized wpa_supplicant
    rfkill: Cannot open RFKILL control device
    [ 2165.144654] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
    udhcpc (v1.23.2) started
    Sending discover...
    [ 2166.697130] wlan0: authenticate with 9c:c7:a6:16:XX:XX
    [ 2166.792515] wlan0: send auth to 9c:c7:a6:16:XX:XX (try 1/3)
    [ 2166.800814] wlan0: authenticated
    [ 2166.804607] rt2800usb 1-1.3:1.0 wlan0: disabling HT/VHT due to WEP/TKIP use
    [ 2166.813078] wlan0: associate with 9c:c7:a6:16:XX:XX (try 1/3)
    [ 2166.826939] wlan0: RX AssocResp from 9c:c7:a6:16:XX:XX (capab=0x431 status=0 aid=1)
    [ 2166.848286] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
    [ 2166.854771] wlan0: associated
    Sending discover...
    Sending select for 192.168.23.159...
    Lease of 192.168.23.159 obtained, lease time 864000
    RTNETLINK answers: File exists
    /etc/udhcpc.d/50default: Adding DNS 192.168.23.1
    oxoocoffee and modjo like this.
  3. Andrea Rovai
    Great! If you provide us a working image we'll send you a Quad too, so you can work also on the Quad.
    If you like, obviously :)
  4. graugans
    Sep 17, 2015
    328
    141
    Cool, so I can send a working image for Neo. The quad will follow when I have the board :). BTW the quad is what I am used to. Because at ifm we use it for our O3D300 industrial 3D camera.
    Gesendet von meinem Nexus 4 mit Tapatalk
  5. Andrea Rovai
    So you can just post the image here! Otherwise, my email is andrea DOT rovai AT udoo DOT org
    graugans likes this.
  6. graugans
    Sep 17, 2015
    328
    141
    Here we go....
    Yocto image for UDOO NEO - 20151109191206
    The image is zipped and it is a full SD-CARD image. So it should be possible to use a approach like you describe in your getting started tutorial. On Ubuntu I put it on SD-Card this way:
    ATTENION please check the path of your SD-CARD Writer first!!! Otherwise you may damage your harddrive....
    umount /dev/sde? && zcat core-image-full-cmdline-udooneo-20151109191206.rootfs.sdcard.gz | sudo dd of=/dev/sde bs=32M
    After inserting the SD-CARD into your NEO you can either connect a 3.3V USB <-> serial converter to your NEO board or use the USB-Serial port ( /dev/ttyACM0 ) spawned by the UDOO Neo. I've written a complete Howto on on my Blog some time ago.
    On the login prompt just type root for the username and no password.
    For the Bluetooth part you have to call the following command:
    root@udooneo:~# hciconfig hci0 up
    hci0:  Type: BR/EDR  Bus: UART
      BD Address: 74:DA:EA:C7:19:B4  ACL MTU: 1021:6  SCO MTU: 180:4
      UP RUNNING
      RX bytes:1176 acl:0 sco:0 events:62 errors:0
      TX bytes:804 acl:0 sco:0 commands:62 errors:0
    If you want to scan for Bluetooth Low Energy devices for example you can do this like this:
    root@udooneo:~# hcitool lescan
    LE Scan ...
    68:C9:0B:06:EF:CC (unknown)
    68:C9:0B:06:EF:CC CC2650 SensorTag
    A4:77:33:A6:FF:D5(unknown)
    A4:77:33:A6:4D:D1 (unknown)
    root@udooneo:~# hcitool leinfo 68:C9:0B:06:EF:CC
    Requesting information ...
      Handle: 1025 (0x0401)
      LMP Version: 4.1 (0x7) LMP Subversion: 0x200
      Manufacturer: Texas Instruments Inc. (13)
      Features: 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    For the WiFi part I tried a simple scan
    root@udooneo:~# ifconfig wlan0 up
    root@udooneo:~# iw wlan0 scan
    BSS 5c:49:79:21:31:75(on wlan0)
      TSF: 2075562266 usec (0d, 00:34:35)
      freq: 2412
      signal: -67.00 dBm
      last seen: 410 ms ago
      SSID: XXXX
      DS Parameter set: channel 1
      ERP: <no flags>
  7. graugans
    Sep 17, 2015
    328
    141
    I am facing some trouble with the out of tree kernel builds Yocto is doing. So my announcement having something GUI based by the end of this week is not possible.
    At the moment it looks like the backported drivers cause the Kbuild system to an endless loop when running building out of tree.
    For my console based build I mad a hack and build the kernel in tree. But Yocto builds the Vivante Driver from a separate repo. And this is broken.
    Maybe I can skip the seperate build of Vivante Driver or I can fix the endless loop.
    If there is kconfig superhero around please give me some hints.
  8. graugans
    Sep 17, 2015
    328
    141
    I did some investigations and have an idea about how to fix the endless loop. But meanwhile I found a hack to use the vivante driver included in the UDOO Neo kernel sources. This is okay for now but maybe an issue when Yocto uses a newer or older version of the vivante userland.
    Anyway here is a youtube video where you can see UDOO Neo booting into the graphical Sato image based on a yocto master from end of November.
    If you want to test the image yourself you can download it here
  9. graugans
    Sep 17, 2015
    328
    141
    Next step will be UDOO Quad/Dual support. And after this u-boot 2015 :)
  10. Francesco
    Francesco Active Member
    Jun 23, 2015
    220
    110
    Hi graugans,
    which kernel are you using? If you use this you will get Neo and Quad/Dual support out of the box.
    If you want to use u-boot 2015 (that we will use in the next UDOObuntu releases):
    - 2015.10+fslc is u-boot for Quad/Dual and has SPL support
    - 2015.10+fslc_NEO has Neo support and SPL support
    This may help you on building SPL u-boot and flash it in the right places on the sdcard.
  11. graugans
    Sep 17, 2015
    328
    141
    Thank you Francesco,
    yesterday in the evening I managed to run the 2015.10+fslc on the UDOO Quad/Dual. It is really cool to swap one SD-Card between both boards and it is booting smoothly. For the kernel I have to switch to master soon. At the moment I am using the two branches one for the Neo and the other one for the Quad/Dual.
    My suggestion for the naming of the Quad/dual board in Yocto is
    • udooqdl
    Or are there any other suggestions? The name of the UDOO Neo is pretty simple
    • udooneo
    After cleaning stuff up and getting SPL support for the Neo up and running I have to figure out how to support that splash screen stuff.
  12. Francesco
    Jun 23, 2015
    220
    110
    The name "udooqdl" is acceptable as it is an internal name. A user visible name should otherwise always be "UDOO Quad/Dual".
    What do you refer to with "splash screen"? You mean u-boot splash screen? In that case please note that:
    - on UDOO Quad/Dual it is already in the 2015.10 branch (as you already noticed)
    - on UDOO Neo it is missing (HDMI init code for u-boot is on master only and not in 2015.04; LVDS support should be checked too).
    graugans and modjo like this.
  13. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Hi graugans ! Congratulation for your job ! Do you plan to make a yocto image with qt5 layer ? Otherwise, do you plan to make a tutorial to buid a yocto image (git repository with udoo layers) ?
  14. graugans
    Sep 17, 2015
    328
    141
    Hi @modjo ,
    sorry for the late reply. I alread wrote a response but this was eaten by taptalk .... Anyway, I plan to write some tutorial. but had not found time to do so :). The qt5 thingy should be pretty straight forward with meta-qt5 In case of any questions pleas do not hesitate to ask.
    modjo likes this.
  15. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Hi graugans, i'm very insterested by your work ! Currently i'm building a yocto image with qt5.3 for my seco A62 (seco give a guideline to do that). if i understand, your layer work on udoo quad and neo with the same build ? On neo, do you have the accelerometer, gyro ... working ? I suppose you have the A9 gpio working (by linux) but for the commnucation with the M4 copro, do you have the time to test that ? If you would, i can test to build an image with your layer and let you know if it's working ? Just said me the bbconf (machine) you use and if the have some particulars instructions ...
  16. graugans
    Sep 17, 2015
    328
    141
    The new layer https://github.com/graugans/meta-udoo have two machine configurations one udooqdl for quad and dual version of the UDOO Board and the udooneo configuration. By selecting udooqdl you can build an image which runs on quad and dual. But this image is not compatible with the UDOO Neo.
    I'll write some documentation about setup and tuning the layers.
  17. graugans
    Sep 17, 2015
    328
    141
    I've updated to top-level post which now addresses the new meta-udoo layer. This is not yet finished yet and needs some polishing but could be a starter...
    Andrea Rovai and modjo like this.
  18. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Big thank's for your job ;)
    Andrea Rovai and graugans like this.
  19. modjo
    modjo Active Member
    Sep 29, 2014
    417
    127
    Hi graugans, i have init my repo, download the bsp and setup the environement. Now i'm on your step "Fixing layers". You said to modify build/conf/local.conf. Do it need to erase the original file and replace it by the line you gives or append it ? I try with the second option and obtain this errors :
    osboxes@osboxes:~/udoo-community-bsp/build$ MACHINE=udooneo bitbake udoo-image-full-cmdline
    ERROR: Unable to parse /home/osboxes/udoo-community-bsp/sources/poky/bitbake/lib/bb/parse/parse_py/ConfHandler.py
    Traceback (most recent call last):
      File "/home/osboxes/udoo-community-bsp/sources/poky/bitbake/lib/bb/parse/parse_py/ConfHandler.py", line 188, in feeder(lineno=24, s='--- fsl-udoo-community-bsp.orig/build/conf/bblayers.conf', fn='/home/osboxes/udoo-community-bsp/build/conf/local.conf', statements=[<bb.parse.ast.DataNode object at 0x1312ad0>, <bb.parse.ast.DataNode object at 0x1312b10>, <bb.parse.ast.DataNode object at 0x1312b50>, <bb.parse.ast.DataNode object at 0x1312bd0>, <bb.parse.ast.DataNode object at 0x1312c50>, <bb.parse.ast.DataNode object at 0x1312c90>, <bb.parse.ast.DataNode object at 0x1312cd0>, <bb.parse.ast.DataNode object at 0x1312d10>, <bb.parse.ast.DataNode object at 0x1312d50>, <bb.parse.ast.DataNode object at 0x1312d90>, <bb.parse.ast.DataNode object at 0x1312dd0>, <bb.parse.ast.DataNode object at 0x1312e50>, <bb.parse.ast.DataNode object at 0x1312e90>]):
      >  raise ParseError("unparsed line: '%s'" % s, fn, lineno);
    ParseError: ParseError at /home/osboxes/udoo-community-bsp/build/conf/local.conf:24: unparsed line: '--- fsl-udoo-community-bsp.orig/build/conf/bblayers.conf'
    Could you help please ?
  20. graugans
    Sep 17, 2015
    328
    141
    Sorry this is a typo in my tutorial. For the layers it is conf/bblayers.conf I'll fix it when I have access to a PC.
