OS X - Serial Tools - SLAB_USBtoUART not in list . . .
Discussion in 'Troubleshooting' started by Simsy, Jan 12, 2015.
  1. Simsy
    Simsy New Member
    Jan 12, 2015
    Hello All,
    I'm trying get the serial debug working with a Macbook Pro running 10.9.5 and UDOO Quad following these instructions:
    http://www.udoo.org/ProjectsAndTutorial ... ial-cable/
    I've install serial tools and then SLAB_USBtoUART driver "Silicon Labs VCP Driver Installer".
    With UDOO running and connect to laptop using USB cable into CN3 with J18 jumper in place I get this list of serial ports . . .
    Manual implies that "SLAB_USBtoUART" should appear in the list but it doesn't . . .
    If I go ls /dev/ in terminal is also doesn't appear . . .
    Any thought / ideas ?
  2. delba
    1,064
  3. Simsy
    Simsy New Member
    Jan 12, 2015
    Hi delba,
    I've installed CoolTeam but it's no different to other program, 'SLAB_USBtoUART' doesn't appear in list.
    To prove the software worked I program a separate Arduino to reply with what it receives via serial and provide this worked using the Arduino Serial monitor. I then Tried to use Cool Term to open serial interface with Arduino using below setting:
    I got the following Error Message:
  4. Simsy
    Simsy New Member
    Jan 12, 2015
    I also noticed that when I connect UDOO to my Mac with USB cable the following appears in system preferences
    This would imply that UDOO's USB interface is working on some level . . . but either is in the wrong mode or drivers aren't installed properly . . .
    Surely 'SLAB_USBtoUART' need to appear if you type 'ls /dev/' into terminal before it appears in Cool Term ?
