How does the Ryzen Embedded V1000 SoC compare to the regular desktop versions 2200G and 2400G with build-in Vega GPU? Maybe there are any benchmarks that compare the two platforms?
i expect the cpu part (based on clockspeeds only) to be around 60-70% of a 2200g depending on how long and how often it can boost the vega gpu will hopefully be around 80-90% that of a 2200g with same RAM speed (2400mhz), but please remember that the desktop part uses lots more power, and supports faster RAM (so better gpu performance when set up properly) this system is built for a good balance of power/performance.
can't find a way to edit my post, i forgot to calculate in the multithreading, i went for a 4 thread calculation for both the 2200g and bolt v8, however, the bolt v8 has 8 threads, meaning more multicore speed, but the singlecore won't be as fast though.
glmark2 benchmarks: 3514 (3400G @ ASRock DeskMini A300, 65 W) 3200 (Udoo BOLT v3, 25 W) 2237 (Udoo BOLT v3, 15 W)
