Plywood case by lasercutting
Discussion in 'Cases' started by killor, Jun 16, 2014.
  1. killor
    killor New Member
    Jun 16, 2014
    Hi everyone,
    I'm from Spain ( and sorry my level of english is bad )..
    I'm trying to design a enclosure for the UDOO board, made in birch plywood .
    (I prefer to use wood that is a recyclable material, that using ABS plastic having bisphenol A, etc.. ) :!:
    I have made and sell many cases for the Raspberry Pi computer and now I want to also be done UDOO board.
    I made this based on published measures..
    The top can be opened for access inside.
    I have not UDOO computer, :( so, if someone wants a enclosure , I need to provide some measure to adjust the enclosure to your needs. (If you use CAD software would be great! but also a sketch in PDF is fine.)
    Currently, I sell cases for Raspberry Pi in AMAZON and eBay sites..
    We ship from Spain by registered mail to worldwide.
    If anyone is interested you can send a message ..
    Thanks!!!
    PD: I use a CO2 laser, and can only cut organic materials.
    I CAN NOT CUT METALS :cry:
  2. bynarie
    bynarie New Member
    Jun 9, 2014
    Thats pretty good looking man. I like it. Prolly need a way to access all the headers and whatnot but thats easy... I like it
  3. delba
    1,064
    That's a nice wood case. Love it!!! +1 for the access to the headers
  4. killor
    killor New Member
    Jun 16, 2014
    Hi , Delba !
    If you have a UDOO board ,
    Can you post some measures to verify that I have ?
    The DXF file board size I have is 110mm x 86,5mm.
    The holes diameter is 3,17mm.
    The hole distance to the border is 2mm.
    What is the rectangle conector power mesure?
    What is the maximum height above the board?
    Once I check the measurements, I can make a enclosure for you.
    Thank you very much,
  5. delba
    1,064
    killor i confirm your measures and:
    - the power connector rectangle: 11mm H x 9mm W
    - the max height of the board: 18,5mm
    looking forward for your news, thanks.
  6. killor
    killor New Member
    Jun 16, 2014
    Thank you very much, Delba !!
    I'll edit some measures of the enclosure.
  7. Maxr96
    Maxr96 New Member
    Jul 4, 2014
    This wood case is amazing, good job.
  8. killor
    killor New Member
    Jun 16, 2014
    Someone has information dimensions of UDOO X86 Beta board version...?
    Thank's.
  9. delba
    1,064
    There you go: 4.72 inches (12cm) x 3.35 inches (8.5cm)
    Cheers
