The website has broken links on the udoo vision. I also have some issue with the vision board not posting even to the bios. The orange blinks once and green light blinks quickly 2 times then it repeats after a few seconds. I am using a universal power supply for the board with 12v 3a output. I tried 2 different keyboards to make sure that it wasn't a keyboard issue both of which showed no signs of life with num lock and caps lock and no display even when hitting escape. I also tried 2 different wall outlets. I read some of the documentation for it, but it just says that it is communicating. When I try to search for anything else udoo bolt is recommended and it claims there is a power button. Is there a hidden power button for the udoo vision/do I need to jump it somehow? Any help would be appreciated if anyone else fixed this issue or experienced it.
New power adapter arrived today and it works! 1 amber and 2 green flashes are due to not enough power. 12w 5a is what should be used 3 amps is not enough.
