I'm looking forward to preorder an Udoo x86 but i need to know how much power it is going to drain in certain circumstances (in watts): - Power consumption in idle - Average power consumption - Power consumption on max load
I'd be also interested to know that. Presumably guys have already some prototypes ready, maybe they can share some measurements?
Hi there @nikodll, Power consumption in idle is 3W. Maximum power consumption is 36 W with stuff attached (since the board should be powered with a 12V3A power supply). Average power consumption is 11 W.
I can verify Andrea's specifications as I measured power last evening : - Loading browser, surfing internet, Windows 10 PRO, with USB wireless adapter, HDMI video cable, Ethernet cable, and remote SSD is 7.0 W to 9.99 W (12.5 VDC, 0.799 A ). - Idle desktop Windows 10 PRO, with USB wireless adapter, HDMI video cable, and remote SSD is 5.08 W (12.5 VDC, 0.406 A) - Sleep mode, with USB wireless adapter, HDMI video cable, and remote SSD is 863mW (12.5 VDC, 0.069 A)
These 36 W are measured when the arduino 101 is also running at its maximum ? Because I would like to know if both processors are under stress test how much it would drain. According to the datasheet under stress test it drains only 1008 mA.
We recommend a power supply capable of supplying 3A, to cover scenarios where a user connects peripherals that draw power, for example, SATA hard drives. The power consumption of the Intel Curie can be viewed in the Intel datasheet, page 53: https://www.intel.com/content/dam/s.../curie/Intel_Curie_Module_Datasheet_V1.21.pdf
Power consumption of the various models can be found in the Hardware and UEFI User Manual that you can download from here: https://www.udoo.org/docs-x86/Hardware_Reference/Resources.html
thx I found them here are the figures in W: Code: Inrush current at boot : 11.04 8.98 6.50 Idle, power saving configuration : 3.68 3.17 3.77 OS Boot, power saving configuration : 5.45 4.10 3.79 Video reproduction@720p, power saving configuration : 4.46 4.31 4.03 Video reproduction@1080p, power saving configuration : 5.84 5.04 4.02 Internal Stress Test Tool, maximum performance : 12.10 12.24 10.87
