Hello all, My problem is that trying to connect the LCD touchscreen UDOO seems to refuse to start, however, the power LED is on. Another problem is related to the camera, I tried to disable and enable the camera module and connecting the chamber UDOO launching from the terminal command: Code: gst-launch-0.10 mfw_v4lsrc ! ffmpegcolorspace ! ximagesink it shows me an error message
Hi there GGarreffa, and welcome to this forum! Regarding the LCD touchscreen my question is: where did you buy your touchscreen? By default UDOO is compatible just with UDOO touchscreens. Otherwise you should recompile the Kernel and write the drivers. Regarding the camera, could you report the error?
I have a problem with camera. I try to connect but I have an error. After gst-launch-0.10 mfw_v4lsrc ! ffmpegcolorspace ! ximagesink ERROR appear "Setting pipeline to PAUSED... ERROR: Pipeline doesn't want to pause Setting pipeline to NULL... Freeing pipeline..."
