I have some questions about the script in qt5-layer in meta-udoo. In fact, they have a qt5-env.bb that make some tests to write or not some export QT var on qt5-env.sh (if i'm not wrong ) . I'm not sure that is working because if i define a LVDS7 in my local.conf i'm not sure that it modify the file qt5-env.sh ? For example, i have found to build qt5.7 it's needed to add fonts in yocto image. At first i have make a recipe that overlay the layer "dejavu" but i don't need to do that ! Just need to export this : export QT_QPA_FONTDIR=/usr/share/fonts/truetype/ To enable this on the card i add it on the qt5-env.sh (+ another var env) : #export platforms export QT_QPA_PLATFORM=eglfs #with the new version of QT5.7, we need to re-define the path to the #font (no more delivred with this version) export QT_QPA_FONTDIR=/usr/share/fonts/truetype/ #export size of lvds7 in milimeters export QT_QPA_EGLFS_PHYSICAL_HEIGHT=91 export QT_QPA_EGLFS_PHYSICAL_WIDTH=152 #export touchscreen event export QT_QPA_EVDEV_TOUCHSCREEN_PARAMETERS=/dev/input/event1:inverty It work fine on the card, but how we can add this to qt5-env.bb to have a working bb (that we can configure from local.conf)?
You're right. Personally, I edited this file to add the right variables. Code: SUMMARY = "Add Qt5 bin dir to PATH" LICENSE = "GPL-2.0" LIC_FILES_CHKSUM = "file://${COMMON_LICENSE_DIR}/GPL-2.0;md5=801f80980d171dd6425610833a22dbe6" SRC_URI = "file://qt5-env.sh" S = "${WORKDIR}" HAS_X11 = "${@base_contains('DISTRO_FEATURES', 'x11', 1, 0, d)}" HAS_LVDS7 = "${@base_contains('VIDEO_OUTPUT', 'lvds7', 1, 0, d)}" do_install() { install -d ${D}${sysconfdir}/profile.d install -m 0755 qt5-env.sh ${D}${sysconfdir}/profile.d if test ${HAS_X11} -eq 0; then cat >> ${D}${sysconfdir}/profile.d/qt5-env.sh <<EOF # QT_QPA_PLATFORM There are multiple platform plugins that are # potentially usable on Embedded Linux systems: EGLFS, LinuxFB, KMS, # DirectFB, Wayland. The availability of these depend on the # configuration of Qt. The default platform plugin is also device # specific. For instance, on many boards eglfs will be chosen as the # default one. If the default is not suitable, the QT_QPA_PLATFORM # environment variable parameter can be used to request another plugin. # Alternatively, for quick tests, the -platform command-line can be # used with the same syntax. export QT_QPA_PLATFORM=eglfs EOF fi if test ${HAS_LVDS7} -eq 1; then cat >> ${D}${sysconfdir}/profile.d/qt5-env.sh <<EOF # QT_QPA_EGLFS_PHYSICAL_WIDTH and QT_QPA_EGLFS_PHYSICAL_HEIGHT # - Physical screen width and height in millimeters. On platforms # where the framebuffer device /dev/fb0 is not available or the # query is not successful, the values are calculated based on a # default DPI of 100. This variable can be used to override any # such defaults. export QT_QPA_EGLFS_PHYSICAL_HEIGHT=91 export QT_QPA_EGLFS_PHYSICAL_WIDTH=152 export QT_QPA_EGLFS_TSLIB=1 export QT_QPA_EVDEV_TOUCHSCREEN_PARAMETERS=/dev/input/event1:inverty export QT_EGLFS_IMX6_NO_FB_MULTI_BUFFER=1 EOF fi cat >> ${D}${sysconfdir}/profile.d/qt5-env.sh <<EOF # Add fonts path to prevent warnings export QT_QPA_FONTDIR=/usr/share/fonts/truetype EOF } FILES_${PN} = "${sysconfdir}" I have an issue to make the touchscreen work with the UDOO Quad. When I start my Qt app, I get this error: Code: evdevtouch: Cannot open input device /dev/input/event1 (No such file or directory) The touchscreen event is in /dev/input/event0.
