Hi, Why my quad board always auto reset (atuo reboot)? My quad board used UDOO power adapter(12V 2A). OS: android(update to ver1.1)(ver 1.0 the same) PS: Dual board no this probelm. thanks~
does the same thing happen when running Linaro? Does it happen when there is no activity? when it just sits idle? Does it happen when it is active running apps or browsing the web? Is there any common trigger or time frame or is it random... 5 mins after start up, or 30 minutes regardless of you doing something or nothing it just reboots? I haven't seent his specific bug reported, but we do know that the current Android build is very buggy and a new release is due out from UDOO any day now
Hi Draco~ No running any program and apps. Restart trigger is random, (5 sec,10 sec,1 min,any time...) Even occurs when initial boot at standby mode(standby to unlock mode). A trigger would have been repeated restarts. :? :? :?
did you create your SD card or did it come with the Board? If you created the SD card are you sure you are using the latest 1.2 version? Have you applied any updates? 2 main patches have been released, one official(that you should have) and one unofficial (which doesn't address anything like this
I just try "udoo_quad_android_1.1.zip" and "udoo_quad_android_1.0.zip" image file from UDOO. Is the same.(means restart) I haven't applied any updates.
Linus, have you tried ubuntu 1.2 image? it returns the same problem? We updated the android image (still called 1.1) friday, if you didn't reflash it by then i suggest you to redo the procedure. Let me know so i can give you more specific information. Cheers
Hi~ The Quad board run Linaro Ubuntu 11.10(udoo_quad_ubuntu_1.3.zip) no restart problem. But run Android(try new 1.1 image) still happen random auto restart problem. I I also tried another power adapter(12V 3A) and another mouse the problem still here. What do I need to try ? thanks!
Linus, i thought was a watchdog problem (hardware) but if with ubuntu 1.3 UDOO doesn't auto-restart and with Android 1.1 it does, the problem is somewhere else. We never experienced anything like that with android, we'll verify the issue and let you know asap. Cheers
I'm having a similar issue. It seems to have just started today. I've had my quad now for 4 days, and I think it's been fine for those days, but now it seems to restart often, at very random intervals. I'm running the latest version posted in the downloads section. I don't seem to recognize a trigger, it's sitting idle. I have been playing with the Arduino side of things recently, attempting to get the ADK working, but other than that Android isn't doing anything.
Got charge quad board thanks. constant rebooting problem on all versions of android. restarts at random intervals for no reason, and yactoo just do not boot! Normally only works on Ubuntu What to do?
If it works fine on Ubuntu then it's not a hardware related issue. Sounds like you need to download Android images again, check the SHA-1 checksum, and burn it to SD Card and try again. If it still doesn't work, try burning the card again etc. There are many reports of: a) bad download b) bad card writing - which repeated attempts fix.
Has anything changed on day 3 or 4? EG did you change the SD Card content (like trying Ubuntu 12.04 which came out yesterday) as you said you are 'running the latest version'.
all done by the description, and still does not boot android sometimes nothing at all happens when the power supply, and sometimes restarts on window launch
SHA-1 are the same giving otg. what do I do? then reboot or blank screen U-Boot 2009.08-svn24 (Nov 05 2013 - 03:04:40) CPU: Freescale i.MX6 family TO1.2 at 792 MHz Thermal sensor with ratio = 180 Temperature: 32 C, calibration data 0x5744e369 mx6q pll1: 792MHz mx6q pll2: 528MHz mx6q pll3: 480MHz mx6q pll8: 50MHz ipg clock : 66000000Hz ipg per clock : 66000000Hz uart clock : 80000000Hz cspi clock : 60000000Hz ahb clock : 132000000Hz axi clock : 264000000Hz emi_slow clock: 132000000Hz ddr clock : 528000000Hz usdhc1 clock : 198000000Hz usdhc2 clock : 198000000Hz usdhc3 clock : 198000000Hz usdhc4 clock : 198000000Hz nfc clock : 24000000Hz Board: i.MX6Q-UDOO: unknown-board Board: 0x63012 [POR] Boot Device: NOR I2C: ready DRAM: 1 GB MMC: FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3 *** Warning - bad CRC or MMC, using default environment In: serial Out: serial Err: serial Net: got MAC address from IIM: 00:c0:08:88:1b:12 FEC0 [PRIME] Hit any key to stop autoboot: 0 kernel @ 10808000 (4305072) ramdisk @ 11800000 (186957) kernel cmdline: use uboot command line: console=ttymxc1,115200 init=/init video=mxcfb0:dev=hdmi,1920x1080M@60,if =RGB24,bpp=32 video=mxcfb1ff video=mxcfb2ff fbmem=28M vmalloc=400M androidbo ot.console=ttymxc1 androidboot.hardware=freescale mem=1024M Starting kernel ... Initializing cgroup subsys cpuset Initializing cgroup subsys cpu Linux version 3.0.35-svn24 (udoo@ubuntu) (gcc version 4.6.x-google 20120106 (pre release) (GCC) ) #5 PREEMPT Mon Nov 4 02:58:07 PST 2013 CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache Machine: i.Mx6 UDOO Board Ignoring unrecognised tag 0x41000901 Memory policy: ECC disabled, Data cache writeback CPU identified as i.MX6Q, silicon rev 1.2 Built 1 zonelists in Zone order, mobility grouping on. Total pages: 223232 Kernel command line: console=ttymxc1,115200 init=/init video=mxcfb0:dev=hdmi,192 0x1080M@60,if=RGB24,bpp=32 video=mxcfb1ff video=mxcfb2ff fbmem=28M vmalloc=4 00M androidboot.console=ttymxc1 androidboot.hardware=freescale mem=1024M PID hash table entries: 2048 (order: 1, 8192 bytes) Dentry cache hash table entries: 65536 (order: 6, 262144 bytes) Inode-cache hash table entries: 32768 (order: 5, 131072 bytes) Memory: 640MB 240MB = 880MB total Memory: 879172k/879172k available, 169404k reserved, 491520K highmem Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) DMA : 0xfbe00000 - 0xffe00000 ( 64 MB) vmalloc : 0xd9800000 - 0xf2000000 ( 392 MB) lowmem : 0xc0000000 - 0xd9000000 ( 400 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .init : 0xc0008000 - 0xc0036000 ( 184 kB) .text : 0xc0036000 - 0xc0b53f58 (11384 kB) .data : 0xc0b54000 - 0xc0ba2880 ( 315 kB) .bss : 0xc0ba28a4 - 0xc0ccfae8 (1205 kB) Preemptible hierarchical RCU implementation. NR_IRQS:624 MXC GPIO hardware sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms arm_max_freq=1GHz MXC_Early serial console at MMIO 0x21e8000 (options '115200') bootconsole [ttymxc1] enabled Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280) pid_max: default: 32768 minimum: 301 Mount-cache hash table entries: 512 CPU: Testing write buffer coherency: ok hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available print_constraints: dummy: NET: Registered protocol family 16 print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal ####Called set_gpios_direction failed to get MX6_IO_MICRO: -16 Resetting ethernet physical layer. hw-breakpoint: found 6 breakpoint and 1 watchpoint registers. hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step. hw-breakpoint: maximum watchpoint size is 4 bytes. L310 cache controller enabled l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x02070000, Cache size: 1048576 B bio: create slab <bio-0> at 0 print_constraints: vmmc: 3300 mV vgaarb: loaded SCSI subsystem initialized usbcore: registered new interface driver usbfs usbcore: registered new interface driver hub usbcore: registered new device driver usb Freescale USB OTG Driver loaded, $Revision: 1.55 $ imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7) imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7) mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x3130302a MIPI CSI2 driver module loaded Advanced Linux Sound Architecture Driver Version 1.0.24. Bluetooth: Core ver 2.16 NET: Registered protocol family 31 Bluetooth: HCI device and connection manager initialized Bluetooth: HCI socket layer initialized Bluetooth: L2CAP socket layer initialized Bluetooth: SCO socket layer initialized cfg80211: Calling CRDA to update world regulatory domain i2c-core: driver [max17135] using legacy suspend method i2c-core: driver [max17135] using legacy resume method Switching to clocksource mxc_timer1 NET: Registered protocol family 2 IP route cache hash table entries: 16384 (order: 4, 65536 bytes) TCP established hash table entries: 65536 (order: 7, 524288 bytes) TCP bind hash table entries: 65536 (order: 6, 262144 bytes) TCP: Hash tables configured (established 65536 bind 65536) TCP reno registered UDP hash table entries: 256 (order: 0, 4096 bytes) UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) NET: Registered protocol family 1 RPC: Registered named UNIX socket transport module. RPC: Registered udp transport module. RPC: Registered tcp transport module. RPC: Registered tcp NFSv4.1 backchannel transport module. Unpacking initramfs... Freeing initrd memory: 180K PMU: registered new PMU device of type 0 Static Power Management for Freescale i.MX6 wait mode is enabled for i.MX6 cpaddr = d9880000 suspend_iram_base=d98f0000 PM driver module loaded IMX usb wakeup probe add wake up source irq 75 IMX usb wakeup probe cpu regulator mode:ldo_enable i.MXC CPU frequency driver highmem bounce pool size: 64 pages ashmem: initialized JFFS2 version 2.2. (NAND) В© 2001-2006 Red Hat, Inc. fuse init (API version 7.16) msgmni has been set to 757 io scheduler noop registered io scheduler deadline registered io scheduler cfq registered (default) MIPI DSI driver module loaded mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver hdmi mxc_hdmi mxc_hdmi: Detected HDMI controller 0x13:0xa:0xa0:0xc1 fbcvt: 1920x1080@60: CVT Name - 2.073M9 imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7) mxc_sdc_fb mxc_sdc_fb.1: Can't get fb option for mxcfb1! mxc_sdc_fb mxc_sdc_fb.2: Can't get fb option for mxcfb2! imx-sdma imx-sdma: loaded firmware 1.1 imx-sdma imx-sdma: initialized fbcvt: 1920x1080@60: CVT Name - 2.073M9 Serial: IMX driver imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX console [ttymxc1] enabled, bootconsole disabled console [ttymxc1] enabled, bootconsole disabled imx-uart.3: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX loop: module loaded request BOSSA_CLK IRQ registering IRQ 419 for BOSSAC Arduino erase/reset operation vcan: Virtual CAN interface driver CAN device driver interface flexcan netdevice driver FEC Ethernet Driver fec_enet_mii_bus: probed PPP generic driver version 2.4.2 PPP Deflate Compression module registered PPP BSD Compression module registered PPP MPPE Compression module registered NET: Registered protocol family 24 PPTP driver version 0.8.5 usbcore: registered new interface driver rt2800usb ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1 fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000 fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00 hub 1-0:1.0: USB hub found hub 1-0:1.0: 1 port detected add wake up source irq 72 fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2 fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200 fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00 hub 2-0:1.0: USB hub found hub 2-0:1.0: 1 port detected usbcore: registered new interface driver cdc_acm cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters Initializing USB Mass Storage driver... usbcore: registered new interface driver usb-storage USB Mass Storage support registered. usbcore: registered new interface driver usbserial usbserial: USB Serial Driver core USB Serial support registered for GSM modem (1-port) usbcore: registered new interface driver option option: v0.7.2:USB Driver for GSM modems USB Serial support registered for Qualcomm USB modem usbcore: registered new interface driver qcserial ARC USBOTG Device Controller driver (1 August 2005) android_usb gadget: Mass Storage Function, version: 2009/09/11 android_usb gadget: Number of LUNs=1 lun0: LUN: removable file: (no medium) Gadget Android: controller 'fsl-usb2-udc' not recognized android_usb gadget: android_usb ready Suspend udc for OTG auto detect fsl-usb2-udc: bind to driver android_usb mousedev: PS/2 mouse device common for all mice i2c-core: driver [isl29023] using legacy suspend method i2c-core: driver [isl29023] using legacy resume method using rtc device, snvs_rtc, for alarms snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0 i2c /dev entries driver Linux video capture interface: v2.00 mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16 mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17 i2c-core: driver [mag3110] using legacy suspend method i2c-core: driver [mag3110] using legacy resume method imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1) device-mapper: uevent: version 1.0.3 device-mapper: ioctl: 4.20.0-ioctl (2011-02-02) initialised: dm-devel@redhat.com Bluetooth: Virtual HCI driver ver 1.3 Bluetooth: HCI UART driver ver 2.2 Bluetooth: HCIATH3K protocol initialized Bluetooth: Generic Bluetooth USB driver ver 0.6 usbcore: registered new interface driver btusb sdhci: Secure Digital Host Controller Interface driver sdhci: Copyright(c) Pierre Ossman mmc0: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed VPU initialized mxc_asrc registered revserved_memory_account:viv_gpu registerd Thermal calibration data is 0x5744e369 Thermal sensor with ratio = 180 Anatop Thermal registered as thermal_zone0 anatop_thermal_probe: default cooling device is cpufreq! usbcore: registered new interface driver usbhid usbhid: USB HID core driver logger: created 256K log 'log_main' usb 2-1: new high speed USB device number 2 using fsl-ehci logger: created 256K log 'log_events' logger: created 256K log 'log_radio' logger: created 256K log 'log_system' usbcore: registered new interface driver snd-usb-audio mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio asoc: mxc-hdmi-soc <-> imx-hdmi-soc-dai.0 mapping ok ALSA device list: #0: imx-hdmi-soc Netfilter messages via NETLINK v0.30. nf_conntrack version 0.5.0 (13739 buckets, 54956 max) ctnetlink v0.93: registering with nfnetlink. NF_TPROXY: Transparent proxy support initialized, version 4.1.0 NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd. xt_time: kernel timezone is -0000 IPv4 over IPv4 tunneling driver GRE over IPv4 demultiplexor driver ip_tables: (C) 2000-2006 Netfilter Core Team arp_tables: (C) 2002 David S. Miller TCP cubic registered NET: Registered protocol family 10 ip6_tables: (C) 2000-2006 Netfilter Core Team IPv6 over IPv4 tunneling driver NET: Registered protocol family 17 NET: Registered protocol family 15 can: controller area network core (rev 20090105 abi 8) NET: Registered protocol family 29 can: raw protocol (rev 20090105) can: broadcast manager protocol (rev 20090105 t) mmc0: new high speed SDHC card at address aaaa Bluetooth: RFCOMM TTY layer initialized mmcblk0: mmc0:aaaa SU08G 7.40 GiB Bluetooth: RFCOMM socket layer initialized Bluetooth: RFCOMM ver 1.11 Bluetooth: BNEP (Ethernet Emulation) ver 1.3 Bluetooth: BNEP filters: protocol multicast Bluetooth: HIDP (Human Interface Emulation) ver 1.2 L2TP core driver, V2.0 PPPoL2TP kernel driver, V2.0 L2TP IP encapsulation support (L2TPv3) L2TP netlink interface L2TP ethernet pseudowire support (L2TPv3) lib80211: common routines for IEEE802.11 drivers hub 2-1:1.0: USB hub found mmcblk0: p1 p2 p3 < p5 p6 p7 p8 > p4 hub 2-1:1.0: 4 ports detected VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 MMDC: unable to set irq affinity irq=139, Bus freq driver module loaded Bus freq driver Enabled mxc_dvfs_core_probe DVFS driver module loaded snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:01 UTC (1) Freeing init memory: 184K input: A4TECH USB Device as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.1/2-1.1:1.0/input/input0 generic-usb 0003:09DA:054F.0001: input,hidraw0: USB HID v1.11 Keyboard [A4TECH USB Device] on usb-fsl-ehci.1-1.1/input0 input: A4TECH USB Device as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.1/2-1.1:1.1/input/input1 generic-usb 0003:09DA:054F.0002: input,hidraw1: USB HID v1.11 Mouse [A4TECH USB Device] on usb-fsl-ehci.1-1.1/input1 usb 2-1.3: new high speed USB device number 4 using fsl-ehci init: cannot find '/system/bin/ingsvcd', disabling 'ing' android_usb: already disabled android_usb: already disabled mtp_bind_config adb_bind_config adb_open root@android:/ # warning: `zygote' uses 32-bit capabilities (legacy support in use) request_suspend_state: wakeup (3->0) at 14478501670 (1970-01-02 00:00:04.528560333 UTC) eth0: Freescale FEC PHY driver [Generic PHY] (mii_bushy_addr=1:06, irq=-1) Warning: Product ID of physical layer not recognized [id = 0x1622 unknown] ADDRCONF(NETDEV_UP): eth0: link is not ready acc_open acc_release
я заново скачивал образы, безрезультатно я пробовал 3 шт. sd card , безрезультатно я пробовал 2 шт. компьютеров , безрезультатно Android без перерыва перезагружается Что мне делать? Как из источников собрать систему самому? (очень подробное описание) I re-downloaded the images, to no avail I tried 3 pcs. sd card, to no avail I tried 2 pcs. computers, to no avail Android reboots without interruption What do I do? How to assemble a system from the sources yourself? (very detailed description)
I just got my new class 10 micro SD card for my UDOO and am still having this issue. The only reason I bought this thing is for Android, and it's currently unusable, it keep rebooting at random intervals.
At this point i might be best to open an actual support ticket with UDOO if you havent already They have a new ticketing system, you can find the link in my signature.
That's my advise as well. Open a new ticket defining as help topic "Technical Support" explaining your problem.
