Hi i am beginner in udoo, i try to write IR reciver but i got errors. Code: In file included from F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:20:0: F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp: In member function 'void IRsend::mark(int)': F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:227:31: error: 'TCCR2A' was not declared in this scope #define TIMER_ENABLE_PWM (TCCR2A |= _BV(COM2B1)) ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:227:3: note: in expansion of macro 'TIMER_ENABLE_PWM' TIMER_ENABLE_PWM; // Enable pin 3 PWM output ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:227:45: error: 'COM2B1' was not declared in this scope #define TIMER_ENABLE_PWM (TCCR2A |= _BV(COM2B1)) ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:227:3: note: in expansion of macro 'TIMER_ENABLE_PWM' TIMER_ENABLE_PWM; // Enable pin 3 PWM output ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:227:51: error: '_BV' was not declared in this scope #define TIMER_ENABLE_PWM (TCCR2A |= _BV(COM2B1)) ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:227:3: note: in expansion of macro 'TIMER_ENABLE_PWM' TIMER_ENABLE_PWM; // Enable pin 3 PWM output ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp: In member function 'void IRsend::space(int)': F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:228:31: error: 'TCCR2A' was not declared in this scope #define TIMER_DISABLE_PWM (TCCR2A &= ~(_BV(COM2B1))) ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:235:3: note: in expansion of macro 'TIMER_DISABLE_PWM' TIMER_DISABLE_PWM; // Disable pin 3 PWM output ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:228:47: error: 'COM2B1' was not declared in this scope #define TIMER_DISABLE_PWM (TCCR2A &= ~(_BV(COM2B1))) ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:235:3: note: in expansion of macro 'TIMER_DISABLE_PWM' TIMER_DISABLE_PWM; // Disable pin 3 PWM output ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:228:53: error: '_BV' was not declared in this scope #define TIMER_DISABLE_PWM (TCCR2A &= ~(_BV(COM2B1))) ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:235:3: note: in expansion of macro 'TIMER_DISABLE_PWM' TIMER_DISABLE_PWM; // Disable pin 3 PWM output ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp: In member function 'void IRsend::enableIROut(int)': F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:230:31: error: 'TIMSK2' was not declared in this scope #define TIMER_DISABLE_INTR (TIMSK2 = 0) ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:253:3: note: in expansion of macro 'TIMER_DISABLE_INTR' TIMER_DISABLE_INTR; //Timer2 Overflow Interrupt ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:234:3: error: 'TCCR2A' was not declared in this scope TCCR2A = _BV(WGM20); \ ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:263:3: note: in expansion of macro 'TIMER_CONFIG_KHZ' TIMER_CONFIG_KHZ(khz); ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:234:16: error: 'WGM20' was not declared in this scope TCCR2A = _BV(WGM20); \ ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:263:3: note: in expansion of macro 'TIMER_CONFIG_KHZ' TIMER_CONFIG_KHZ(khz); ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:234:21: error: '_BV' was not declared in this scope TCCR2A = _BV(WGM20); \ ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:263:3: note: in expansion of macro 'TIMER_CONFIG_KHZ' TIMER_CONFIG_KHZ(khz); ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:235:3: error: 'TCCR2B' was not declared in this scope TCCR2B = _BV(WGM22) | _BV(CS20); \ ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:263:3: note: in expansion of macro 'TIMER_CONFIG_KHZ' TIMER_CONFIG_KHZ(khz); ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:235:16: error: 'WGM22' was not declared in this scope TCCR2B = _BV(WGM22) | _BV(CS20); \ ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:263:3: note: in expansion of macro 'TIMER_CONFIG_KHZ' TIMER_CONFIG_KHZ(khz); ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:235:29: error: 'CS20' was not declared in this scope TCCR2B = _BV(WGM22) | _BV(CS20); \ ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:263:3: note: in expansion of macro 'TIMER_CONFIG_KHZ' TIMER_CONFIG_KHZ(khz); ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:236:3: error: 'OCR2A' was not declared in this scope OCR2A = pwmval; \ ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:263:3: note: in expansion of macro 'TIMER_CONFIG_KHZ' TIMER_CONFIG_KHZ(khz); ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:237:3: error: 'OCR2B' was not declared in this scope OCR2B = pwmval / 3; \ ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:263:3: note: in expansion of macro 'TIMER_CONFIG_KHZ' TIMER_CONFIG_KHZ(khz); ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp: In member function 'void IRrecv::enableIRIn()': F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:249:3: error: 'TCCR2A' was not declared in this scope TCCR2A = _BV(WGM21); \ ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:279:3: note: in expansion of macro 'TIMER_CONFIG_NORMAL' TIMER_CONFIG_NORMAL(); ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:249:16: error: 'WGM21' was not declared in this scope TCCR2A = _BV(WGM21); \ ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:279:3: note: in expansion of macro 'TIMER_CONFIG_NORMAL' TIMER_CONFIG_NORMAL(); ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:249:21: error: '_BV' was not declared in this scope TCCR2A = _BV(WGM21); \ ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:279:3: note: in expansion of macro 'TIMER_CONFIG_NORMAL' TIMER_CONFIG_NORMAL(); ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:250:3: error: 'TCCR2B' was not declared in this scope TCCR2B = _BV(CS21); \ ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:279:3: note: in expansion of macro 'TIMER_CONFIG_NORMAL' TIMER_CONFIG_NORMAL(); ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:250:16: error: 'CS21' was not declared in this scope TCCR2B = _BV(CS21); \ ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:279:3: note: in expansion of macro 'TIMER_CONFIG_NORMAL' TIMER_CONFIG_NORMAL(); ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:251:3: error: 'OCR2A' was not declared in this scope OCR2A = TIMER_COUNT_TOP / 8; \ ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:279:3: note: in expansion of macro 'TIMER_CONFIG_NORMAL' TIMER_CONFIG_NORMAL(); ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:252:3: error: 'TCNT2' was not declared in this scope TCNT2 = 0; \ ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:279:3: note: in expansion of macro 'TIMER_CONFIG_NORMAL' TIMER_CONFIG_NORMAL(); ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:229:31: error: 'TIMSK2' was not declared in this scope #define TIMER_ENABLE_INTR (TIMSK2 = _BV(OCIE2A)) ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:282:3: note: in expansion of macro 'TIMER_ENABLE_INTR' TIMER_ENABLE_INTR; ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:229:44: error: 'OCIE2A' was not declared in this scope #define TIMER_ENABLE_INTR (TIMSK2 = _BV(OCIE2A)) ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:282:3: note: in expansion of macro 'TIMER_ENABLE_INTR' TIMER_ENABLE_INTR; ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:229:50: error: '_BV' was not declared in this scope #define TIMER_ENABLE_INTR (TIMSK2 = _BV(OCIE2A)) ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:282:3: note: in expansion of macro 'TIMER_ENABLE_INTR' TIMER_ENABLE_INTR; ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp: In function 'void TIMER2_COMPA_vect()': F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:501:25: error: 'PORTB' was not declared in this scope #define BLINKLED_ON() (PORTB |= B00100000) ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:370:7: note: in expansion of macro 'BLINKLED_ON' BLINKLED_ON(); // turn pin 13 LED on ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremoteInt.h:502:25: error: 'PORTB' was not declared in this scope #define BLINKLED_OFF() (PORTB &= B11011111) ^ F:\Works\Tools\ArduinoIDE UDOO Path\libraries\IRremote\IRremote.cpp:373:7: note: in expansion of macro 'BLINKLED_OFF' BLINKLED_OFF(); // turn pin 13 LED off ^ i used in this library https://www.pjrc.com/teensy/td_libs_IRremote.html thank you!
Hi, UDOO has an Arduino DUE processor integrated, the libraries have to be Arduino DUE compatibles. I'm not sure that these libraries developed for Teensy are compatible with the SAM3X Arduino DUE processor.
