Recent UDOO updates
Discussion in 'General Discussion' started by trunet, Oct 30, 2013.
  1. trunet
    trunet New Member
    Oct 25, 2013
    17
    I'm seeing that you're releasing new binary versions of u-boot and kernel/modules.
    Why UDOO patched u-boot source code is not available?
    Why Kernel_Unico is not being updated as this last update?
    I'm using a custom version of kernel because I need to include some modules that is not included in your binary version. So please, make the commits on your repository.
    Thanks,
    Wagner Sartori Junior
  2. DracoLlasa
    DracoLlasa UDOOer
    Oct 15, 2013
    419
    were the downloadable IMG files updated? it seems they are still v1.2 from before
  3. trunet
    trunet New Member
    Oct 25, 2013
    17
    anyone?
  4. maurizio
    maurizio Administrator
    Jul 1, 2013
    35
    Go there : http://www.udoo.org/downloads/#tab2
    U-boat and Kernel are update.
    For automatic update : http://www.udoo.org/update-procedure/
    This update will upgrade the uBoot (release 1.2 version v.89) and Kernel (release 1.2 version v.87) to the latest available release. None of your data will be deleted, nor your installed applications but, if you made changes to the uBoot's environment variables, those will be lost after the update.
  5. trunet
    trunet New Member
    Oct 25, 2013
    17
    That does not answer my 2 initial questions:
  6. jayrabe
    jayrabe New Member
    Oct 31, 2013
    Successfully downloaded and extracted the U-boot update, but can't get it to load onto SD card.
    Executed: sudo ./udooupdate.sh but get error "can't guess the UDOO cpu (use -c CPU option).
    I'm total newbie to Linux. Thanks for any help.
    Jay
  7. mkopack
    mkopack Member
    451
    Each they need to edit the usage comments to explain what values are valid for the -CPU option. Is it looking for "dual" vs "quad" or "2" vs "4" ? Etc.
  8. jayrabe
    jayrabe New Member
    Oct 31, 2013
    I successfully created a new Ubuntu boot disk using win32DiskImager per tutorial. It all worked. Thanks for a clear procedure that even a noob can follow!
    I used the udoo_quad_ubuntu_1.2.img file. Is this the most current or do I still need to do the "update"?
    Thanks
  9. mkopack
    mkopack Member
    451
    Nope that's the most recent, you all good to go (for now until there is a new update).
  10. jayrabe
    jayrabe New Member
    Oct 31, 2013
    Thanks.
    On a related note, when I put either the Arduino or Linux boot SD into my USB card reader, it doesn't seem to see any file structure, telling me I need to format the card before using it. I declined (duh) but am curious why nothing shows up.
  11. firehopper
    firehopper Member
    Jun 10, 2013
    154
    the card is formatted in ext3 I think, something windows cant read.
  12. joemcder
    joemcder New Member
    Oct 21, 2013
    17
    I assume you have plugged the card into Windows using NTFS. The Linux filesystem (EXT3) is not recognized. That's why most memory sticks are formatted as FAT32. Windows, Linux, Mac, cameras and just about every gadget can recognize FAT32. Unfortunately it is an old 'primitive' file system good enough for sticks which are the modern equivalent of floppy disks. 'Sneaker Net' will never die :)
  13. andcmp
    andcmp New Member
    161
    Confirmed!
  14. steezeburger
    steezeburger New Member
    Oct 20, 2013
    -c quad worked after I got the "Can't guess the UDOO cpu" error.
