Recover display on Basic board
Discussion in 'UDOO X86' started by Jagan Teki, Nov 16, 2018.
  1. Jagan Teki
    Jagan Teki New Member
    Nov 10, 2018
    We accidentally turn of display ports in BIOS, and later power on we can't see anything on HDMI monitor? any idea how to recover an get the display on again.
    Thanks,
    Jagan
  2. Laura
    Laura UDOOer
    Apr 22, 2016
    374
    156
    Restore Factory configuration
    You can restore the factory default settings from the SCU pressing the F9 key.
    You can also restore the factory UEFI BIOS configuration with a simple procedure involving the RTC battery: when the board is NOT connected to any power source, unplug the RTC battery on the bottom side of the board and keep it unplugged for at least 1 minute. Plug the RTC battery again and power up the board, all the configurations should now be reverted to the factory defaults.
    Heads up! You can use the RTC battery procedure starting from the UEFI BIOS v1.03
    Updating the UEFI BIOS to a newer version will also restore the new factory default configuration.
