Reinstalling UDOO tooling arm-none-eabi-g++ not found
Discussion in 'UDOO NEO' started by Maurice, Jul 3, 2018.
  1. Maurice
    Maurice Active Member
    Oct 13, 2015
    394
    87
    I have dusted off my Neo, reflashed a SD card and am trying to get an Arduino program up and running again. My Arduino IDE still contains the board packages of the UDOO, unfortunately when I try to compile it the g++ compiler seems not to be available anymore:
    How can I fix my environment?
  2. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    159
    17
    Are you programming from the UDOO or an external PC?
    I've used ArduinoIDE 1.8.1 for months without getting that error.
    What about reinstall ArduinoIDE?
  3. Maurice
    Oct 13, 2015
    394
    87
    I'm using an external PC. I've stuck with the old Arduino ide because 'in the past' newer ides didn't work.
  4. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    159
    17
    Sure to install them correctly? Never had particular problems with ArduinoIDE..
    OS? Kernel?
  5. Maurice
    Oct 13, 2015
    394
    87
    The new 1.8.5 IDE recognizes or uses the same path as the old one. I removed the .arduino15 directory, re-installed the board definition. Due to the 32/64 bit difference the g++ is probably not running. Executing
    sudo apt-get -y install lib32z1 lib32ncurses5 lib32bz2-1.0 doesn't work as lib32bz2-1.0 isn't found in Ubuntu 18. Leaving that last one out worked, and I was able to upload to my Neo again.
  6. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    159
    17
