Hello, I have problem with HW reset bios to the default setting (factory reset). I set up xhci - USB on DISABLE yesterday and then does not work keyboard and all USB devices. I don´t know how to bios setting and change usb xhci on ENABLE without keyboard. Thank you very much for your help
You need to flash the firmware. The tool and guide for performing this action is available on the following page: https://www.udoo.org/other-resources/#x86
Is the standard Bios updating tool not working (because USB is switched off)? Then you have to do something way more complex to update. See the following post and thread: https://www.udoo.org/forum/threads/reset-bios-jumper-or-pins.6674/#post-25338
Thank you Laura, but I do not have any system installed on udoo yet and USB flash does not respond. When I create, for example, a dos boot on a USB stick with UEFI update, will it work when USB ports do not respond? Thanks
