Sata drive issues.
Discussion in 'General Discussion' started by evilpengw1n, Feb 22, 2014.
  1. evilpengw1n
    evilpengw1n New Member
    Oct 21, 2013
    26
    So now that I've figured out the drive, I'm not quite sure what's going on. I installed linaro 12.04 on the microsd (so i could have u-boot 2013) as well as on the sata drive. same procedure, then used gparted to fill up both drives (16gb micro, 500gb sata). Booted, watched 115200, used 'setenv root root=/dev/sda1' the 'boot', and it booted succesfully. However, 'df -mh' shows:
    ubuntu@udoo:~$ df -mh
    Filesystem      Size  Used Avail Use% Mounted on
    /dev/root       6.7G  2.4G  4.0G  37% /
    devtmpfs        438M  4.0K  438M   1% /dev
    none             88M  2.6M   86M   3% /run
    none            5.0M     0  5.0M   0% /run/lock
    none            438M  100K  438M   1% /run/shm
    Which is weird, because it booted succesfully and fdisk -l looks like I thought it would:
    ubuntu@udoo:~$ fdisk -l
    WARNING: GPT (GUID Partition Table) detected on '/dev/sda'! The util fdisk doesn
    't support GPT. Use GNU Parted.
    Disk /dev/sda: 500.1 GB, 500107862016 bytes
    255 heads, 63 sectors/track, 60801 cylinders, total 976773168 sectors
    Units = sectors of 1 * 512 = 512 bytes
    Sector size (logical/physical): 512 bytes / 512 bytes
    I/O size (minimum/optimal): 512 bytes / 512 bytes
    Disk identifier: 0x000c356e
       Device Boot      Start         End      Blocks   Id  System
    /dev/sda1           16065   970928127   485456031+  83  Linux
    /dev/sda2       970928128   976773119     2922496   82  Linux swap / Solaris
    Disk /dev/mmcblk0: 15.7 GB, 15707668480 bytes
    255 heads, 63 sectors/track, 1909 cylinders, total 30679040 sectors
    /dev/mmcblk0p1           16065    14201459     7092697+  83  Linux
    Problem resolved. Resolution:
    setenv mmcroot /dev/sda1 rootwait rw
    U-boot 2013 uses mmcroot.
    /dev/root       456G  2.4G  431G   1% /
    none            438M   88K  438M   1% /run/shm
  2. rolly
    rolly New Member
    May 12, 2014
    14
    How might I make this correction?
  3. peter247
    peter247 Member
    Mar 10, 2014
    263
    Enter this line by line :-
    setenv sataroot "/dev/sda1"
    setenv satadev 0
    setenv satapart 1
    setenv loaduimagesata 'ext2load sata ${satadev}:${satapart} ${loadaddr} ${uimage}'
    setenv sataargs 'setenv bootargs console=${console},${baudrate} root=${sataroot} ${hdmi_patch} fbmem=24M video=mxcfb0:dev=hdmi,1920x1080M@60,bpp=32'
    setenv sataboot 'echo Booting from sata ...; run sataargs ; bootm'
    setenv bootcmd 'sata dev ${satadev}; run loaduimagesata; run sataboot;'
    saveenv
    reset
    But how I do it is :
    Boot from the SD image with default uboot setting with sata drive backed up in a state you can reformat and start again:
    fdisk /dev/sda ... delete all partition and make two new partitions , 16gb and the other the rest .
    format the first partition .. mke2fs -j /dev/sda1
    mount /dev/sda1 /mnt
    download / unzip and copy the rootfs to your mount point
    download / unzip and copy kernel and modules to the mount point
    reboot
    set up uboot to uses the sata drive to boot
    format the second partition .. mke2fs -j /dev/sda2
    mount the big partition to the mount point so you can share it.
  4. rolly
    rolly New Member
    May 12, 2014
    14
    I have an inexpensive ($70) 120 GB SATA SSD hooked up to my UDOO.
    I had originallly followed the proceedure in http://www.elinux.org/UDOO_boot_from_sata.
    Using it bootup was OK (albeit slow), I could see both the micro sd card & the sata drive, but the system was slow.
    I performed bootus-interuptus using a serial connection to a pc, entered
    as you suggested,
    along with
    saveenv
    , rebooted, & magic happened.
    My UDOO went from disappointing slow, to a real speed daemon. Bootup & program execution became comfortably fast.
    Consequences noticed so far:
    - micro SD card no longer appears (but that's OK as I didn't want it to be used for anything).
    - Firefox disappeared (
    sudo apt-get install firefox
    got it back.
    - desktop background & icons vanished.
    Thanks for the help.
