SD card prepartion have issue.
Discussion in 'UDOO NEO' started by pavan, Jul 23, 2019.
  1. pavan
    pavan UDOOer
    Jul 6, 2019
    14
    11
    Hi Team,
    Directly writing image to SD card working fine.
    sudo dd bs=1M if=udoobuntu-udoo-neo-desktop_20190623-2007.img of=/dev/sdb ==> Working fine.
    Issue :
    Creating own SPL and Uboot file and writing to SD card, at the time have issue.
    How to create own SD card partition and how to write SPL,Uboot to SD card.
    While write to SD card i am facing below issue.
    Could you please help on this.
    linux$
    linux$ lsblk
    NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
    sda 8:0 0 465.8G 0 disk
    ├─sda1 8:1 0 95.4G 0 part /
    ├─sda2 8:2 0 3.8G 0 part [SWAP]
    ├─sda3 8:3 0 250G 0 part /media/linux/d3013e39-a19c-402e-8736-0ccd0b2bb896
    └─sda4 8:4 0 116.6G 0 part /media/linux/3b7afe20-bab2-406a-8c64-811e78f911e2
    sdb 8:16 1 7.5G 0 disk
    ├─sdb1 8:17 1 32M 0 part /media/linux/boot1
    └─sdb2 8:18 1 2.6G 0 part /media/linux/udoobuntu
    sr0 11:0 1 1024M 0 rom
    linux$
    linux$
    linux$
    linux$
    linux$
    linux$ ls
    SPL u-boot.img zImage dts
    System.map
    linux$ sudo dd if=SPL of=/dev/sdb1 seek=1 bs=1k
    [sudo] password for linux:
    31+0 records in
    31+0 records out
    31744 bytes (32 kB, 31 KiB) copied, 0.000417137 s, 76.1 MB/s
    linux$
    linux$
    linux$ ls
    System.map
    linux$
    linux$ sudo dd if=u-boot.img of=/dev/sdb1 seek=69 bs=1k
    230+1 records in
    230+1 records out
    236260 bytes (236 kB, 231 KiB) copied, 0.00160651 s, 147 MB/s
    linux$ sync
    linux$
    linux$
    linux$
    ls: cannot access ''$'\022''± 2ε╥'$'\a''ε.Ü_'$'\001': Input/output error
    ls: cannot access ''$'\b''╨"f'$'\v''h'$'\f''i.'$'\001''<'$'\r': Input/output error
    ls: cannot access ''$'\a''εü?'$'\001''≡.'$'\b''╡ ': Input/output error
    ls: cannot access 'ಠ≈m '$'\001''≡.╣² ': Input/output error
    ls: cannot access ''$'\003''╤'$'\001'')'$'\024''┐c#.g#┬': Input/output error
    ls: cannot access ''$'\032''`,J.ó⌡µ': Input/output error
    ls: cannot access 'w └≤'$'\a''0c(.'$'\005''╤ ': Input/output error
    ls: cannot access 'pG.'$'\b''╡ ': Input/output error
    ls: cannot access '#╨'$'\022''KÜi┬≤.AQ┬': Input/output error
    ls: cannot access ''$'\t\003\003''çpgpg.'$'\017''jo': Input/output error
    ls: cannot access ''$'\a''╤'$'\002''≡'$'\003\003\006''!.[': Input/output error
    ls: cannot access '¿°éç.'$'\001''(s': Input/output error
    ls: cannot access 'hfú@'$'\005''Ω'$'\003\001''.ß@'$'\035': Input/output error
    ls: cannot access '─≤'$'\002''D'$'\003''⌠.'$'\b''α─': Input/output error
    ls: cannot access ''$'\032''o'$'\020''▒B⌠@R.'$'\001''α"': Input/output error
    ls: cannot access ''$'\002''(ö┐'$'\030''F.)α'$'\003': Input/output error
    ls: cannot access '└≤ü@'$'\002''('$'\017''╨.'$'\003''('$'\022': Input/output error
    ls: cannot access '@q!⌠@aög.┘j!': Input/output error
    ls: cannot access 'nk'$'\033''h▄ic'$'\006''.'$'\005''╘ ': Input/output error
    ls: cannot access '┬≤Aq┬≤┬T.'$'\002'')'$'\020': Input/output error
    ls: cannot access '/k.'$'\024''0x': No such file or directory
    '¥· !'$'\001''¬.'$'\f''┐'$'\023' ''$'\036''H'$'\003''⌐'$'\n''≡Φ■'
    ''$'\001''.'$'\022''&' '%H'$'\v''≡├ #i.$H'
    '▐└¡'$'\v' ''$'\b''╡'$'\b''h'$'\v''≡'$'\002'' .l≥p'
    '╔.'$'\003\003''[' '-I'$'\033''≡Ä√.∞╨0'
    '╛.'$'\024''≡ƒ' ''$'\003''!'$'\032''≡î■'$'\a''f'
    '╦■."≡'$'\017' '¬i+`Za.p╜8'
    '■≈\■'$'\f'' ■≈.'$'\025''ⁿ'$'\004' '#╣'$'\003''i'$'\023''╣.╜Φ°'
    ''$'\004''≡≡'$'\005\004''≡'$'\017\004''.└≤'$'\a' 'i·'$'\001''≡»·╜Φ.'$'\b''@'$'\f'
    ''$'\a''╤'$'\002''≡'$'\003\003\006''!.[' jfrnsfjf.Rnô
    ''$'\b''╜' 'jh╤p.B°'$'\b'
    ''$'\t''.'$'\002' ''$'\032''`,J.ó⌡µ'
    ''$'\f''≡┤ⁿ'$'\001''! |.'$'\t''%'$'\021' ''$'\001\002\032''`'$'\024''JO⌠.ös'$'\023'
    ''$'\r' ''$'\002''J'$'\023''`pG.'$'\004''!á'
    ''$'\r' ''\''j'$'\022''α ≈â .&i'$'\a'
    ''$'\r' '/k.'$'\024''0x'
    ''$'\r' ''$'\027''k.'$'\024''0X'
    ''$'\r' 'KF'$'\033''hs╡'$'\005''F.'$'\033''l'$'\001'
    ''$'\r' '┌`kf[n4j.'$'\032''ak'
    ''$'\r' '≤╨'$'\036''K'$'\032''hB≡.'$'\001\002\032'
    ''$'\020''.,' ''$'\t''k'$'\034''h. h)'
    ''$'\022''.'$'\037\020' '┌küc┌k'$'\020'':.┌cp'
    ''$'\035''°.'$'\001''*'$'\001' 'k■'$'\001''Ü F.!."≡?'
    ''$'\a''0c('$'\006''╤■≈.ô └' '#╨'$'\022''KÜi┬≤.AQ┬'
    '■≈╢■└≤'$'\a''0.d('$'\004' 'l╣'$'\004''6'$'\b''.±╨.°τq'
    ''$'\a''°└≤'$'\a''0f(.'$'\v''╨ ' L⌠çç╣CÇç.,
    ''$'\a''.0f ' ''$'\n'' LF ≈╓ⁿ.─°╨'
    linux$
    linux$
    linux$
    linux$
    After writing SPL and Uboot to SD card, displaying above junk values.
    Can you please suggest me, how to write SPL and Uboot.img file to SD card.
    Thanks,
    Pavan.
    huthamcau likes this.
  2. pavan
    pavan UDOOer
    Jul 6, 2019
    14
    11
    If any know about this issue, please help on this.
  3. ektor5
    Jul 1, 2013
    97
    48
    Hi Pavan,
    You wrongly flashed the uboot directly on the filesystem instead of the whole disk:
    Right commands:
    sudo dd if=SPL of=/dev/sdb seek=1 bs=1k
    sudo dd if=u-boot.img of=/dev/sdb seek=69 bs=1k
    Have a nice day,
    Ek5
    evaloverde, huthamcau and waltervl like this.
  4. pavan
    pavan UDOOer
    Jul 6, 2019
    14
    11
    Hi Ek5,
    Thanks for reply, i have tried same thing as below.
    But it not showing any thing in SD card.
    Could you please suggest me, am i doing correct or not ?
    linux$ ls
    dts  SPL  System.map  u-boot.img  zImage
    linux$ sudo dd if=SPL of=/dev/sdb seek=1 bs=1k
    31+0 records in
    31+0 records out
    31744 bytes (32 kB, 31 KiB) copied, 0.00386453 s, 8.2 MB/s
    linux$
    linux$ sudo dd if=u-boot.img of=/dev/sdb seek=69 bs=1k
    230+1 records in
    230+1 records out
    236244 bytes (236 kB, 231 KiB) copied, 0.00100831 s, 234 MB/s
    linux$
    linux$
    linux$ lsblk
    └─sdb1   8:17   1   7.5G  0 part /media/linux/7E09-5BB6
    linux$
    linux$
    linux$ ls
    linux$
    linux$pwd
    linux$
    Hi Team,
    if any one knows about this issue, could you please help on this.
    Thanks,
    Pavan
  5. ektor5
    Jul 1, 2013
    97
    48
    Hi pavan,
    This is not an issue, it is normal.
    After dd-ing the disk, the kernel doesn't reload the partition table automatically.
    You can do that manually by executing `partprobe` or rebooting.
    BR,
    Ek5
    evaloverde likes this.
  6. pavan
    pavan UDOOer
    Jul 6, 2019
    14
    11
    Hi Ek5,
    Thanks for you response.
    Can you please share the step for
    1.How to create exact space of fat32 for SPL and U-boot in SD card.
    2.How to write SPL and U-boot file into SD card.
    3.How to write zImage and rootfs into SD.
    Could you please share the details. I didn't able to find the exact details in internet.
  7. waltervl
  8. pavan
    pavan UDOOer
    Jul 6, 2019
    14
    11
    Thanks for response waltervl.
    I have tried but not luck, if you did anything like that ... can you please share any example scripts.
    Same thing i will try in my side.
    Thanks,
    Pavan.
  9. waltervl
    The mkudoobuntu script is the script. Not much more to share.
    I personelly have no experience with this so cannot help you.
    Why do you want to create a new SPL and uboot?
  10. pavan
    pavan UDOOer
    Jul 6, 2019
    14
    11
    Thanks for reply.
    Actually i am looking for how to create our own custom udoo neo operation system.
    This is actual requirement.
