searching for compatible cable for humidity sensor
Discussion in 'UDOO BOLT' started by stecolumna, Feb 28, 2020.
  1. stecolumna
    stecolumna UDOOer
    May 20, 2016
    138
    33
    I had purchased a humidity sensor for my Udoo X86 Ultra but now I see that the cable is not compatible with the pin assignment of the 3 sockets mounted on the Udoo BOLT. Do you know if a compatible cable is on sale in the Udoo Shop?
    Thanks and best regards,
    Stefano Colonna
    [italiano]
    Io avevo acquistato un sensore di umidità per la mia Udoo X86 Ultra ma vedo ora che il cavo non è compatibile con la piedinatura dei 3 zoccoli montati sulla Udoo BOLT. Sapete se in Udoo Shop esiste in vendita un cavo compatibile ?
    Grazie e cordiali saluti
    Stefano Colonna
  2. stecolumna
    stecolumna UDOOer
    May 20, 2016
    138
    33
    I rephrase the question: from what I understand the three external connectors of Udoo Bolt V8 for the sensors are reserved only for the Grove then I would like to know if there is on Udoo Bolt V8 an I2C Brick connector compatible with the Snap-in UDOO Bricks in order to connect the I2C sensor without having to use the UDOO BOLT I / O Expansion Board described in https://www.udoo.org/docs-bolt/Arduino_Leonardo-compatible(ATmega32U4)/Pinout.html but which among other things I cannot find for sale in the Udoo Shop
    [italiano]
    Riformulo la domanda:
    da quanto ho capito i tre connettori esterni per i sensori della Udoo Bolt V8 sono riservati soltanto al Grove allora vorrei sapere se esiste su Udoo Bolt V8 un I2C Brick connector compatibile con il Snap-in UDOO Bricks in modo da connettere il sensore I2C senza dover usare la UDOO BOLT I/O Expansion Board descritta in https://www.udoo.org/docs-bolt/Arduino_Leonardo-compatible(ATmega32U4)/Pinout.html ma che tra l'altro non trovo in vendita in Udoo Shop
  3. ccs_hello
    424
    162
    UDOO x86's CN24 (Bricks interface) is a 4-pin I2C connector arrangement;
    UDOO Bolt's CN28 (Grove interface) is also for I2C connection
    (Both are on Arduino side.)
    But you'll need a pin converter to change connector pitch and pinout, guess DIY is the best way.
    Alternatively, why not just get the I2C sensor that is already come with the Grove interface?
    stecolumna likes this.
  4. stecolumna
    stecolumna UDOOer
    May 20, 2016
    138
    33
  5. stecolumna
    stecolumna UDOOer
    May 20, 2016
    138
    33
    Dear ccs_hello,
    where to buy the humidity sensor with Grove interface in UdooShop?
    Thanks for advice
  6. ccs_hello
    424
    162
  7. stecolumna
    stecolumna UDOOer
    May 20, 2016
    138
    33
  8. ccs_hello
    424
    162
    I would think so (but you'll have to try).
    UDOO Bolt's Grove interface is supposed to work with all Grove based sensor boards.
    After all, they are all for Arduino boards and Bolt has one in it.
  9. stecolumna
    stecolumna UDOOer
    May 20, 2016
    138
    33
    Dear ccs_hello,
    OK! I got it. Thanks for the tips
  10. stecolumna
    stecolumna UDOOer
    May 20, 2016
    138
    33
    Dear ccs_hello,
    I found the seeestudio.com products for sale on Mouser.it
    I ask you if the cable should be buckled or unbuckled
    Thanks in advance
    Descrizione:
    Stumenti di sviluppo per sensori a funzioni multiple Grove - CO2 & Temperature & Humidity Sensor (SCD30)
    https://www.mouser.it/ProductDetail...GAEpiMZZMve4/bfQkoj%2BJoqoFqZJeF2RzMbmZzEWhk=
    Descrizione:
    Accessori Seeed Studio Grove - Universal 4 Pin Buckled 20cm Cable (5 PCs pack)
    https://www.mouser.it/ProductDetail...=sGAEpiMZZMvxSQPygxWTpTF6csad0WNBtWZE7NXNUwg=
  11. ccs_hello
    424
    162
    I am guessing the "buckled" type connector has the locking latch to make it harder to remove (pulling out) the cable.
    I think it's all up to you.
    Cable length probably is the first thing to consider...
  12. stecolumna
    stecolumna UDOOer
    May 20, 2016
    138
    33
    Dear ccs_hello,
    If this is the only difference, there is no problem. I thought it was a different cable configuration that could affect compatibility with the SBC.
    Thank you very much.
    [italiano]
    Se la differenza è solo questa non c'è problema. Io credevo che si trattasse di una diversa configurazione dei cavi che potesse incidere sulla compatibilità con la SBC.
    Grazie molte.
  13. stecolumna
    stecolumna UDOOer
    May 20, 2016
    138
    33
    Dearest ccs_hello,
    I purchased the Seeedstudio sensor
    through Mouser.it
    The delivery was very fast.
    I have chosen the 50 cm. buckled cable.
    https://www.mouser.it/ProductDetail...=sGAEpiMZZMvxSQPygxWTpVCbDZDgPOC8ZKa4HtTajuA=
    I found a great wiki made by seeedstudio.com
    http://wiki.seeedstudio.com/Grove-CO2_Temperature_Humidity_Sensor-SCD30/
    which suggests taking the library and .ino sketches from github
    https://github.com/Seeed-Studio/Seeed_SCD30
    I have installed the aforementioned library and sketches and after
    ls -l /dev/ttyACM*
    I added the group to the username which in the case of Manjaro is not
    dialout
    as in Debian but
    uucp
    sudo usermod -a -G uucp stecolumna
    I have rebooted Manjaro to take effect
    I have uploaded the sketch SCD30_auto_calibration.ino but the serial monitor is empty.
    The output of the skecth is:
    /home/stecolumna/Scrivania/examples_ino/SCD30_auto_calibration/SCD30_auto_calibration.ino:7: warning: "SERIAL" redefined
        7 |     #define SERIAL Serial
    In file included from sketch/SCD30_auto_calibration.ino.cpp:1:
    /usr/share/arduino/hardware/archlinux-arduino/avr/cores/arduino/Arduino.h:54: note: this is the location of the previous definition
       54 | #define SERIAL  0x0
    /home/stecolumna/Scrivania/examples_ino/SCD30_auto_calibration/SCD30_auto_calibration.ino:6:65: note: #pragma message: Defined architecture for ARDUINO_ARCH_AVR.
        6 |     #pragma message("Defined architecture for ARDUINO_ARCH_AVR.")
    Lo sketch usa 8222 byte (28%) dello spazio disponibile per i programmi. Il massimo è 28672 byte.
    Le variabili globali usano 464 byte (18%) di memoria dinamica, lasciando altri 2096 byte liberi per le variabili locali. Il massimo è 2560 byte.
    what do you suggest me to do ?
  14. ccs_hello
    424
    162
  15. stecolumna
    stecolumna UDOOer
    May 20, 2016
    138
    33
