Hi, I am working on a project which is going to use opengl on the udoo. I encounter segfaults from some methods which appear to be coming from the vivante_dri.so. The same code runs fine under arch, ubuntu and debian on a normal pc (and valgrind does not detect any memoryissues). The first segfaults occures trying to get the shader compilation logs: Code: Program received signal SIGSEGV, Segmentation fault. strlen () at ../ports/sysdeps/arm/strlen.S:29 29../ports/sysdeps/arm/strlen.S: No such file or directory. (gdb) bt #0 strlen () at ../ports/sysdeps/arm/strlen.S:29 #1 0x2b004984 in __glim_GetShaderiv () from /usr/lib/dri/vivante_dri.so #2 0x2abbe3bc in glGetShaderiv () from /usr/lib/arm-linux-gnueabihf/libGL.so.1 A further segfault is thrown by glBindAttribLocation: Code: Program received signal SIGSEGV, Segmentation fault. 0x2b0252e0 in __glChipBindAttributeLocation () from /usr/lib/dri/vivante_dri.so (gdb) bt #0 0x2b0252e0 in __glChipBindAttributeLocation () from /usr/lib/dri/vivante_dri.so #1 0x2b005324 in __glim_BindAttribLocation () from /usr/lib/dri/vivante_dri.so #2 0x2abbe628 in glBindAttribLocation () from /usr/lib/arm-linux-gnueabihf/libGL.so.1 Uname returns: Linux udoobuntu 3.0.35 #10 SMP PREEMPT Wed Jul 30 18:16:10 CEST 2014 armv7l armv7l armv7l GNU/Linux Code reproducing the problem appended below (as *.cpp is not allowed for attachments). Compile with Code: gcc minimalGL.cpp -lGL -lglut -lGLEW -lstdc++ I fear the problem might be caused by an old version of udoobuntu or corrupted libs. So any hint is welcome. Kind regards, Matthias Code: #include <GL/glew.h> #include <GL/glut.h> #include <stdio.h> #include <string.h> #include <stdlib.h> #include <math.h> #include <iostream> //programs GLuint regProg; const GLfloat quad[4*3] = { /* down right */ -0.95, -0.95, 0.0, 0.95, -0.95, 0.0, -0.95, 0.95, 0.0, 0.95, 0.95, 0.0, }; const GLfloat texCoords[4*2] = { 0.f, 1.f, 1.f, 1.f, 0.f, 0.f, 1.f, 0.f, }; //////////////////////////////////////////////////////////////////////////////// void printShaderLog(GLuint shad) { GLint infoLogLength = 0; GLsizei charsWritten = 0; GLchar *infoLog; glGetShaderiv(shad, GL_INFO_LOG_LENGTH, &infoLogLength); if (infoLogLength > 0) { infoLog = new char[infoLogLength]; glGetShaderInfoLog(shad, infoLogLength, &charsWritten, infoLog); printf("%s\n",infoLog); delete[] infoLog; } } void printProgramLog(GLuint prog) { GLint infoLogLength = 0; GLsizei charsWritten = 0; GLchar *infoLog; glGetProgramiv(prog, GL_INFO_LOG_LENGTH, &infoLogLength); if (infoLogLength > 0) { infoLog = new char[infoLogLength]; glGetProgramInfoLog(prog, infoLogLength, &charsWritten, infoLog); printf("%s\n",infoLog); delete[] infoLog; } } //////////////////////////////////////////////////////////////////////////////// void renderScene(void) { glClear(GL_COLOR_BUFFER_BIT | GL_DEPTH_BUFFER_BIT); //clear buffer glUseProgram(regProg); glVertexAttribPointer( 0, 3, GL_FLOAT, GL_FALSE, 0, quad ); glVertexAttribPointer( 1, 2, GL_FLOAT, GL_FALSE, 0, texCoords ); glEnableVertexAttribArray(0); glEnableVertexAttribArray(1); glDrawArrays( GL_TRIANGLE_STRIP, 0, 4); glutSwapBuffers(); } int main(int argc, char **argv) { //Setup glut and glew glutInit(&argc, argv); glutInitDisplayMode(GLUT_DEPTH | GLUT_DOUBLE | GLUT_RGBA); glutInitWindowPosition(20,20); glutInitWindowSize(800, 600); glutCreateWindow("GLSL-Test"); glutDisplayFunc(renderScene); glutIdleFunc(renderScene); glewInit(); glEnable(GL_DEPTH_TEST); glClearColor(0.0,0.0,0.0,1.0); if (GLEW_ARB_vertex_shader && GLEW_ARB_fragment_shader&&GL_EXT_geometry_shader4)//) printf("Ready for GLSL\n"); else { printf("No GLSL support\n"); exit(1); } //Setup shaders GLuint v,f; v = glCreateShader(GL_VERTEX_SHADER); f = glCreateShader(GL_FRAGMENT_SHADER); const char* vv = "attribute vec4 vPosition;\ attribute vec2 per_vertex_tex_coord;\ varying vec2 tex_coord;\ void main(){ \ gl_Position = vPosition; \ tex_coord = per_vertex_tex_coord;\ } "; const char* ff = "varying vec2 tex_coord;\ uniform sampler2D tex;\ void main(){ \ gl_FragColor.rg = tex_coord; \ gl_FragColor.ba = vec2(0.0,1.1);\ }"; glShaderSource(v, 1, &vv,NULL); glShaderSource(f, 1, &ff,NULL); glCompileShader(v); glCompileShader(f); printShaderLog(v); printShaderLog(f); regProg = glCreateProgram(); glAttachShader(regProg,v); glAttachShader(regProg,f); glLinkProgram(regProg); printProgramLog(regProg); //MainLoop glutMainLoop(); return 0; }
