Environment : UDOO quad. The J18 jumper is not used( empty ). CN6 is not connected, ie I am using direct serial connection between iMX6 with SAM arduino. Potentiometer is connected to A0 pin on arduino. I am trying to send data from analog reading on the Arduino side via serial comm to iMX6. I can see the data being generated and print on the arduiono monitor. When I run Python code, I can see data on python side for about 8-10 lines then the error. ( see below ) Code: // Adruino code int ADCpin0 = A0; void setup() { Serial.begin( 9600); } void loop() { int myVal = analogRead(ADCpin0); Serial.println( myVal, DEC); delay(100); } # this is my Udoo linux python code( iMX6 side ) # reading serial data Code: #!/usr/bin/python import serial ser = serial.Serial(timeout=1); ser.port = "/dev/ttymxc3" ser.baudrate = 9600 ser.open() data = "" try : while True: ch = ser.read() # **** while ch != '\n': data = data + ch ch = ser.read() print "Data: " + data data = "" except Exception, e : print "error ::" + str(e ) Result on python screen Code: Data: 167 Data: 166 Data: 12 error ::device reports readiness to read but returned no data (device disconnected or multiple access on port?) I also tried ser.readline() #**** It gave the same error. Question : what is causing this error mesage ? Thanks. samira
