Just a quick hack to pilot/read the UDOO from the web/lan, requires node, node-udoo, and that you run this script in node: Code: ubuntu@udoo:~/nodeweb$ node /home/ubuntu/nodeweb/main.js Server running at port 8080/ Node v0.10.22 arm After this the UDOO will be accessible from the lan (or the web if you configure your routers right). Code: http://<UDOO ip>/set/?p10=hi will light up a led connected to pin 10 Code: // Example of accessing pins from the web // copyleft Francesco Munafò // Use as you wish. // This is not throughly tested code, just a quick hack prototype // It does seem to work though // Sample: // API to get pin values // http://127.0.0.1:8080/get/?p12&p13&p10 // result: {"p12":"false","p13":"false","p10":"false"} // API to set pin values // http://127.0.0.1:8080/set/?p12=hi&p13=lo&p10=hi // result should be ignored same as below with no params // if you connect to http://127.0.0.1:8080/ with no params you can see a little web page sample to handle pins 10-13 by clicking links. var udoo = require('udoo'); var util = require('util'); var http = require('http'); var url = require('url') ; var fs = require('fs'); var querystring=require('querystring'); udoo.reset() http.createServer(function (req, res) { var parsedUrl = url.parse(req.url,true); var getData = parsedUrl.query; var urlData = parsedUrl.pathname; var postData = ""; res.outputPins=[]; res.pinsAdded=0; res.pinsDone=0; res.done=false; req.on('data', function (chunk) { postData += chunk; }); req.on('end', function () { handleRequest(req,res,urlData,getData,querystring.parse(postData)); }); }).listen(8080); var postHTML1 = '<html><head><title>Control Panel</title></head>' + '<body>' + '<div>10 | <a href="/set/?p10=hi">on</a>' +' <a href="/set/?p10=lo">off</a></div>' + '<div>11 | <a href="/set/?p11=hi">on</a>' +' <a href="/set/?p11=lo">off</a></div>' + '<div>12 | <a href="/set/?p12=hi">on</a>' +' <a href="/set/?p12=lo">off</a></div>' + '<div>13 | <a href="/set/?p13=hi">on</a>' +' <a href="/set/?p13=lo">off</a></div>'; '<div>all <a href="/get/?p10&p11&p12&p13" target="_blank">get</a></div>'; var postHTML2 = '</body></html>'; var postHTML = postHTML1+postHTML2; function handleRequest(req,res,urlData,getData,postData) { var pin,val; var doSet=false; var doGet=false; var callbacks=[]; // Suggested use is /get/ as a directory with final slash if(urlData=="/get" || urlData=="/get/" || urlData=="/get.php") { doSet=false; doGet=true; } else if(urlData=="/set" || urlData=="/set/" || urlData=="/set.php") { doSet=true; doGet=false; } else { res.end(postHTML); return; } var pins=[]; var pinsCount=0; var done=false; for(var it in getData) { pin=(it); val=getData[it]; if(pin.substr(0,1)=="p") { pin=pin.substr(1); pin=parseInt(pin); console.log("\nPIN: "+pin+" "+val); if(doSet) { var led=udoo.outputPin(pin); if(val==="hi" || val=="on" || val=="high" || val=="255") { led.setHigh(); } else if(val==="lo" || val=="off" || val=="low" || val=="0") { led.setLow(); } else { led.set(parseInt(val)); // NOT SUPPORTED YET BY NODEUDOO } } else { res.pinsAdded++; var led=udoo.inputPin(pin); // console.log("\nSEARCH "+'p'+pin+"=?"); getAndSave(led,pin,res); } } } res.done=true; // console.log("\nTEST "+res.outputPinsCount+">="+pinsCount); if(res.pinsDone>=res.pinsAdded) { console.log("done after loop."); shootout(res); } } function getAndSave(led,apin,res) { var apin2=apin; led.get(function(err,val) { var tmp=0+apin2; res.outputPins["p"+tmp]=val; if(res.done) console.log("GOT(d) "+'p'+tmp+"="+val); else console.log("GOT "+'p'+tmp+"="+val); res.pinsDone++; if(res.done && res.pinsDone>=res.pinsAdded) { console.log("done after received data."); shootout(res); res.pinsDone=-1; } }); } function shootout(res) { // res.write("URL "+util.inspect(urlData)); // res.write("GET "+util.inspect(getData)); // res.write("POST "+util.inspect(postData)); console.log(res.outputPins); var out="{"; var sep=""; for(var it in res.outputPins) { out+=sep+'"'+it+'":"'+res.outputPins[it]+'"'; sep=","; } out+='}'; if(out=="{}") { res.setHeader("Content-Type", "text/html"); res.writeHead(200); res.end(postHTML); } else { res.setHeader("Content-Type", "text/plain"); res.writeHead(200); // res.write(postHTML1); // res.write(out); // res.end(postHTML2); res.end(out); } // console.log("\nCLOSE."); } console.log('Server running at port 8080/ Node '+process.version+ ' '+process.arch); Have fun! UDOO Rocks.
Thanks it works fine. My idea was the same project as http://ni-c.github.io/heimcontrol.js/ I planning a smiliar Frontend with Express, Jade and Stylus with Bootstrap-Buttons
