Can I share the Udoo's internet connection to SAM3x Arduino due processor? Or I must use a ethernet shield?
Hi directly no. But I use the script in python. Deamon is listening on any port and transfer command to the COM port shared with SAM x.
Code: #!/usr/bin/env python3 # script by Patrik Hora #IMPORT LIB import sys import multiprocessing from time import * import serial import configparser import os import json import socket, ssl #READ CONFIG FILE config = configparser.ConfigParser() config.read('/etc/hato/config.ini') #VAR Ardu_ID=config['Arduino']['ID'] line = "" jobs = [] arduino_blocked = multiprocessing.Value('b', 0) arduino_cmd_list =('Ident','Report','Set:') linux_cmd_list = ('Cron','ShutDown', 'Restart') try: f = open("/run/hatodaemon.pid", "w") try: f.write(str(os.getpid())) # PID finally: f.close() except IOError: pass #LINUX CMD def linux_cmd(cmd): if cmd.startswith(linux_cmd_list): if cmd.startswith('ShutDown'): os.system("shutdown -h now") if cmd.startswith('Restart'): os.system("reboot") if cmd.startswith('Cron'): os.system('crontab -l | grep -v "WASH" | { cat; echo "15 0 * * * /etc/hato/socket_client.py \"Set:TS03:1200;\" #WASH"; } | crontab') #COMM WITH ARDUINO def arduino(cmd): timeout = time() + 5 while arduino_blocked.value==1 and timeout > time(): pass arduino_blocked.value = 1 try: serial_port = serial.Serial('/dev/ttymxc3', baudrate=115200, timeout=3) except serial.SerialException as e: print("could not open serial port '{}': {}".format(com_port, e)) serial_port.write(cmd.encode('utf-8')) lines = [] while True: try: line = serial_port.readline() except: tb = sys.exc_info() print(tb) timeout = time() + 0.1 while not serial_port.inWaiting() and timeout > time(): pass if not serial_port.inWaiting(): break serial_port.close() arduino_blocked.value = 0 return str(line.decode('ascii').rstrip()) ## SOCKET ON PORT 15000 bindsocket = socket.socket() bindsocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1) bindsocket.bind(('', 15000)) bindsocket.listen(5) def do_something(connstream, data): try: f = open("/etc/hato/log/hatodaemon.log", "a") try: f.write(str(time())) # PID f.write(str(data)) # PID f.write("\n") # PID finally: f.close() except IOError: pass tmp=(data).decode('utf-8') if tmp.startswith(arduino_cmd_list): txt=arduino(tmp) if tmp.startswith(linux_cmd_list): txt=linux_cmd(tmp) connstream.sendall(txt.encode('utf-8')) def socket_instance(): try: timeout = time() + 2 connstream = ssl.wrap_socket(newsocket,server_side=True,certfile="/etc/hato/cert.pem",ca_certs="/etc/hato/cert.pem",ssl_version=ssl.PROTOCOL_TLSv1,cert_reqs=ssl.CERT_REQUIRED) except: tb = sys.exc_info() print(tb) else: deal_with_client(connstream) finally: connstream.shutdown(socket.SHUT_RDWR) connstream.close() def deal_with_client(connstream): data = connstream.recv(1024) while data: if not do_something(connstream, data): break data = connstream.recv(1024) print(data) while True: try: newsocket, fromaddr = bindsocket.accept() except: tb = sys.exc_info() print(tb) else: p = multiprocessing.Process(target=socket_instance) jobs.append(p) p.start() Code: function Connect_to_unit ($UID,$CMD,$IP) { $sslPem = "/cert/$UID.pem"; $streamContext = stream_context_create(); stream_context_set_option($streamContext, 'ssl', 'local_cert', dirname(__FILE__) . '/' . $sslPem); $server = stream_socket_client("ssl://$IP:15000", $error, $errorString, 5, STREAM_CLIENT_CONNECT, $streamContext); stream_set_timeout($server, 10); if (!$server) { echo "$errorString ($error, )<br />\n"; return ("ERR"); } else { fwrite($server, $CMD); $buffer = fgets($server, 1024); $JsonData=json_decode($buffer); if ($buffer === null && json_last_error() !== JSON_ERROR_NONE) { fwrite($server, 'ERR'); fclose ($server); die('ERR'); } fwrite($server, 'OK'); fclose ($server); return($JsonData); } }
