I'm using the Ubuntu system 11.01 just out of the box. I'm connected with my network but I don't have any acces to Internet. If I trie to do the upgrade (with the terminal) I've Code: Connecting to download.udoo.org|83.147.100.13|:80... connected. HTTP request send, awaiting response ... After a time (connection timed out / Retrying...) Code: awaiting response ...200 OK Lenght 5154965 (4.9M) [application/x-gzip] Saving to: 'udooupdate.tar.gz' And more connections timeout / retrying.... Is that normal?
Re: Connected but no Internet access Hi, Which are the result of these command: root@udoo#cat /etc/resolv.conf root@udoo#ifconfig root@udoo#route Thanks!
Re: Connected but no Internet access Thank you, This is the result !: ubuntu@udoo:~$ sudo -i root@udoo:~# cat /etc/resolv.conf # Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8) # DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN nameserver 127.0.0.1 search Belkin # Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8) # DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN nameserver 192.168.0.250 nameserver 192.168.0.249 nameserver 192.168.2.250 search seco.it root@udoo:~# ifconfig eth4 Link encap:Ethernet HWaddr 00:c0:08:88:17:2d UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) lo Link encap:Local Loopback inet addr:127.0.0.1 Mask:255.0.0.0 UP LOOPBACK RUNNING MTU:16436 Metric:1 RX packets:269 errors:0 dropped:0 overruns:0 frame:0 TX packets:269 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:0 RX bytes:39209 (39.2 KB) TX bytes:39209 (39.2 KB) usb0 Link encap:Ethernet HWaddr 16:35:c4:22:88:d8 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) wlan4 Link encap:Ethernet HWaddr 7c:dd:90:3e:8d:4c inet addr:192.168.2.9 Bcast:192.168.2.255 Mask:255.255.255.0 UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:1168 errors:0 dropped:0 overruns:0 frame:0 TX packets:855 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:249735 (249.7 KB) TX bytes:107239 (107.2 KB) root@udoo:~# route Kernel IP routing table Destination Gateway Genmask Flags Metric Ref Use Iface default 192.168.2.1 0.0.0.0 UG 0 0 0 wlan4 192.168.2.0 * 255.255.255.0 U 2 0 0 wlan4 root@udoo:~#
Re: Connected but no Internet access Following the consideration of rkwiles http://www.udoo.org/forum/viewtopic.php?f=6&t=612 I've tried different places and its working now
