[SOLVED] High CPU Load
Discussion in 'Kernels' started by aureq, Oct 26, 2013.
  1. trunet
    trunet New Member
    Oct 25, 2013
    17
    Re: High CPU Load
    I applied the patch and it worked perfectly BTW.
  2. bilsch
    bilsch New Member
    Jun 9, 2013
    Re: High CPU Load
    I submitted a pull request with the change incorporated.
    If anyone is curious, here are the steps:
    git clone https://github.com/UDOOboard/Kernel_Unico.git
    cd Kernel_Unico
    git remote add imx6-dongle https://github.com/imx6-dongle/linux-imx.git
    git fetch imx6-dongle
    git cherry-pick b8a4b014ead3840271b00948b4970051b13e4ff2
    Then build the kernel as described in http://udoo.org/download/files/Document ... 0_2013.pdf
    root@imx6-qsdl:/lib/modules/3.0.35-gdfb7761-dirty# w
    18:45:58 up 2:15, 1 user, load average: 0.49, 0.40, 0.42
    USER TTY FROM LOGIN@ IDLE JCPU PCPU WHAT
    ubuntu pts/0 192.168.1.213 16:31 0.00s 0.38s 0.26s sshd: ubuntu
    Load average is way down and the system seems a little more responsive now too
  3. maara
    maara Member
    Jun 11, 2013
    44
    Re: High CPU Load
    Could you please send me your kernel image?
  4. bilsch
    bilsch New Member
    Jun 9, 2013
    Re: High CPU Load
    Sure, https://dl.dropboxusercontent.com/u/863 ... -dirty.tgz
    To install it, here are the steps:
    1) tar -xzf udoo-quad-3.0.35-gdfb7761-dirty.tgz
    --- warning, creates a dir called 'udoo'
    2) cd udoo
    3) sudo cp /boot/uImage /boot/uImage-old
    4) sudo cp uImage /boot
    5) sudo cp -a lib/modules/3.0.35-gdfb7761-dirty /lib/modules
    6) shutdown -r now
    This kernel is the default udoo config. At least on my board, the sata port does not seem to show the disk ( there is one ;) ). I have not had time to debug it
  5. maara
    maara Member
    Jun 11, 2013
    44
    Re: High CPU Load
    Thanks! The load is resolved... :)
    Now I need to dive into the overall slowness of the linaro :-D
  6. DracoLlasa
    DracoLlasa UDOOer
    Oct 15, 2013
    419
    Re: High CPU Load
    yep confirmed, that was a much simpler way of applying the fix and its working well on my board
  7. Taillo
    Taillo New Member
    Oct 29, 2013
    10
    Re: High CPU Load
    The patch can be apply in dual udoo ? My load is ~ 2 .
  8. aureq
    aureq New Member
    Oct 25, 2013
    17
    Re: High CPU Load
    Hi Taillo
    Technically, that patch should be safe for the udoo dual.
    Would be nice if you could post any feedback on that
    cheers
  9. andcmp
    andcmp New Member
    161
    Re: High CPU Load
    As I see from the feedbacks, the patch works fine so it will be added to the next releases!
  10. Lifeboat_Jim
    Lifeboat_Jim New Member
    Sep 16, 2013
    399
    Re: High CPU Load
    Yes, no issues at all with this patch - many happy UDOO'ers in IRC have applied this.
  11. saidol
    saidol New Member
    Oct 3, 2013
    24
    [SOLVED] Re: High CPU Load
    Marked thread as solved.
  12. delba
    1,063
    Thanks ;)
