[SOLVED] I2C slow
Discussion in 'UDOO NEO' started by Gorgo, Jun 5, 2017.
  1. jas-mx
    jas-mx Active Member
    Dec 31, 2013
    407
    118
    Gorgo likes this.
  2. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    159
    17
  3. jas-mx
    Dec 31, 2013
    407
    118
    In the dts i2c-1 (i2c@021a4000) is still active (status = "okay";) , needs to be disabled. You can disable it manually by changing following in imx6sx-udoo-neo-externalpins.dtsi in your kernel source tree:
    &i2c2 {
    status = "disabled";
    Then compile imx6sx-udoo-neo-full-hdmi-m4.dtb in the kernel source tree and copy to the overlay directory on your sd card.
  4. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    159
    17
    Does it mean that my device tree editor is broken? :( Why?
    In order to change my imx6sx-udoo-neo-externalpins.dtsi, should I recompile all the kernel following THIS?
    So, Changing ~/udoo-dev/linux_kernel/arch/arm/boot/dts/imx6sx-udoo-neo-externalpins.dtsi and then:
    ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make zImage -j5
    ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make dtbs -j5
    ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- make modules -j5
    cp arch/arm/boot/dts/*.dtb $BOOT_PARTITION/dts-overlay
    Do you confirm?
  5. jas-mx
    Dec 31, 2013
    407
    118
    I don't use device tree editor so I don't.
    You need to do something like this:
    cp arch/arm/boot/dts/imx6sx-udoo-neo-full-hdmi-m4.dtb $BOOT_PARTITION/dts-overlay
  6. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    159
    17
    Ok, current status:
    - /dev/i2c-1 doesn't exist now. Correct.
    - Sketch starts everytime without hangs. Perfect
    - I added a delay(2000) between Wire.begin() and bmp.begin(). Without it, it fails getting the starting value and it doesn't detect the sensor. Okay
    - UART6 stops working. Bad I suspect that overwriting the dbs, changed something from @ektor5 's fix (https://www.udoo.org/forum/threads/a9-uart6-and-udoobuntu.3196/page-3#post-25705) or I should reactive it from the dts.
    How? My device tree editor shows the previous settings (UART6 and UART1 enabled). I tried to re-set them, save and reboot, but uart6 is not working (ttymxc5 is missing).
  7. waltervl
    So a preliminary conclusion could be that detaching I2C-2 from A9 through the device tree editor is not working?
  8. jas-mx
    Dec 31, 2013
    407
    118
    Just enable uart6 in the same dts (imx6sx-udoo-neo-externalpins.dtsi) , eg:
    &uart6 {
    status = "okay";
  9. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    159
    17
    Now /dev/ttymxc5 is up but I can't get data from it.
    Should I fix the kernel with the old .c fix we used to do or should I use ektor5's fix again?
  10. jas-mx
    Dec 31, 2013
    407
    118
    I can't diagnose your problem as there could be numerous reasons for it to occur and I don't know about your kernel fix or environment setup.
  11. Gorgo
    Gorgo UDOOer
    Nov 9, 2016
    159
    17
    Ok, after some further checks with @ektor5, we blamed the device editor as we said in this topic too.
    The i2c problem was due to the presence of the i2c-2 in M4 and A9 in the same time.
    I flashed a new image, edited the device tree editor removing the i2c-2 and everything worked. No more hangs on Wire library on M4.
    Udoo Team also released a new image (Udoobuntu 2.1.3) with the UART6 patch inside!! :D
    Actually he told me to update+upgrade a new image and everything is working now.
