(solved) perl: warning: Setting locale failed.
Discussion in 'UDOO 101' started by alexandros301, Mar 22, 2014.
Thread Status:
Not open for further replies.
  1. alexandros301
    alexandros301 Member
    Mar 22, 2014
    40
    Hi all,
    New to this forum and to Udoo. Just got my Udoo quad and I'm running it with ssh. It seems to be quite ok since I did an apt-get update and I installed Pure Data also with apt-get install. Though I'm getting an error message when I type /usr/bin/pd, which is
    Application initialization failed: no display name and no $DISPLAY environment variable
    and I'm also getting some other errors when I'm installing stuff (e.g. automake and libtool), and when I'm in the Desktop directory and I type ./chromium-browser.desktop no browser is launched and I get the following messages:
    perl: warning: Please check that your locale settings:
    	LANGUAGE = (unset),
    	LC_ALL = (unset),
    	LC_CTYPE = "UTF-8",
    	LANG = (unset)
        are supported and installed on your system.
    perl: warning: Falling back to the standard locale ("C").
    	LANGUAGE = (unset),
    	LC_ALL = (unset),
    	LC_CTYPE = "UTF-8",
    	LANG = (unset)
    Warning: unknown mime-type for "./chromium-browser.desktop" -- using "application/octet-stream"
    Error: no "view" mailcap rules found for type "application/octet-stream"
    	LANGUAGE = (unset),
    	LC_ALL = (unset),
    	LC_CTYPE = "UTF-8",
    	LANG = (unset)
    Opening "./chromium-browser.desktop" with gedit  (application/x-desktop)
    (process:6046): Gtk-WARNING **: Locale not supported by C library.
    	Using the fallback 'C' locale.
    Cannot open display:
    Run 'gedit --help' to see a full list of available command line options.
    /usr/bin/xdg-open: 461: /usr/bin/xdg-open: links2: not found
    /usr/bin/xdg-open: 461: /usr/bin/xdg-open: links: not found
    /usr/bin/xdg-open: 461: /usr/bin/xdg-open: lynx: not found
    /usr/bin/xdg-open: 461: /usr/bin/xdg-open: w3m: not found
    xdg-open: no method available for opening './chromium-browser.desktop'
    Can anyone give a hint?
    Thanks,
    Alexandros
  2. alexandros301
    Mar 22, 2014
    40
    Solved, I had to use the -X flag for ssh so that udoo could display the GUI. It's working now. So the command is ssh -X ubuntu@ip_address
  3. delba
    1,064
    Great, i'm closing the thread then.
Thread Status:
