When I first got my Udoo I installed the Linaro image and worked a bit on that. Later on I installed a Debian Wheezy image on another SD card but the board kept the same IP address and when I tried to connect via SSH I got this Code: @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ @ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @ @@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@ IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY! Someone could be eavesdropping on you right now (man-in-the-middle attack)! It is also possible that a host key has just been changed. The fingerprint for the RSA key sent by the remote host is 02:d5:2b:40:a0:82:d4:f0:45:65:50:57:cc:31:e0:7d. Please contact your system administrator. Add correct host key in /Users/alexandrosdrymonitis/.ssh/known_hosts to get rid of this message. Offending RSA key in /Users/alexandrosdrymonitis/.ssh/known_hosts:4 RSA host key for 192.168.2.12 has changed and you have requested strict checking. Host key verification failed. the /Users/alexandrosdrymonitis/.ssh/known_hosts file contains this line (along with a few others) Code: 192.168.2.12 ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQC59gujYLyyLwCkVlVPj0JUzn7O/ijxcUC4/ZdSm8XiyYOQo5sxqfJnBqvogL8aB+ri71OCpjM7qayOzd/ElklfFeBoM9FqIXys$XkXcI3uW7kW92gO9SIINU4RfWYjZldYn+ZpQMhPF/4D7nONFZJR873UnLPD62e63DUIyIXAacib0558M4SUW0dUyDlhfej4N3DYmBwDNihwFTEohJjm55bY1APvsGeOVWcI650bG+hvO0jb2UK2z$TXp+MDJYqQWD2nNOFy8iz0p6aKcCR5gvVtQM59APe+DLWkmRWUeiTarJhqggPc6BO660keQ/7Aa4bKralcj8ls9TUXNJNoXt which is the IP the Udoo gets on boot. What I do is connect via USB using Serial Tools (on OS X) and change the IP like this Code: sudo ifconfig eth0 192.168.2.13 up (got it from some tutorial) and then log in via SSH with the new IP. The problem is that I have to deviate every time I wanna use the Udoo and when I connect via SSH I don't get an internet connection... What should I edit in /Users/alexandrosdrymonitis/.ssh/known_hosts to solve this?
Re: Problems connecting via SSH Try backing up /Users/alexandrosdrymonitis/.ssh/known_hosts and deleting what`s inside. That way it should install the new key !!!!
