[SOLVED] rebooting probem when booting with android image
Discussion in 'General Discussion' started by praveen, Nov 9, 2013.
  1. praveen
    praveen New Member
    Nov 9, 2013
    10
    I have a udoo quad board, Initially i booted udoo with android image the was no issue. I connected the udoo board to laptop using usb to micro usb through serial port (CN6), the rebooting problem started.
    The udoo board boots with android stays on android lock screen for 5 secs then reboots. This happens repeatedly
    any one facing this problem ?
  2. andcmp
    andcmp New Member
    161
    Re: rebooting probem when booting with android image
    My trouble shooting check list would be:
    - check for the power adapter if actually supply enough power (between 6 and 15V and at least 1A but I would prefer 2A)
    - you did't mentioned the lan cable, if you have the lan cable plugged in, disconnect it and check if the board works properly
    - check what Android version you're running, ES File Explorer app is already installed? if not, you're running the older version and you need to update
    Anyway, my general suggestion is to reimage your micro SD card with the latest Android image available on our website: www.udoo.org/downloads/ following this step by step guide: http://www.udoo.org/getting-started/cre ... rom-image/
  3. praveen
    praveen New Member
    Nov 9, 2013
    10
    After updating the android os the problelm has been solved.
  4. delba
    1,064
    Glad to hear that!
