Hi guys! I've just bought my Udoo Neo and I'm trying to connect to a WPA2 Enterprise network. I've flashed UDOObuntu 2.1 (NOT minimal). First kernel image: Linux udooneo 3.14.56-udooneo-02023-g8d371df I set the current date (otherwise I can't update any packages because of certificate verification errors), then update && upgrade. Updated kernel image: Linux udooneo 3.14.56-udooneo-02041-g77702fa wpa_supplicant.conf: Code: network={ ssid="eduroam" key_mgmt=WPA-EAP pairwise=CCMP group=CCMP TKIP eap=TTLS ca_cert="/home/udooer/.cat_installer/ca.pem" identity="USER@upmc.fr" domain_suffix_match="radius.upmc.fr" phase2="auth=PAP" password="******" anonymous_identity="anonymous@upmc.fr" } If I try to connect it tries to read a p2p-dev-wlan0 interface that doesn't exist. Code: udooer@udooneo:~$ sudo wpa_supplicant -B -iwlan0 -c/home/udooer/.cat_installer/cat_installer.conf Successfully initialized wpa_supplicant Could not read interface p2p-dev-wlan0 flags: No such device nl80211: Could not set interface 'p2p-dev-wlan0' UP nl80211: deinit ifname=p2p-dev-wlan0 disabled_11b_rates=0 p2p-dev-wlan0: Failed to initialize driver interface P2P: Failed to enable P2P Device interface Setting the conf header with p2p_disabled=1 doesn't solve the problem.
I have no Neo with Wifi so cannot help you directly. I see you are editing files directly. What if you try the folllowing from the manual: Connecting to Wi-Fi networks You can connect to wireless networks by: using the Web Control Panel, in Configuration/Network settings; using the network utility in the UDOObuntu desktop environment (in the bottom-right corner).
Hi Waltervl I'm not a masochist I need to connect via terminal instead of NetworkManager gui. The web control panel doesn't support Eduroam (It wants a specific AP but in my case the university is a ESS network) since it shows multiple networks with the same SSID. I succeded in connect to eduroam (WPA2 802.1X) with my Udoo QUAD (Arch) and I must do the same with the quad.
It doesn't have to be eduroam. I'd like a working wpa_supplicant to start. In this case the package in Udoobuntu seems broken since It doesn't detect wlan0 as interface. An expert friend of mine told me this should be a broken version of wpa_supplicant but I let the devs to check it.
SEMI-SOLVED: Interfaces: Code: udooer@Pizzicottina:~$ less /etc/network/interfaces # Loopback network interface auto lo iface lo inet loopback # Wifi eduroam auto wlan0 iface wlan0 inet dhcp wpa-driver nl80211 wpa-conf /etc/wpa_supplicant.conf # Primary network interface #auto eth0 #iface eth0 inet dhcp # USB OTG connection allow-hotplug usb0 iface usb0 inet static address 192.168.7.2 netmask 255.255.255.252 wpa_supplicant.conf Code: udooer@Pizzicottina:~$ cat /etc/wpa_supplicant.conf ctrl_interface=/var/run/wpa_supplicant network={ ssid="eduroam" key_mgmt=WPA-EAP pairwise=CCMP group=CCMP TKIP eap=TTLS ca_cert="/home/udooer/.cat_installer/ca.pem" identity="USER@upmc.fr" domain_suffix_match="radius.upmc.fr" phase2="auth=PAP" password="*********" anonymous_identity="anonymous@upmc.fr" } When I reboot there's a working wpa_supplicant: Code: udooer@Pizzicottina:~$ ps -aux | grep wpa root 840 0.1 0.2 5256 2284 ? Ss 2015 0:00 /sbin/wpa_supplicant -s -B -P /run/wpa_supplicant.wlan0.pid -i wlan0 -D nl80211 -c /etc/wpa_supplicant.conf ifconfig Code: udooer@Pizzicottina:~$ ifconfig wlan0 wlan0 Link encap:Ethernet HWaddr 5c:31:3e:28:22:56 inet6 addr: fe80::5e31:3eff:fe28:2256/64 Scope:Link UP BROADCAST MULTICAST MTU:1500 Metric:1 RX packets:18 errors:0 dropped:0 overruns:0 frame:0 TX packets:16 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:10410 (10.4 KB) TX bytes:1320 (1.3 KB) At this moment I wonder why the dhcp doesn't work dynamically (It's in the interface file) but if I type: Code: sudo dhclient wlan0 -v Listening on LPF/wlan0/5c:31:3e:28:22:56 Sending on LPF/wlan0/5c:31:3e:28:22:56 Sending on Socket/fallback DHCPREQUEST of MYIP on wlan0 to 255.255.255.255 port 67 (xid=0x610f477f) DHCPREQUEST of MYIP on wlan0 to 255.255.255.255 port 67 (xid=0x610f477f) DHCPREQUEST of MYIP on wlan0 to 255.255.255.255 port 67 (xid=0x610f477f) DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 3 (xid=0xa608f045) DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 3 (xid=0xa608f045) DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 4 (xid=0xa608f045) DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 6 (xid=0xa608f045) DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 10 (xid=0xa608f045) DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 12 (xid=0xa608f045) DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 13 (xid=0xa608f045) DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 21 (xid=0xa608f045) DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 9 (xid=0xa608f045) DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 11 (xid=0xa608f045) DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 8 (xid=0xa608f045) DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 11 (xid=0xa608f045) DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 14 (xid=0xa608f045) DHCPDISCOVER on wlan0 to 255.255.255.255 port 67 interval 19 (xid=0xa608f045) DHCPREQUEST of MYIP on wlan0 to 255.255.255.255 port 67 (xid=0x45f008a6) DHCPOFFER of MYIP from 2.2.2.2 DHCPACK of MYIP from 2.2.2.2 bound to MYIP -- renewal in 1407 seconds. And it works.
