Hi, I have connected a HTMI to VGA converter to my UDOO, and connected to my 1280x1024 VGA monitor. Works fine except that it keeps using 1920x1080 resolution. I have tried to add my resolution manually but when I try to change to it, it says that my minimum resolution is 1920x1080 and doesn't allow to do that. Below is output from xrandr: Code: ubuntu@imx6-qsdl:~$ xrandr xrandr: Failed to get size of gamma for output default Screen 0: minimum 1920 x 1080, current 1920 x 1080, maximum 1920 x 1080 default connected 1920x1080+0+0 0mm x 0mm 1920x1080 60.0* How to change minimum resolution to something smaller? Thanks in advance, Gediminas
Re: Using HDMI>VGA convertor, how to change minimum resoluti Hi I solved a similar problem changed the resolution at boot with Code: setenv setvideomode 'setenv videomode video=mxcfb0:dev=hdmi,1024x768@60,bpp=32' You can find more info at this topic viewtopic.php?f=16&t=193&start=30 Regards
Re: Using HDMI>VGA convertor, how to change minimum resoluti Yep, you may need to override a couple of Environmental variables at boot time. (Team UDOO are working on display/resolution issues of course, so this is an interim solution). Note: HDMI -> whatever adapters can have their own problems.
Re: Using HDMI>VGA convertor, how to change minimum resoluti Great! Can we add [SOLVED] to the topic title?
