spdif out
Discussion in 'UDOO X86' started by Triodefreak, Mar 22, 2017.
  1. Paede
    Paede New Member
    Jul 8, 2017
    10
    Is there a plug'n'play module the does this?
  2. ccs_hello
    536
    194
    Unfortunately, no. Perhaps it can be built by forum members or UDOO/SECO.
  3. JonathanNet
    JonathanNet New Member
    Aug 9, 2016
    Yeah I also had same question about an plug n play module like on the raspberry pi 2 I bought for that :)
    And It was also a forum member that made that, and sold them on the forum.
  4. Paede
    Paede New Member
    Jul 8, 2017
    10
  5. ccs_hello
    536
    194
    First link (SO-14 package) is the right one. <-- this is SOP-14 package with 1.27mm pitch
    Second linked one is even tinier (0.65mm pitch.)
    Braswell SPDIF out goes to "1A" (pin 1).
    1Y (pin 2) goes to 2A (pin3), 3A (pin5), and 4A (pin 9).
    Tie 2Y (pin4), 3Y (pin6), and 4Y (pin8) together to connect to C1 (100nF.)
    Gnd (Pin 7) goes to ground and Vcc (pin14) goes to 1.8V.
    I usually recommend people to buy a SOP14 Breakout
    (e.g., http://www.ebay.com/itm/5pcs-SOP14-SSOP14-SMD-to-DIP-Breakout-Board-0-65-1-27mm-/301427210226 )
    board from fleabay or aliexpress to help your circuit layout (if you are not building a custom PCB.)
    ccs_hello
  6. Markus Laire
    Markus Laire Active Member
    Mar 9, 2017
    225
    91
    Can someone explain the use of inverters here. Why single inverter first and then three in parallel?
  7. ccs_hello
    536
    194
    Inverter serves as a digital buffer. Inverting cascaded by another inverting becomes non-inverting.
    The second stage has 3 parallel units to gain more driving capability.
    Bottom-line is this, it's a $0.03 part (in quantity) with 6 unit of inverters, isolating/protecting a $20 - $30 Braswell SoC's SPDIF weak digital output, to drive a SPDIF receiver.
    Markus Laire likes this.
  8. JCSelector
    JCSelector UDOOer
    Jun 23, 2017
    19
    Please keep us informed of your results, I would also like to use spdif. Thanx.
  9. Paede
    Paede New Member
    Jul 8, 2017
    10
    I drawed a schematic in Fritzing:
    Is that correct?
    Can I use the 1.8V from Expansion Socket #2 Pin 20?
    Sjonno and Markus Laire like this.
  10. ccs_hello
    536
    194
    Yes and yes (CN13 Expansion Socket #2, pin 20.)
    Paede likes this.
  11. Paede
    Paede New Member
    Jul 8, 2017
    10
    Cnc machined PCB
    Ill post links to the file when it really does work.
    Sjonno and waltervl like this.
  12. Paede
    Paede New Member
    Jul 8, 2017
    10
    I soldered the pcb today, but in windows 10 I do not have a spdif in the device manager or in the sound configuration.
    Do I have to activate the spdif somehow?
  13. ccs_hello
    536
    194
    The SPDIF Out signal came from HD Codec IC: ALC283, not from Braswell.
    I would start to check in Audio output selection, if there is an option to pick SPDIF_Out.
  14. ccs_hello
    536
    194
    It looks like ALC283 internals are mainly running on 3.3V and its SPDIF digital signal is also using 3.3v logic level.
    Using 3.3V based SPDIF driving system is much easier than the ultra-low 1.8V version.
  15. Paede
    Paede New Member
    Jul 8, 2017
    10
    i have no spdif device in win10 (see screenshot)
    I did not see where in the bios I could activate spdif. I hope udoo give some advice how to use spdif ...
    can I use spdif (once it is recognised by windows) without the pcb I soldered?
  16. ccs_hello
    536
    194
    You can use that buffer board still, just connect the power feed to 3.3V instead of 1.8V.
    It is a rather standard design to have a buffer. It helps protecting the more $$$ expensive circuit.
    I.e., a 20-cent buffer IC vs. the cost of the UDOO x86 board (actually $5 ALC283 chip but very hard to replace.)
    For emergency use, I'm guessing no buffer is an option.
    ccs_hello
    Paede likes this.
  17. ccs_hello
    536
    194
    Definitely turn on SPDIF output in BIOS.
    Reinstall Realtek HD Audio driver. This time, it should also install "Digital Audio" portion of the driver.
    Go to Realtek HD Audio manager, select "Speaker", choose Digital Output instead of Analog output.
    Paede likes this.
  18. Paede
    Paede New Member
    Jul 8, 2017
    10
    How?
    In the audio section 4.3.4.2 of the manual I set like this:
    Audio controller enabled
    Azalia hdmi codec enabled
    Mute hda amplifier disabled
    Where can I enable spdif in bios?
  19. ccs_hello
    536
    194
    Suggest you open a ticket asking UDOO BIOS firmware designer to tell you the proper configuration.
    From Internet search, the issue seems to be related to
    Intel Braswell's HDMI video + "digital audio" output is fighting with Azalia HD "Digital" Output (and HDMI's won.)
    In some brand's BIOS config, some folks said set On-board Azalia Audio to "Enabled" (not Disabled or Auto) then select "Digital Audio Output" to an option that is NOT HDMI Audio.
    Quote
    "Nonetheless I seem to have resolved my issue. How, I do not know. I went in and deleted the drivers for NVidia and reinstalled AGAIN the Realtek drivers, then rebooted. It still auto installed the Nvidia High Def drivers AGIAN without warning after reboot but when I looked in my Playback Devices, SPDIF was now there. " <-- Nvidia is the combined HDMI video+audio
  20. goldio
    goldio New Member
    Apr 14, 2017
    10
    Are there any news how to get SPDIF out (coax or optical) on a userfriendly way?
