SPI5 on imx6
Discussion in 'General Discussion' started by yani, Jan 20, 2014.
  1. yani
    yani New Member
    Jan 20, 2014
    Hi all,
    I'm trying to get spidev up on spi5 on the imx6 (not the arduino), I've been following the instructions in the user manual and at https://community.freescale.com/thread/302612 which details how to do it for a similair board.
    I've uncommented all the SPI5 pins in board-mx6qd_seco_UDOO.h, and commented out the corresponding standard GPIO pins, I've also removed those pins from the input array in board-mx6qd_seco_UDOO.h. I've quoted my full kernel diff to show exactly what changes I've made below.
    At boot I'm seeing the following, and not much more information:
    [    0.892438] spi_imx imx6q-ecspi.4: can't get cs gpios
    [    0.897516] spi_imx: probe of imx6q-ecspi.4 failed with error -22
    I've tried varios CS gpio pins, including only using SS0, with no luck. It seems the spi_imx driver can't claim the pins, and yet as far as I can see they aren't being used by anything else.
    Any help would be appreciated! Has anyone got SPI working?
    diff --git a/arch/arm/mach-mx6/board-mx6_seco_UDOO.c b/arch/arm/mach-mx6/board-mx6_seco_UDOO.c
    index 78f9fc7..b7fc9ec 100644
    --- a/arch/arm/mach-mx6/board-mx6_seco_UDOO.c
    +++ b/arch/arm/mach-mx6/board-mx6_seco_UDOO.c
    @@ -915,6 +915,36 @@ void set_gpios_directions(void)
     		printk("#### No gpios to export");
    + *                                   SPI                               *
    +static int mx6q_seco_udoo_spi_cs5[] = {
    +	MX6Q_PAD_SD1_DAT1__ECSPI5_SS0,
    +	MX6Q_PAD_SD1_DAT2__ECSPI5_SS1,
    +	MX6Q_PAD_SD1_DAT3__ECSPI5_SS2,
    +	MX6Q_PAD_SD2_DAT3__ECSPI5_SS3
    +static const struct spi_imx_master mx6q_seco_UDOO_spi_data5 __initconst = {
    +        .chipselect     = mx6q_seco_udoo_spi_cs5,
    +        .num_chipselect = ARRAY_SIZE(mx6q_seco_udoo_spi_cs5),
    +static struct spi_board_info imx6_seco_UDOO_spi_device[] __initdata = {
    +		.modalias = "spidev",
    +		.max_speed_hz = 20000000, /* max spi clock (SCK) speed in HZ */
    +		.bus_num = 4,
    +		.chip_select = 0,
    +		.mode = SPI_MODE_0,
    +static void spi_device_init(void) {
    +        spi_register_board_info(imx6_seco_UDOO_spi_device,
    +                                ARRAY_SIZE(imx6_seco_UDOO_spi_device));
    @@ -1035,6 +1065,9 @@ static void __init mx6_seco_UDOO_board_init(void)
     			ARRAY_SIZE(mxc_i2c2_board_info));
    +	imx6q_add_ecspi(4, &mx6q_seco_UDOO_spi_data5);
    +	spi_device_init();
     	imx6q_add_mxc_hdmi(&hdmi_data);
     	imx6q_add_anatop_thermal_imx(1, &mx6q_seco_UDOO_anatop_thermal_data);
    diff --git a/arch/arm/mach-mx6/board-mx6qd_seco_UDOO.h b/arch/arm/mach-mx6/board-mx6qd_seco_UDOO.h
    index bfd2c4b..f1d16cf 100644
    --- a/arch/arm/mach-mx6/board-mx6qd_seco_UDOO.h
    +++ b/arch/arm/mach-mx6/board-mx6qd_seco_UDOO.h
    @@ -249,35 +249,35 @@ static iomux_v3_cfg_t mx6qd_seco_UDOO_pads[] = {
     		//MX6DL_PAD_CSI0_DAT11__UART1_RXD,
     	MX6Q_PAD_CSI0_DAT10__GPIO_5_28,							// pin 1
     		//MX6Q_PAD_CSI0_DAT10__UART1_TXD,
    -    MX6Q_PAD_SD1_CLK__GPIO_1_20,							// pin 2
    +    	//MX6Q_PAD_SD1_CLK__GPIO_1_20,							// pin 2
     		// MX6Q_PAD_SD1_CLK__USDHC1_CLK,
    -		// MX6Q_PAD_SD1_DAT1__ECSPI5_SCLK,
    -	MX6Q_PAD_SD1_DAT0__GPIO_1_16,							// pin 3
    +	MX6Q_PAD_SD1_CLK__ECSPI5_SCLK,
    +	//MX6Q_PAD_SD1_DAT0__GPIO_1_16,							// pin 3
     		// MX6Q_PAD_SD1_DAT0__USDHC1_DAT0,
    -		// MX6Q_PAD_SD1_DAT1__ECSPI5_MISO,
    -	MX6Q_PAD_SD1_DAT1__GPIO_1_17,							// pin 4
    +	MX6Q_PAD_SD1_DAT0__ECSPI5_MISO,
    +	//MX6Q_PAD_SD1_DAT1__GPIO_1_17,							// pin 4
     		// MX6Q_PAD_SD1_DAT1__USDHC1_DAT1,
     		// MX6Q_PAD_SD1_DAT1__PWM3_PWMO,
    -		// MX6Q_PAD_SD1_DAT1__ECSPI5_SS0,
     		// MX6Q_PAD_SD1_DAT1__GPT_CAPIN2,
    -	MX6Q_PAD_SD1_CMD__GPIO_1_18,							// pin 5
    +	//MX6Q_PAD_SD1_CMD__GPIO_1_18,							// pin 5
     		// MX6Q_PAD_SD1_CMD__USDHC1_CMD,
     		// MX6Q_PAD_SD1_CMD__PWM4_PWMO,
    -		// MX6Q_PAD_SD1_CMD__ECSPI5_MOSI,
    +	MX6Q_PAD_SD1_CMD__ECSPI5_MOSI,
     	MX6Q_PAD_SD4_DAT1__GPIO_2_9,							// pin 6
     		// MX6Q_PAD_SD4_DAT1__PWM3_PWMO,
     	MX6Q_PAD_SD4_DAT2__GPIO_2_10,							// pin 7
     		// MX6Q_PAD_SD4_DAT2__PWM4_PWMO,
    -	MX6Q_PAD_SD1_DAT3__GPIO_1_21,  							// pin 8
    +	//MX6Q_PAD_SD1_DAT3__GPIO_1_21,  							// pin 8
     		// MX6Q_PAD_SD1_DAT3__PWM1_PWMO,
     		// MX6Q_PAD_SD1_DAT3__USDHC1_DAT3,
    -		// MX6Q_PAD_SD1_DAT3__ECSPI5_SS2,
     		// MX6Q_PAD_SD1_DAT3__WDOG2_WDOG_RST_B_DEB,
    -	MX6Q_PAD_SD1_DAT2__GPIO_1_19,							// pin 9
    +	// MX6Q_PAD_SD1_DAT2__GPIO_1_19,							// pin 9
     		// MX6Q_PAD_SD1_DAT2__PWM2_PWMO,
     		// MX6Q_PAD_SD1_DAT2__USDHC1_DAT2,
    -		// MX6Q_PAD_SD1_DAT2__ECSPI5_SS1,
     		// MX6Q_PAD_SD1_DAT2__GPT_CMPOUT2,
     	MX6Q_PAD_GPIO_1__GPIO_1_1,								// pin 10
     		// MX6Q_PAD_GPIO_1__PWM2_PWMO,
    @@ -404,16 +404,16 @@ static unsigned int mx6q_set_in_inputmode[] = {
     	MX6Q_PAD_CSI0_DAT10__GPIO_MODE,
     	MX6Q_PAD_CSI0_DAT11__GPIO_MODE,
    -	MX6Q_PAD_SD1_CLK__GPIO_MODE,
    -	MX6Q_PAD_SD1_DAT0__GPIO_MODE,
    +	//MX6Q_PAD_SD1_CLK__GPIO_MODE,
    +	//MX6Q_PAD_SD1_DAT0__GPIO_MODE,
    -	MX6Q_PAD_SD1_DAT1__GPIO_MODE,
    -	MX6Q_PAD_SD1_CMD__GPIO_MODE,
    +	//MX6Q_PAD_SD1_DAT1__GPIO_MODE,
    +	//MX6Q_PAD_SD1_CMD__GPIO_MODE,
     	MX6Q_PAD_SD4_DAT1__GPIO_MODE,
     	MX6Q_PAD_SD4_DAT2__GPIO_MODE,
    -	MX6Q_PAD_SD1_DAT3__GPIO_MODE,
    +	//MX6Q_PAD_SD1_DAT3__GPIO_MODE,
    -	MX6Q_PAD_SD1_DAT2__GPIO_MODE,
    +	//MX6Q_PAD_SD1_DAT2__GPIO_MODE,
     	MX6Q_PAD_GPIO_1__GPIO_MODE,
     	MX6Q_PAD_GPIO_9__GPIO_MODE,
     	MX6Q_PAD_GPIO_3__GPIO_MODE,
  2. glenn
    glenn New Member
    Mar 5, 2014
    I'm running into the same problem (although i'm trying to use spi1) and wondered if you were able to fix this?
    I also noticed the error in dmesg is gone when moving these lines
    spi_device_init();
    to the bottom of mx6_seco_UDOO_board_init() .
    The error is gone but there is no other mention of spi in dmesg log, and there is no /dev/spi* file created.
    i do get something in /proc/iomem , but i'm not sure what this means..
    # less /proc/iomem | grep spi
    02018000-02018fff : imx6q-ecspi.4
    Thanks for any hints!
  3. Sany
    Sany New Member
    Feb 27, 2014
    10
    Hello,
    i stuck on the Problem, that is no SPI dev available..
    can you help me?
  4. glenn
    glenn New Member
    Mar 5, 2014
    Sany, i'm afraid i can't help you since i'm stuck with this problem as well ..
  5. Sany
    Sany New Member
    Feb 27, 2014
    10
    Hello,
    I have searched in the Datasheet, i found this:
    EIM_D16 ECSPI1_SCKL
    EIM_D17 ECSPI1_MISO
    EIM_D18 ECSPI1_MOSI
    EIM_D24 ECSPI1_SS2, ECSPI1_SS3...
    Now, in the Kernel config Header Source:
    MX6Q_PAD_EIM_D16__ECSPI1_SCLK, // - to SPI
    MX6Q_PAD_EIM_D17__ECSPI1_MISO, // - to SPI
    MX6Q_PAD_EIM_D18__ECSPI1_MOSI, // - to SPI
    MX6Q_PAD_EIM_D19__GPIO_3_19, /*SS1*/ // - to SPI CS1 (In Datasheet is D24?!)
    The Schematic for REV D Says, D19 is going to the Watchdog...
    That is very tricky....
    Informations Outdated?
  6. Oromit
    Oromit New Member
    Mar 14, 2014
  7. glenn
    glenn New Member
    Mar 5, 2014
    ok, thanks for your message!
