Teamviewer 4 Udoo
Discussion in 'Linux Ubuntu' started by Poldo, Jan 15, 2014.
  1. Poldo
    Poldo New Member
    Jan 15, 2014
    Hello UDOOers,
    I have some problems with HDMI and I'm looking for a temporary solution.
    My idea is to install Teamviewer on UDOO and control it from my PC.
    I'm pretty new on Linux, someone cal help me ?
    Thanks
    Poldo
  2. delba
    1,064
  3. matthias
    matthias New Member
    Oct 23, 2013
  4. francescomm
    francescomm Member
    Dec 14, 2013
    80
    Hi, has anybody solved this? I am trying to use my quad to control my network from outside and while VNC in not an option (I am already using it now inside my network, but I need access from anywhere like LogMeIn or TeamViewer do).
    Is there an option to connect to the UDOO from anywhere in the world without knowing an ip address? Hamachi?
  5. waltervl
    Did you try the installlation method for TeamViewer on Raspberry Pi (also arm based)? I did not as I do not need TeamViewer but you could give it a try. Google for one of the many results.
  6. francescomm
    francescomm Member
    Dec 14, 2013
    80
    I tried. Downloaded a .deb file from here
    https://www.teamviewer.com/it/download/linux/
    and "sudo apt install "ed the file. It wrote a lot of stuff about missing things. I have no idea if this can be fixed or not.
  7. francescomm
    francescomm Member
    Dec 14, 2013
    80
    Ok, I tried dpkg to install the downloaded .deb file
    dpkg -i ./*.deb
    (only one .deb file was present so *.deb just saved me some typing)
    dpkg showed me some errors on stuff that was missing, most of the missing dependencies were related to libqt5... stuff
    I tried a
    sudo apt-get install libqt5gui5
    (picked up a random one) and got another bunch of errors with the suggestion to
    Try 'apt-get -f install' with no packages (or specify a solution).
    And `sudo apt-get -f install` completed successfully showing the TeamViewer Licence agreement.
    After that TeamViewer was in the internet menu!
    And it started fine:
    And this is a view from my Mac:
    Done!
  8. waltervl
    Next of using TeamViewer (thanks for posting the solution), ngrok also seems to work https://www.udoo.org/forum/threads/remote-desktop-from-different-network.8498/
  9. hhtmp88
    hhtmp88 UDOOer
    May 24, 2016
    48
    will teamviewer also work on Udoo X86, Ubuntu 16.04?
    Thanks!
  10. waltervl
