Temperature and humidity Meteo project
Discussion in 'General Discussion' started by chilliman, Sep 5, 2014.
  1. chilliman
    chilliman New Member
    Dec 31, 2013
    hi
    i am tying to get the Temperature and humidity Meteo project from the tutorials on the udoo website , have got it working but when i try to use the PHP part of the tutorial i keep get an error listed below
    Warning: Unable to open the device in /var/www/METEO/php_serial.class.php on line 157 Warning: Device must be opened in /var/www/METEO/php_serial.class.php on line 541 Warning: Device must be opened to read it in /var/www/METEO/php_serial.class.php on line 474
    --UDOO SYSTEM--METEO DATA DETECTION--
    Last Detection 2014-09-05 02:49:18
    Humidity Temperature
    Notice: Undefined offset: 1 in /var/www/METEO/data_php.php on line 55
    i think i have changed the permissions using the 'chmod 777' command.
    can anyone help me with this issue.
    thanks
    chilliman
  2. chilliman
    Dec 31, 2013
    i found the problem on another website is as follows
    "I found the error: You have to give www-data permissions to access the serial port: That means chmod 777 /dev/ttymxc3 and i did also added www-data to the intserial group. Then you have to restart and it should work."
    and it works fine
    chilliman
  3. THXC
    THXC New Member
    Nov 30, 2013
    sorry for diging up this thred but i have same problem with my meteo project and i get the same error
    Notice: Undefined offset: 1 in /var/www/data_php.php on line 55
    try difrent solutions but they didint help
