The screen shuts off after 10-15 minutes
Discussion in 'Kernels' started by Teleco88, Dec 16, 2016.
  1. Teleco88
    Teleco88 New Member
    Jul 25, 2016
    10
    Hi, friends!
    I am making a custom filesystem to use on my Udoo with only the files I need. My idea is to use the Udoo and display images using the screen (LVDS 7 ") and using a C application that shows images in the framebuffer.
    My problem is the next one after being 10-15 minutes showing an image, the screen goes out and stops showing.
    Anyone know what this may be?
    Is it in the activated kernel something related to the energy saving that causes the screen to be turned off after 10-15 minutes?
    - Kernel 3.14.56 (Oficial)
    - Custom fs
    - Framebuffer to show images.
    2,162
    551
    Does it do the same when attached to an HDMI monitor?
  3. patrykk
    patrykk Member
    Dec 10, 2014
    52
    for lvds backlight we just use only gpio backlight which switch off certain gpio.
    So in a sys you have a backlight device /sys/devices/soc0/backlight_lcd/ . you could use some power daemon to control it in a backgroup.
  4. patrykk
    patrykk Member
    Dec 10, 2014
    52
    btw. you could remove backlight from dts file and inform what happened.
  5. Teleco88
    Teleco88 New Member
    Jul 25, 2016
    10
    Hi, All!
    Yes, the same problem.​
    |So in a sys you have a backlight device /sys/devices/soc0/backlight_lcd/ . you could use some power daemon to |control it in a backgroup.
    I see the device and "bl_power" is activated.​
  6. waltervl
    2,162
    551
    On the risk of telling something completely stupid:
    According this page there is a kernel start-up parameter in 3.14.
    consoleblank= [KNL] The console blank (screen saver) timeout in
    seconds. Defaults to 10*60 = 10mins. A value of 0
    disables the blank timer.
    I hope it helps you. And I am sorry if I brought you deeper into trouble :)
    patrykk likes this.
  7. Teleco88
    Teleco88 New Member
    Jul 25, 2016
    10
    You are right!That was indeed what happened.
    Thanks!!
    Andrea Rovai and waltervl like this.
