Here's how I finally got cgminer to work on UDOO, might be of use to others... Optional: Use nano to add sources, it's tons easier than vi! And get screen simply because it's awesome. Step 1 - Get more repos, we'll need them: Code: sudo nano /etc/apt/sources.list Code: deb http://ports.ubuntu.com/ oneiric main restricted universe multiverse deb http://ports.ubuntu.com/ oneiric-backports main multiverse restricted universe deb http://ports.ubuntu.com/ oneiric-security main restricted universe multiverse deb http://ports.ubuntu.com/ oneiric-updates main restricted universe multiverse Now update with new repos.... Code: sudo apt-get update Step 2 - Get latest version of curl, the one in the repos is so old it's useless... Code: wget http://curl.haxx.se/download/curl-7.33.0.tar.gz tar -xzf curl-7.33.0.tar.gz cd curl-7.33.0 ./configure make sudo make install Step 4 - Now install cgminer dependencies, clone it and configure it and compile it Code: sudo apt-get install libudev-dev libusb-dev libncurses5-dev pkg-config libtool autoconf automake git clone https://github.com/ckolivas/cgminer.git cd cgminer ./autogen.sh ./configure --enable-avalon --enable-bflsc --enable-bitforce --enable-bitfury --enable-hashfast --enable-icarus --enable-knc --enable-bab --enable-klondike --enable-modminer make sudo make install Make sure user can use usb devices - Code: sudo usermod -G plugdev -a ubuntu Run cgminer... Code: cgminer --help Useful Example of screen: Code: sudo screen cgminer -o "127.0.0.1:8332" -u username -p password Ctrl+A Ctrl+D (now you can leave it running peacefully in the background on a screen!) screen -r (pulls screen back up whenever you need) ??? Done! :mrgreen:
bugmenot, i followed your guide but i wasn't able to install cgminer. At the end of step 4, after compiling the cgminer dependencies and trying to install them with "sudo make install", i get this error: Code: libtool: Version mismatch error. This is libtool 2.4.2 Debian-2.4.2-1.3, but the libtool: definition of this LT_INIT comes from libtool 2.4. libtool: You should recreate aclocal.m4 with macros from libtool 2.4.2 Debian-2.4.2-1.3 libtool: and run autoconf again. make[1]: *** [cgminer] Error 63 make[1]: Leaving directory `/home/ubuntu/curl-7.33.0/cgminer' make: *** [install-recursive] Error 1 Can you help me with this? Cheers
