Uboot 2013 issue
Discussion in 'Troubleshooting' started by moorsb, Mar 15, 2014.
  1. moorsb
    moorsb New Member
    Feb 20, 2014
    36
    I am getting login prompt on U boot console but no video on my monitor
    Any ideas what is wrong?
    U-Boot 2013.10-rc3 (Jan 20 2014 - 13:33:34)
    CPU:   Freescale i.MX6Q rev1.2 at 792 MHz
    Reset cause: POR
    Board: UDOO
    DRAM:  1 GiB
    MMC:   FSL_SDHC: 0
    auto-detected panel HDMI
    Display: HDMI (1024x768)
    In:    serial
    Out:   serial
    Err:   serial
    Net:   using phy at 6
    FEC [PRIME]
    Hit any key to stop autoboot:  5  4  3  2  1  0
    AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
    flags: ncq stag pm led clo only pmp pio slum part
    SATA Device Info:
    S/N: 50026B773B04CF70
    Product model number: KINGSTON SV300S37A60G
    Firmware version: 505ABBF1
    Capacity: 117231408 sectors
    SATA device 0: Model: KINGSTON SV300S37A60G Firm: 505ABBF1 Ser#: 50026B773B04CF70
                Type: Hard Disk
                Supports 48-bit addressing
                Capacity: 57241.8 MB = 55.9 GB (117231408 x 512)
    ... is now current device
    4372712 bytes read in 75 ms (55.6 MiB/s)
    Booting from sata ...
    ## Booting kernel from Legacy Image at 12000000 ...
       Image Name:   Linux-3.0.35
       Data Size:    4372648 Bytes = 4.2 MiB
       Load Address: 10008000
       Entry Point:  10008000
       Verifying Checksum ... OK
       Loading Kernel Image ... OK
    Starting kernel ...
    [    0.000000] Initializing cgroup subsys cpu
    [    0.000000] Linux version 3.0.35 (udoo@ubuntu) (gcc version 4.4.4 (4.4.4_09.06.2010) ) #1 SMP PREEMPT Mon Mar 3 15:17:07 CET 2014
    [    0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] Machine: SECO i.Mx6 UDOO Board
    [    0.000000] Kernel ver: v. 127\nMemory policy: ECC disabled, Data cache writealloc
    [    0.000000] CPU identified as i.MX6Q, silicon rev 1.2
    [    0.000000] PERCPU: Embedded 7 pages/cpu @8c008000 s5504 r8192 d14976 u32768
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 227328
    [    0.000000] Kernel command line: console=ttymxc1,115200 root=/dev/sda1 fbmem=24M video=mxcfb0:dev=hdmi, 1920x1080M@60,bpp=32
    [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Memory: 640MB 256MB = 896MB total
    [    0.000000] Memory: 895872k/895872k available, 152704k reserved, 0K highmem
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
    [    0.000000]     DMA     : 0xf4600000 - 0xffe00000   ( 184 MB)
    [    0.000000]     vmalloc : 0xc0800000 - 0xf2000000   ( 792 MB)
    [    0.000000]     lowmem  : 0x80000000 - 0xc0000000   (1024 MB)
    [    0.000000]     pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    [    0.000000]     modules : 0x7f000000 - 0x7fe00000   (  14 MB)
    [    0.000000]       .init : 0x80008000 - 0x8003a000   ( 200 kB)
    [    0.000000]       .text : 0x8003a000 - 0x80b7851c   (11514 kB)
    [    0.000000]       .data : 0x80b7a000 - 0x80be1460   ( 414 kB)
    [    0.000000]        .bss : 0x80be1484 - 0x80c32bc0   ( 326 kB)
    [    0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
    [    0.000000] Preemptible hierarchical RCU implementation.
    [    0.000000] NR_IRQS:624
    [    0.000000] MXC GPIO hardware
    [    0.000000] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms
    [    0.000000] arm_max_freq=1GHz
    [    0.000000] MXC_Early serial console at MMIO 0x21e8000 (options '115200')
    [    0.000000] bootconsole [ttymxc1] enabled
    [    0.000000] Console: colour dummy device 80x30
    [    0.216465] Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280)
    [    0.304803] pid_max: default: 32768 minimum: 301
    [    0.309691] Mount-cache hash table entries: 512
    [    0.314954] Initializing cgroup subsys cpuacct
    [    0.319454] Initializing cgroup subsys devices
    [    0.323913] Initializing cgroup subsys freezer
    [    0.328406] Initializing cgroup subsys blkio
    [    0.332743] CPU: Testing write buffer coherency: ok
    [    0.337902] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
    [    0.438440] CPU1: Booted secondary processor
    [    0.518438] CPU2: Booted secondary processor
    [    0.598456] CPU3: Booted secondary processor
    [    0.637940] Brought up 4 CPUs
    [    0.653768] SMP: Total of 4 processors activated (6324.22 BogoMIPS).
    [    0.660585] devtmpfs: initialized
    [    0.680781] print_constraints: dummy:
    [    0.684744] NET: Registered protocol family 16
    [    0.693679] print_constraints: vddpu: 725 <--> 1300 mV at 1150 mV fast normal
    [    0.701274] print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal
    [    0.709021] print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal
    [    0.716693] print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal
    [    0.724472] print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal
    [    0.732157] print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal
    [    0.741286]
    [    0.741293] > UDOO quad
    [    0.745066] > rev C Called set_gpios_direction
    [    0.749747] Test and set gpios directions and values by Gionji feat. Ekirei test
    [    0.781888] Resetting ethernet physical layer.
    [    0.824840] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
    [    0.831678] hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step.
    [    0.839038] hw-breakpoint: maximum watchpoint size is 4 bytes.
    [    0.844924] L310 cache controller enabled
    [    0.848968] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x02070000, Cache size: 1048576 B
    [    0.886411] bio: create slab <bio-0> at 0
    [    0.893829] mxs-dma mxs-dma-apbh: initialized
    [    0.898587] print_constraints: vmmc: 3300 mV
    [    0.903698] vgaarb: loaded
    [    0.907249] SCSI subsystem initialized
    [    0.912207] usbcore: registered new interface driver usbfs
    [    0.917842] usbcore: registered new interface driver hub
    [    0.923362] usbcore: registered new device driver usb
    [    0.928443] Freescale USB OTG Driver loaded, $Revision: 1.55 $
    [    0.947937] imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
    [    0.967931] imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
    [    0.975767] mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 driver probed
    [    0.982246] mxc_mipi_csi2 mxc_mipi_csi2: i.MX MIPI CSI2 dphy version is 0x3130302a
    [    0.989967] MIPI CSI2 driver module loaded
    [    0.994321] Advanced Linux Sound Architecture Driver Version 1.0.24.
    [    1.001548] Bluetooth: Core ver 2.16
    [    1.005255] NET: Registered protocol family 31
    [    1.009726] Bluetooth: HCI device and connection manager initialized
    [    1.016101] Bluetooth: HCI socket layer initialized
    [    1.021002] Bluetooth: L2CAP socket layer initialized
    [    1.026146] Bluetooth: SCO socket layer initialized
    [    1.031490] cfg80211: Calling CRDA to update world regulatory domain
    [    1.038963] i2c-core: driver [max17135] using legacy suspend method
    [    1.045251] i2c-core: driver [max17135] using legacy resume method
    [    1.051482] Switching to clocksource mxc_timer1
    [    1.071593] NET: Registered protocol family 2
    [    1.076174] IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
    [    1.084068] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
    [    1.093413] TCP bind hash table entries: 65536 (order: 7, 786432 bytes)
    [    1.101156] TCP: Hash tables configured (established 131072 bind 65536)
    [    1.107807] TCP reno registered
    [    1.110966] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [    1.116951] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [    1.123670] NET: Registered protocol family 1
    [    1.128373] RPC: Registered named UNIX socket transport module.
    [    1.134314] RPC: Registered udp transport module.
    [    1.139056] RPC: Registered tcp transport module.
    [    1.143776] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    1.151165] PMU: registered new PMU device of type 0
    [    1.156302] Static Power Management for Freescale i.MX6
    [    1.161545] wait mode is enabled for i.MX6
    [    1.165841] cpaddr = c0880000 suspend_iram_base=c08fc000
    [    1.171274] PM driver module loaded
    [    1.175176] IMX usb wakeup probe
    [    1.178927] add wake up source irq 75
    [    1.186221] IMX usb wakeup probe
    [    1.189762] cpu regulator mode:ldo_enable
    [    1.193979] i.MXC CPU frequency driver
    [    1.224356] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
    [    1.231247] fuse init (API version 7.16)
    [    1.236120] msgmni has been set to 1749
    [    1.241511] alg: No test for stdrng (krng)
    [    1.245783] io scheduler noop registered
    [    1.249742] io scheduler deadline registered
    [    1.254120] io scheduler cfq registered (default)
    [    1.259955] MIPI DSI driver module loaded
    [    1.264155] mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver hdmi
    [    1.270667] mxc_hdmi mxc_hdmi: Detected HDMI controller 0x13:0xa:0xa0:0xc1
    [    1.277647] fb_videomode = 69 640 400 39721 40 24 39 9 96 2 0 0 32
    [    1.306136] imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7)
    [    1.361414] Console: switching to colour frame buffer device 128x48
    [    1.403591] mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver ldb
    [    1.410023] _regulator_get: get() with no identifier
    [    1.422348] fb_videomode = 69 640 400 39721 40 24 39 9 96 2 0 0 32
    [    1.429173] mxc_sdc_fb mxc_sdc_fb.2: register mxc display driver ldb
    [    1.524635] fb_videomode = 59 640 480 39721 48 16 33 10 96 2 0 16 32
    [    1.560139] fb_videomode = 70 720 400 38210 88 17 13 1 71 3 0 0 8
    [    1.567351] imx-sdma imx-sdma: loaded firmware 1.1
    [    1.571720] imx-sdma imx-sdma: initialized
    [    1.572846] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines
    [    1.644974] fb_videomode = 70 720 400 38210 88 17 13 1 71 3 0 0 32
    [    1.644990] fb_videomode = 70 720 400 38210 88 17 13 1 71 3 0 0 8
    [    1.716660] Serial: IMX driver
    [    1.719854] imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX
    [    1.726748] imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX
    [    1.733230] console [ttymxc1] enabled, bootconsole disabled
    [    1.744785] imx-uart.3: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX
    [    1.756898] loop: module loaded
    [    1.760433] request BOSSA_CLK IRQ
    [    1.763752] registering IRQ 419 for BOSSAC Arduino erase/reset operation
    [    1.779325] ahci: SSS flag set, parallel bus scan disabled
    [    1.784842] ahci ahci.0: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
    [    1.792778] ahci ahci.0: flags: ncq sntf stag pm led clo only pmp pio slum part ccc apst
    [    1.802003] scsi0 : ahci_platform
    [    1.805736] ata1: SATA max UDMA/133 mmio [mem 0x02200000-0x02200fff] port 0x100 irq 71
    [    1.815014] GPMI NAND driver registered. (IMX)
    [    1.820477] vcan: Virtual CAN interface driver
    [    1.824929] CAN device driver interface
    [    1.828795] flexcan netdevice driver
    [    1.832532] FEC Ethernet Driver
    [    1.838028] fec_enet_mii_bus: probed
    [    1.847072] usbcore: registered new interface driver rt2800usb
    [    1.852911] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    1.859596] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
    [    1.866265] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
    [    1.896096] fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000
    [    1.916107] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
    [    1.922446] hub 1-0:1.0: USB hub found
    [    1.926227] hub 1-0:1.0: 1 port detected
    [    1.930325] add wake up source irq 72
    [    1.934026] fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller
    [    1.940682] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2
    [    1.986080] fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200
    [    2.016072] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00
    [    2.022255] hub 2-0:1.0: USB hub found
    [    2.026019] hub 2-0:1.0: 1 port detected
    [    2.030313] Initializing USB Mass Storage driver...
    [    2.035349] usbcore: registered new interface driver usb-storage
    [    2.041406] USB Mass Storage support registered.
    [    2.046340] usbcore: registered new interface driver usbserial
    [    2.052278] USB Serial support registered for generic
    [    2.057466] usbcore: registered new interface driver usbserial_generic
    [    2.063998] usbserial: USB Serial Driver core
    [    2.068470] USB Serial support registered for debug
    [    2.073472] usbcore: registered new interface driver debug
    [    2.078979] ARC USBOTG Device Controller driver (1 August 2005)
    [    2.085271] g_ether gadget: using random self ethernet address
    [    2.091133] g_ether gadget: using random host ethernet address
    [    2.097729] usb0: MAC ea:6b:5b:9e:13:4c
    [    2.101568] usb0: HOST MAC 02:ea:56:2a:c3:11
    [    2.105845] g_ether gadget: controller 'fsl-usb2-udc' not recognized; trying CDC Ethernet (ECM)
    [    2.114584] g_ether gadget: Ethernet Gadget, version: Memorial Day 2008
    [    2.121221] g_ether gadget: g_ether ready
    [    2.125236] Suspend udc for OTG auto detect
    [    2.146103] fsl-usb2-udc: bind to driver g_ether
    [    2.151389] mousedev: PS/2 mouse device common for all mice
    [    2.157019] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
    [    2.157389] usbcore: registered new interface driver usbtouchscreen
    [    2.157803] Sitronix touch driver 2.9.1
    [    2.157809] Release date: 20120507
    [    2.158182] sitronix_reset_ic
    [    2.187686] ata1.00: ATA-8: KINGSTON SV300S37A60G, 505ABBF1, max UDMA/133
    [    2.194483] ata1.00: 117231408 sectors, multi 16: LBA48 NCQ (depth 31/32)
    [    2.207682] ata1.00: configured for UDMA/133
    [    2.226371] scsi 0:0:0:0: Direct-Access     ATA      KINGSTON SV300S3 505A PQ: 0 ANSI: 5
    [    2.235061] sd 0:0:0:0: [sda] 117231408 512-byte logical blocks: (60.0 GB/55.8 GiB)
    [    2.242992] sd 0:0:0:0: [sda] Write Protect is off
    [    2.247885] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    [    2.257887]  sda: sda1
    [    2.261088] sd 0:0:0:0: [sda] Attached SCSI disk
    [    2.286478] send status reg command error (-5)
    [    2.290934] sitronix: probe of 2-0055 failed with error -5
    [    2.296996] i2c-core: driver [isl29023] using legacy suspend method
    [    2.303267] i2c-core: driver [isl29023] using legacy resume method
    [    2.310189] snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0
    [    2.316879] i2c /dev entries driver
    [    2.321189] Linux video capture interface: v2.00
    [    2.356092] usb 2-1: new high speed USB device number 2 using fsl-ehci
    [    2.456173] ov5640_read_reg:write reg error:reg=300a
    [    2.461140] camera ov5640_mipi is not found
    [    2.465749] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16
    [    2.473415] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17
    [    2.481064] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18
    [    2.488743] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video19
    [    2.496388] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video20
    [    2.504173] vivi-000: V4L2 device registered as video2
    [    2.509333] Video Technology Magazine Virtual Video Capture Board ver 0.8.0 successfully loaded.
    [    2.518544] usbcore: registered new interface driver uvcvideo
    [    2.524336] USB Video Class driver (v1.1.0)
    [    2.529348] hub 2-1:1.0: USB hub found
    [    2.533123] i2c-core: driver [mag3110] using legacy suspend method
    [    2.539346] hub 2-1:1.0: 4 ports detected
    [    2.543373] i2c-core: driver [mag3110] using legacy resume method
    [    2.550139] imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1)
    [    2.558372] Bluetooth: Virtual HCI driver ver 1.3
    [    2.563320] Bluetooth: HCI UART driver ver 2.2
    [    2.567783] Bluetooth: HCIATH3K protocol initialized
    [    2.572751] Bluetooth: Generic Bluetooth USB driver ver 0.6
    [    2.578478] usbcore: registered new interface driver btusb
    [    2.584113] sdhci: Secure Digital Host Controller Interface driver
    [    2.590310] sdhci: Copyright(c) Pierre Ossman
    [    2.595004] mmc0: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA
    [    2.602296] mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
    [    2.613548] VPU initialized
    [    2.616923] mxc_asrc registered
    [    2.638594] Thermal calibration data is 0x58b4f569
    [    2.644998] Thermal sensor with ratio = 184
    [    2.667411] Anatop Thermal registered as thermal_zone0
    [    2.676107] anatop_thermal_probe: default cooling device is cpufreq!
    [    2.685304] usbcore: registered new interface driver usbhid
    [    2.690891] usbhid: USB HID core driver
    [    2.695214] usbcore: registered new interface driver snd-usb-audio
    [    2.701999] mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio
    [    2.707490] Cirrus Logic CS42888 ALSA SoC Codec Driver
    [    2.712744] i2c-core: driver [cs42888] using legacy suspend method
    [    2.718940] i2c-core: driver [cs42888] using legacy resume method
    [    2.759366] mmc0: new high speed SDHC card at address aaaa
    [    2.765256] mmcblk0: mmc0:aaaa SU16G 14.8 GiB
    [    2.771062]  mmcblk0: p1
    [    2.807892] audio_codec_ac97_cold_reset
    [    2.856294] usb 2-1.1: new high speed USB device number 3 using fsl-ehci
    [    2.888653] Found Audio codec AC97 vt1613, [ID = 5649 - 4123]
    [    2.906891] asoc: vt1613 <-> imx-ssi.0 mapping ok
    [    2.913284] imx_3stack asoc driver
    [    2.918343] asoc: mxc-hdmi-soc <-> imx-hdmi-soc-dai.0 mapping ok
    [    2.925048] ALSA device list:
    [    2.928062]   #0: vt1613-audio
    [    2.931118]   #1: imx-hdmi-soc
    [    2.934380] NET: Registered protocol family 26
    [    2.939384] TCP cubic registered
    [    2.942617] NET: Registered protocol family 17
    [    2.947141] can: controller area network core (rev 20090105 abi 8)
    [    2.953397] NET: Registered protocol family 29
    [    2.957856] can: raw protocol (rev 20090105)
    [    2.962129] can: broadcast manager protocol (rev 20090105 t)
    [    2.967876] Bluetooth: RFCOMM TTY layer initialized
    [    2.972763] Bluetooth: RFCOMM socket layer initialized
    [    2.977973] Bluetooth: RFCOMM ver 1.11
    [    2.981726] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [    2.987048] Bluetooth: BNEP filters: protocol multicast
    [    2.988608] hub 2-1.1:1.0: USB hub found
    [    2.988921] hub 2-1.1:1.0: 4 ports detected
    [    3.000379] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
    [    3.006481] lib80211: common routines for IEEE802.11 drivers
    [    3.012175] Registering the dns_resolver key type
    [    3.016926] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    [    3.024977] Bus freq driver module loaded
    [    3.029004] Bus freq driver Enabled
    [    3.034412] mxc_dvfs_core_probe
    [    3.037777] DVFS driver module loaded
    [    3.043104] snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:01 UTC (1)
    [    3.054689] EXT3-fs: barriers not enabled
    [    3.086368] usb 2-1.3: new high speed USB device number 4 using fsl-ehci
    [    3.105782] kjournald starting.  Commit interval 5 seconds
    [    3.111317] EXT3-fs (sda1): using internal journal
    [    3.116293] EXT3-fs (sda1): 2 orphan inodes deleted
    [    3.121174] EXT3-fs (sda1): recovery complete
    [    3.126644] EXT3-fs (sda1): mounted filesystem with writeback data mode
    [    3.133294] VFS: Mounted root (ext3 filesystem) on device 8:1.
    [    3.139847] devtmpfs: mounted
    [    3.142870] Freeing init memory: 200K
    [    3.346478] usb 2-1.1.1: new low speed USB device number 5 using fsl-ehci
    [    3.514008] input: HID 1241:1177 as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.1/2-1.1.1/2-1.1.1:1.0/input/input0
    [    3.525862] generic-usb 0003:1241:1177.0001: input,hidraw0: USB HID v1.00 Mouse [HID 1241:1177] on usb-fsl-ehci.1-1.1.1/input0
    [    6.155165] ERROR: v4l2 capture: slave not found!
    [    6.155740] ERROR: v4l2 capture: slave not found!
    [    6.243039] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines
    [    6.740296] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines
    Ubuntu 12.04 LTS udoo ttymxc1
    udoo login:
  2. moorsb
    moorsb New Member
    Feb 20, 2014
    36
    Finally found the printenv command and found my typo
    now it boots off ssd!
  3. delba
    1,063
    Ok nice. Next time remember to put your code between the
     tag. I did it for you this time.
