os : Ubuntu 12.04 LTS H/W : Udoo QUAD + HDMI Touch Screen Sometimes the system stops in sleep mode. The problem is that it appears intermittently. Pressing the keyboard or touching the monitor does not respond. It looks like suspend mode. The Brightness and Locking and Power settings file is attached. If you have someone with the same problem, please advise. Below is a log file. /var/log/kern.log (Omitted log file) *************************************************************************************************** Mar 23 11:28:52 udoo kernel: [ 3.178442] devtmpfs: mounted Mar 23 11:28:52 udoo kernel: [ 3.181465] Freeing init memory: 200K Mar 23 11:28:52 udoo kernel: [ 3.293537] input: eGalax Inc. USB TouchController as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.2/2-1.2:1.0/input/input2 Mar 23 11:28:52 udoo kernel: [ 3.306170] input: eGalax Inc. USB TouchController as /devices/platform/fsl-ehci.1/usb2/2-1/2-1.2/2-1.2:1.0/input/input3 Mar 23 11:28:52 udoo kernel: [ 3.318726] generic-usb 0003:0EEF:0001.0003: input,hidraw2: USB HID v2.10 Pointer [eGalax Inc. USB TouchController] on usb-fsl-ehci.1-1.2/input0 Mar 23 11:28:52 udoo kernel: [ 3.408385] usb 2-1.3: new high speed USB device number 5 using fsl-ehci Mar 23 11:28:52 udoo kernel: [ 3.573663] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht' Mar 23 11:28:52 udoo kernel: [ 3.575232] Registered led device: rt2800usb-phy0::radio Mar 23 11:28:52 udoo kernel: [ 3.575356] Registered led device: rt2800usb-phy0::assoc Mar 23 11:28:52 udoo kernel: [ 3.575492] Registered led device: rt2800usb-phy0::quality Mar 23 11:28:52 udoo kernel: [ 3.579311] init: ureadahead main process (1628) terminated with status 5 Mar 23 11:28:52 udoo kernel: [ 5.331036] Installing knfsd (copyright (C) 1996 okir@monad.swb.de). Mar 23 11:28:52 udoo kernel: [ 5.766373] NET: Registered protocol family 10 Mar 23 11:28:53 udoo kernel: [ 7.480904] ERROR: v4l2 capture: slave not found! Mar 23 11:28:53 udoo kernel: [ 7.497116] ERROR: v4l2 capture: slave not found! Mar 23 11:28:54 udoo kernel: [ 7.607846] init: failsafe main process (3276) killed by TERM signal Mar 23 11:28:54 udoo kernel: [ 7.900892] eth14: Freescale FEC PHY driver [Generic PHY] (mii_bushy_addr=1:06, irq=-1) Mar 23 11:28:54 udoo kernel: [ 7.900931] Activating ethernet physical layer Micrel KSZ9031 Gigabit PHY. Mar 23 11:28:54 udoo kernel: [ 7.901884] ADDRCONF(NETDEV_UP): eth14: link is not ready Mar 23 11:28:54 udoo kernel: [ 8.282067] ADDRCONF(NETDEV_UP): wlan14: link is not ready Mar 23 11:28:54 udoo kernel: [ 8.298595] ADDRCONF(NETDEV_UP): usb0: link is not ready Mar 23 11:28:55 udoo kernel: [ 8.645886] svc: 127.0.0.1, port=712: unknown version (3 for prog 100003, nfsd) Mar 23 11:28:55 udoo kernel: [ 9.517786] Bridge firewalling registered Mar 23 11:28:56 udoo kernel: [ 9.878293] [drm] Initialized drm 1.1.0 20060810 Mar 23 11:28:56 udoo kernel: [ 9.891659] [drm] Initialized vivante 1.0.0 20120216 on minor 0 Mar 23 11:28:56 udoo kernel: [ 10.160555] [sdhci_pre_dma_transfer] invalid cookie: data->host_cookie 2389 host->next_data.cookie 2390 Mar 23 11:28:57 udoo kernel: [ 10.847654] ip_tables: (C) 2000-2006 Netfilter Core Team Mar 23 11:28:57 udoo kernel: [ 11.048268] init: plymouth-stop pre-start process (3656) terminated with status 1 Mar 23 11:28:57 udoo kernel: [ 11.157701] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines Mar 23 11:28:57 udoo kernel: [ 11.177703] fb_videomode = 75 1024 768 12690 176 16 28 1 96 3 3 0 32 *************************************************************************************************** /var/log/pm-suspend.log *************************************************************************************************** /usr/lib/pm-utils/sleep.d/99video suspend suspend: success. Thu Mar 23 10:44:33 IST 2017: performing suspend Initial commandline parameters: Thu Mar 23 10:58:36 IST 2017: Running hooks for suspend. Running hook /usr/lib/pm-utils/sleep.d/000kernel-change suspend suspend: /usr/lib/pm-utils/sleep.d/000kernel-change suspend suspend: success. Running hook /usr/lib/pm-utils/sleep.d/00logging suspend suspend: Linux udoo 3.0.35 #10 SMP PREEMPT Wed Jul 30 18:16:10 CEST 2014 armv7l armv7l armv7l GNU/Linux Module Size Used by ip6table_filter 877 0 ip6_tables 10649 1 ip6table_filter ebtable_nat 1179 0 ebtables 16338 1 ebtable_nat ipt_REJECT 1907 0 iptable_mangle 1038 0 xt_tcpudp 1881 0 iptable_filter 934 0 ip_tables 9763 2 iptable_mangle,iptable_filter x_tables 11747 8 ip6table_filter,ip6_tables,ebtables,ipt_REJECT,iptable_mangle,xt_tcpudp,iptable_filter,ip_tables vivante 943 1 drm 141876 2 vivante bridge 66875 0 stp 1326 1 bridge ipv6 244966 49 bridge joydev 8547 0 nfsd 62470 11 exportfs 3032 1 nfsd total used free shared buffers cached Mem: 895256 401976 493280 0 1064 76192 -/+ buffers/cache: 324720 570536 Swap: 0 0 0 /usr/lib/pm-utils/sleep.d/00logging suspend suspend: success. Running hook /usr/lib/pm-utils/sleep.d/00powersave suspend suspend: /usr/lib/pm-utils/sleep.d/00powersave suspend suspend: success. Running hook /usr/lib/pm-utils/sleep.d/01PulseAudio suspend suspend: Welcome to PulseAudio! Use "help" for usage information. >>> >>> Welcome to PulseAudio! Use "help" for usage information. >>> >>> Welcome to PulseAudio! Use "help" for usage information. >>> >>> Welcome to PulseAudio! Use "help" for usage information. >>> >>> Welcome to PulseAudio! Use "help" for usage information. >>> >>> /usr/lib/pm-utils/sleep.d/01PulseAudio suspend suspend: success. Running hook /etc/pm/sleep.d/10_unattended-upgrades-hibernate suspend suspend: /etc/pm/sleep.d/10_unattended-upgrades-hibernate suspend suspend: success. Running hook /usr/lib/pm-utils/sleep.d/55NetworkManager suspend suspend: Having NetworkManager put all interaces to sleep...Failed. /usr/lib/pm-utils/sleep.d/55NetworkManager suspend suspend: success. Running hook /usr/lib/pm-utils/sleep.d/60_wpa_supplicant suspend suspend: Failed to connect to wpa_supplicant - wpa_ctrl_open: No such file or directory /usr/lib/pm-utils/sleep.d/60_wpa_supplicant suspend suspend: success. Running hook /usr/lib/pm-utils/sleep.d/75modules suspend suspend: /usr/lib/pm-utils/sleep.d/75modules suspend suspend: not applicable. Running hook /usr/lib/pm-utils/sleep.d/90clock suspend suspend: /usr/lib/pm-utils/sleep.d/90clock suspend suspend: not applicable. Running hook /usr/lib/pm-utils/sleep.d/94cpufreq suspend suspend: /usr/lib/pm-utils/sleep.d/94cpufreq suspend suspend: success. Running hook /usr/lib/pm-utils/sleep.d/95hdparm-apm suspend suspend: /usr/lib/pm-utils/sleep.d/95hdparm-apm suspend suspend: not applicable. Running hook /usr/lib/pm-utils/sleep.d/95led suspend suspend: /usr/lib/pm-utils/sleep.d/95led suspend suspend: not applicable. Running hook /usr/lib/pm-utils/sleep.d/98video-quirk-db-handler suspend suspend: /usr/lib/pm-utils/sleep.d/98video-quirk-db-handler: line 101: /sys/class/dmi/id/bios_version: No such file or directory /usr/lib/pm-utils/sleep.d/98video-quirk-db-handler: line 101: /sys/class/dmi/id/bios_vendor: No such file or directory /usr/lib/pm-utils/sleep.d/98video-quirk-db-handler: line 101: /sys/class/dmi/id/bios_date: No such file or directory /usr/lib/pm-utils/sleep.d/98video-quirk-db-handler: line 101: /sys/class/dmi/id/sys_vendor: No such file or directory /usr/lib/pm-utils/sleep.d/98video-quirk-db-handler: line 101: /sys/class/dmi/id/product_name: No such file or directory /usr/lib/pm-utils/sleep.d/98video-quirk-db-handler: line 101: /sys/class/dmi/id/product_version: No such file or directory /usr/lib/pm-utils/sleep.d/98video-quirk-db-handler: line 101: /sys/class/dmi/id/board_name: No such file or directory /usr/lib/pm-utils/sleep.d/98video-quirk-db-handler: line 101: /sys/class/dmi/id/board_version: No such file or directory /usr/lib/pm-utils/sleep.d/98video-quirk-db-handler: line 101: /sys/class/dmi/id/board_vendor: No such file or directory /usr/lib/pm-utils/sleep.d/98video-quirk-db-handler: line 225: ) 0x10de == : syntax error: operand expected (error token is "== ") No quirk database entry for this system, using default. /usr/lib/pm-utils/sleep.d/98video-quirk-db-handler suspend suspend: success. Running hook /usr/lib/pm-utils/sleep.d/99video suspend suspend: error: "kernel.acpi_video_flags" is an unknown key vbetool not installed! vbetool not installed! vbetool not installed! vbetool not installed! /usr/lib/pm-utils/sleep.d/99video suspend suspend: success. Thu Mar 23 10:58:41 IST 2017: performing suspend ***************************************************************************************************
