Ubuntu UHD (aka 4k) @ 60Hz
Discussion in 'UDOO BOLT' started by zzarr, Jun 5, 2019.
  1. zzarr
    zzarr New Member
    Jun 5, 2019
    Hello!
    I can't set the resolution and framerate to 3840x2160@60 only 3840x2160@30 (over HDMI).
    I have installed Ubuntu 19.04, but I could install 18.04 if needed.
    I tried to add and activate 3840x2160@60 with the help of xrandr, but that did not work.
    My HDMI cable is about 2m in length and flat, could it be the problem?
    Best Regards
    / Rasmus
    Is your cable a HDMI 2.0 Cable?
    Is your monitor supporting 60Hz? Perhaps there is a setting.
    What monitor do you use?
    evaloverde likes this.
  3. zzarr
    zzarr New Member
    Jun 5, 2019
    Hello!
    The Cable is rated for 3840x2160@60Hz (I have tested with 2 cables from different vendors).
    The display can handle 3840x2160@60Hz according to the specification.
    So it's a problem with the driver (must be).
    Best Regards
    / Rasmus
  4. waltervl
    What monitor do you have? Sometimes monitors require extra settings in order to enable 60Hz
  5. zzarr
    zzarr New Member
    Jun 5, 2019
    Hello!
    I have a Swedx 49" UHD-4K monitor. (Note: it's not a TV)
    I will here with Swedx if there's a setting (I can't find one).
    I searched for settings both in BIOS on the Bolt and in the displays settings.
    I'm guessing it have nothing to do with CEC? (and ARC is only for sound I think.)
    Best Regards
    / Rasmus
  6. zzarr
    zzarr New Member
    Jun 5, 2019
    Hello again!
    I got a response from the vendor of the display, it was a setting, EDID, when I selected 2.0 Ubuntu defaulted to 60Hz directly.
    Best Regards
    / Rasmus
  7. evaloverde
    Apr 29, 2019
    236
    60
    Great! Glad the issue was a non-issue
