udoo arduino compiled file is messed up
Discussion in 'Arduino IDE' started by pavan4, Apr 12, 2014.
  1. pavan4
    pavan4 New Member
    Mar 15, 2014
    Hello,
    I am using the SAM to power ws2811 pixels. If I use the neopixel library or the fastled library and compile it on the UDOO (both are supposed to work with DUE) the pixels don't work. I have to compile it on the external computer and upload it onto the SAM.
    Even after that I can't get the code to work properly. Is my board faulty or the connections improper? The exact same code and connections work fine on a DUE or UNO. I tried level shifting using the 74hct245. None of them work. It is extremely frustrating to use the neopixels with the UDOO right now.
    Does anyone have a clue how this is working or did anyone try this before?
  2. peter247
    peter247 Member
    Mar 10, 2014
    263
    If it works on the Due , and the code is compiled on a external computer and upload it onto the SAM , I can`t see why it shouldn't work.
    I know people have problems with code not working on the Due , because of it different libraries or voltage levels , but can`t see why the Due works and the udoo doesn`t , both are 3.3 volt logic and using the same library .
    The only difference I know of is with pull up resistors on i2c.
  3. pavan4
    pavan4 New Member
    Mar 15, 2014
    I don't know why. I connected 160 pixels and the last 40 pixels flicker horribly with both the libraries (adafruit, fastled) If you compile it with the native ide they don't even work. If I compile through an external computer they work but there is flicker. I thought it is the level shifting problem and added the level shifter as well, but it did not help. I took the videos of the flicker and contacted the daniel garcia (author of fastled) he said he will try to get hold of an udoo. I have 6 neopixel shields from adafruit working perfectly fine with UNO, duemilanove. One of the neopixel shield doesnt work when connected to the UDOO, the 5 rest are fine apart from the flicker. I do not have an logic analyzer to check if the timing is being messed up. I am at the verge of giving up.
  4. peter247
    peter247 Member
    Mar 10, 2014
    263
    When you say :-
    The Due do you mean a Due or a duemilanove ? .
    Because a duemilanove , uno , mega is completely different to the Due which is Arm based
  5. mkopack
    mkopack Member
    451
    Yeah, worst thing they ever did was name it the Due when they already had a Duemilanove which most people called a Due for short.... UGH! CONFUSING!
