Hello from Belgium, I try to boot from sata with this post: http://www.elinux.org/UDOO_boot_from_sata I block on "Prepare U-Boot" when i connect with usb cable the Udoo and the PC, nothing happens i don't see connection. i don't understand "Then open a serial terminal to the new COM port on your PC with a baud of 115200" how to do this ? Thank you in advance Nino
Hi from Belgium too See the tutorial http://www.udoo.org/ProjectsAndTutorials/connecting-via-serial-cable/?portfolioID=1394, should help Bonne journée/Prettige dag
Merci beaucoup ! Je vais regarder cela de près ce soir, je n'avais pas vu ce tuto. I look this and it should be OK. Thank you very much
