Hello Community, I received my UDOO Quad today and I am super excited to get it up and running. I imaged the Ubuntu distro on the uSD card and popped it in, powered the beast and noticed a black screen for 10 minutes. I re-downloaded the OS and re-flashed the uSD multiple times, but the results never varied. I went on to troubleshoot and installed Teraterm to monitor the serial port of the device. I noticed that the UDOO sees the OS but around 3.25 seconds into the boot it stops and freezes in place, each time I reset the UDOO I get a similar problem. Below the Teraterm logged data (.txt files attachments seem to not be allowed on the UDOO forums for some reason :?) of 2 of the approximately 10 attempts to get it started up, and you may see that each time the boot froze around the same area, but not exactly the same. Any suggestions on how to get this working will be appreciated Daniel Code: U-Boot 2009.08-svn89 (Oct 29 2013 - 16:13:13) CPU: Freescale i.MX6 family TO1.2 at 792 MHz Thermal sensor with ratio = 179 Temperature: 34 C, calibration data 0x56f4dc69 mx6q pll1: 792MHz mx6q pll2: 528MHz mx6q pll3: 480MHz mx6q pll8: 50MHz ipg clock : 66000000Hz ipg per clock : 66000000Hz uart clock : 80000000Hz cspi clock : 60000000Hz ahb clock : 132000000Hz axi clock : 264000000Hz emi_slow clock: 132000000Hz ddr clock : 528000000Hz usdhc1 clock : 198000000Hz usdhc2 clock : 198000000Hz usdhc3 clock : 198000000Hz usdhc4 clock : 198000000Hz nfc clock : 24000000Hz Board: i.MX6Q-UDOO: unknown-board Board: 0x63012 [POR] Boot Device: NOR I2C: ready DRAM: 1 GB MMC: FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3 In: serial Out: serial Err: serial Net: got MAC address from IIM: 00:c0:08:88:19:bb FEC0 Hit any key to stop autoboot: 3 2 1 0 mmc2 is current device Loading file "/boot/uImage" from mmc device 2:1 (xxc1) 4120128 bytes read ## Booting kernel from Legacy Image at 10800000 ... Image Name: Linux-3.0.35 Created: 2013-11-11 13:45:30 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 4120064 Bytes = 3.9 MB Load Address: 10008000 Entry Point: 10008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... [ 0.000000] Linux version 3.0.35 (udoo@ubuntu) (gcc version 4.4.4 (4.4.4_09.06.2010) ) #5 SMP PREEMPT Mon Nov 11 14:45:12 CET 2013 [ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d [ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: SECO i.Mx6 UDOO Board [ 0.000000] Kernel ver: v. 92 [ 0.000000] Ignoring unrecognised tag 0x41000901 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] CPU identified as i.MX6Q, silicon rev 1.2 [ 0.000000] PERCPU: Embedded 7 pages/cpu @8c008000 s5440 r8192 d15040 u32768 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 227328 [ 0.000000] Kernel command line: console=ttymxc1,115200 root=/dev/mmcblk0p1 rootwait rw fixrtc rootflags=barrier=1 mem=1024M arm_freq=996 video=mxcfb0:dev=hdmi,1920x1080M@60,bpp=32 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 640MB 256MB = 896MB total [ 0.000000] Memory: 896376k/896376k available, 152200k reserved, 0K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] DMA : 0xf4600000 - 0xffe00000 ( 184 MB) [ 0.000000] vmalloc : 0xc0800000 - 0xf2000000 ( 792 MB) [ 0.000000] lowmem : 0x80000000 - 0xc0000000 (1024 MB) [ 0.000000] pkmap : 0x7fe00000 - 0x80000000 ( 2 MB) [ 0.000000] modules : 0x7f000000 - 0x7fe00000 ( 14 MB) [ 0.000000] .init : 0x80008000 - 0x80038000 ( 192 kB) [ 0.000000] .text : 0x80038000 - 0x80b04ec4 (11060 kB) [ 0.000000] .data : 0x80b06000 - 0x80b65b40 ( 383 kB) [ 0.000000] .bss : 0x80b65b64 - 0x80bb44c0 ( 315 kB) [ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] NR_IRQS:624 [ 0.000000] MXC GPIO hardware [ 0.000000] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms [ 0.000000] arm_max_freq=1GHz [ 0.000000] MXC_Early serial console at MMIO 0x21e8000 (options '115200') [ 0.000000] bootconsole [ttymxc1] enabled [ 0.000000] Console: colour dummy device 80x30 [ 0.223179] Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280) [ 0.311515] pid_max: default: 32768 minimum: 301 [ 0.316395] Mount-cache hash table entries: 512 [ 0.321608] CPU: Testing write buffer coherency: ok [ 0.326761] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available [ 0.427288] CPU1: Booted secondary processor [ 0.507287] CPU2: Booted secondary processor [ 0.587302] CPU3: Booted secondary processor [ 0.626793] Brought up 4 CPUs [ 0.642619] SMP: Total of 4 processors activated (6324.22 BogoMIPS). [ 0.649426] devtmpfs: initialized [ 0.669671] print_constraints: dummy: [ 0.673642] NET: Registered protocol family 16 [ 0.682350] print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal [ 0.689840] print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal [ 0.697576] print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal [ 0.705244] print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal [ 0.713007] print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal [ 0.720659] print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal [ 0.729677] [ 0.729683] > UDOO quad [ 0.733455] > rev C Called set_gpios_direction [ 0.738133] Test and set gpios directions and values by Gionji feat. Ekirei test [ 0.769279] Resetting ethernet physical layer. [ 0.813290] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers. [ 0.820122] hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step. [ 0.827480] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.833366] L310 cache controller enabled [ 0.837407] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x02070000, Cache size: 1048576 B [ 0.871277] bio: create slab <bio-0> at 0 [ 0.878611] mxs-dma mxs-dma-apbh: initialized [ 0.883291] print_constraints: vmmc: 3300 mV [ 0.888384] vgaarb: loaded [ 0.891913] SCSI subsystem initialized [ 0.897971] usbcore: registered new interface driver usbfs [ 0.903610] usbcore: registered new interface driver hub [ 0.909106] usbcore: registered new device driver usb [ 0.914175] Freescale USB OTG Driver loaded, $Revision: 1.55 $ [ 0.936792] imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7) [ 0.956793] imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7) [ 0.964682] MIPI CSI2 driver module loaded [ 0.969022] Advanced Linux Sound Architecture Driver Version 1.0.24. [ 0.976233] Bluetooth: Core ver 2.16 [ 0.979954] NET: Registered protocol family 31 [ 0.984412] Bluetooth: HCI device and connection manager initialized [ 0.990797] Bluetooth: HCI socket layer initialized [ 0.995691] Bluetooth: L2CAP socket layer initialized [ 1.000840] Bluetooth: SCO socket layer initialized [ 1.006163] cfg80211: Calling CRDA to update world regulatory domain [ 1.013624] i2c-core: driver [max17135] using legacy suspend method [ 1.019923] i2c-core: driver [max17135] using legacy resume method [ 1.026140] Switching to clocksource mxc_timer1 [ 1.045176] NET: Registered protocol family 2 [ 1.049724] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 1.057636] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 1.066971] TCP bind hash table entries: 65536 (order: 7, 786432 bytes) [ 1.074710] TCP: Hash tables configured (established 131072 bind 65536) [ 1.081357] TCP reno registered [ 1.084517] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 1.090483] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 1.097228] NET: Registered protocol family 1 [ 1.101901] RPC: Registered named UNIX socket transport module. [ 1.107843] RPC: Registered udp transport module. [ 1.112579] RPC: Registered tcp transport module. [ 1.117300] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.124647] PMU: registered new PMU device of type 0 [ 1.129752] Static Power Management for Freescale i.MX6 [ 1.135013] wait mode is enabled for i.MX6 [ 1.139310] cpaddr = c0880000 suspend_iram_base=c08fc000 [ 1.144741] PM driver module loaded [ 1.148629] IMX usb wakeup probe [ 1.152343] add wake up source irq 75 [ 1.159598] IMX usb wakeup probe [ 1.163138] cpu regulator mode:ldo_enable [ 1.167408] i.MXC CPU frequency driver [ 1.197667] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc. [ 1.204347] msgmni has been set to 1750 [ 1.209734] alg: No test for stdrng (krng) [ 1.214005] io scheduler noop registered [ 1.217941] io scheduler deadline registered [ 1.222325] io scheduler cfq registered (default) [ 1.228095] MIPI DSI driver module loaded [ 1.232318] mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver hdmi [ 1.238817] mxc_hdmi mxc_hdmi: Detected HDMI controller 0x13:0xa:0xa0:0xc1 [ 1.245742] fbcvt: 1920x1080@60: CVT Name - 2.073M9 [ 1.262913] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines [ 1.280799] imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7) [ 1.314109] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines [ 1.347484] Console: switching to colour frame buffer device 160x64 [ 1.395634] mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver ldb [ 1.402049] _regulator_get: get() with no identifier [ 1.414578] mxc_sdc_fb mxc_sdc_fb.2: register mxc display driver ldb [ 1.426921] fbcvt: 1920x1080@60: CVT Name - 2.073M9 [ 1.432099] imx-sdma imx-sdma: loaded firmware 1.1 [ 1.436157] imx-sdma imx-sdma: initialized [ 1.609679] Serial: IMX driver [ 1.609785] imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX [ 1.610190] imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX [ 1.725945] console [ttymxc1] enabled, bootconsole disabled [ 1.725945] console [ttymxc1] enabled, bootconsole disabled [ 1.737677] imx-uart.3: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX [ 1.749590] loop: module loaded [ 1.752749] request BOSSA_CLK IRQ [ 1.756066] registering IRQ 419 for BOSSAC Arduino erase/reset operation [ 1.806363] No sata disk. [ 1.810203] GPMI NAND driver registered. (IMX) [ 1.815558] vcan: Virtual CAN interface driver [ 1.820009] CAN device driver interface [ 1.823855] flexcan netdevice driver [ 1.827588] FEC Ethernet Driver [ 1.832924] fec_enet_mii_bus: probed [ 1.841677] usbcore: registered new interface driver rt2800usb [ 1.847513] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.854176] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller [ 1.860825] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1 [ 1.890774] fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000 [ 1.910743] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00 [ 1.917001] hub 1-0:1.0: USB hub found [ 1.920778] hub 1-0:1.0: 1 port detected [ 1.924884] add wake up source irq 72 [ 1.928581] fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller [ 1.935225] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2 [ 1.980744] fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200 [ 2.010734] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00 [ 2.016890] hub 2-0:1.0: USB hub found [ 2.020652] hub 2-0:1.0: 1 port detected [ 2.024943] Initializing USB Mass Storage driver... [ 2.029978] usbcore: registered new interface driver usb-storage [ 2.036025] USB Mass Storage support registered. [ 2.040925] usbcore: registered new interface driver usbserial [ 2.046855] USB Serial support registered for generic [ 2.052045] usbcore: registered new interface driver usbserial_generic [ 2.058575] usbserial: USB Serial Driver core [ 2.063049] USB Serial support registered for debug [ 2.068061] usbcore: registered new interface driver debug [ 2.073564] ARC USBOTG Device Controller driver (1 August 2005) [ 2.080289] mousedev: PS/2 mouse device common for all mice [ 2.086877] i2c-core: driver [isl29023] using legacy suspend method [ 2.093162] i2c-core: driver [isl29023] using legacy resume method [ 2.100023] snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0 [ 2.106728] i2c /dev entries driver [ 2.111011] Linux video capture interface: v2.00 [ 2.115995] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16 [ 2.123626] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17 [ 2.131283] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18 [ 2.138904] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video19 [ 2.146545] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video20 [ 2.154351] vivi-000: V4L2 device registered as video0 [ 2.159495] Video Technology Magazine Virtual Video Capture Board ver 0.8.0 successfully loaded. [ 2.168675] i2c-core: driver [mag3110] using legacy suspend method [ 2.174872] i2c-core: driver [mag3110] using legacy resume method [ 2.181386] imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1) [ 2.189492] Bluetooth: Virtual HCI driver ver 1.3 [ 2.194429] Bluetooth: HCI UART driver ver 2.2 [ 2.198875] Bluetooth: HCIATH3K protocol initialized [ 2.203854] Bluetooth: Generic Bluetooth USB driver ver 0.6 [ 2.209597] usbcore: registered new interface driver btusb [ 2.215252] sdhci: Secure Digital Host Controller Interface driver [ 2.221447] sdhci: Copyright(c) Pierre Ossman [ 2.226116] mmc0: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA [ 2.233467] mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed [ 2.241492] VPU initialized [ 2.245309] mxc_asrc registered [ 2.267024] Thermal calibration data is 0x56f4dc69 [ 2.271871] Thermal sensor with ratio = 179 [ 2.296605] Anatop Thermal registered as thermal_zone0 [ 2.305918] anatop_thermal_probe: default cooling device is cpufreq! [ 2.313264] usbcore: registered new interface driver usbhid [ 2.318839] usbhid: USB HID core driver [ 2.323146] usbcore: registered new interface driver snd-usb-audio [ 2.329861] mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio [ 2.335334] Cirrus Logic CS42888 ALSA SoC Codec Driver [ 2.340573] i2c-core: driver [cs42888] using legacy suspend method [ 2.346792] i2c-core: driver [cs42888] using legacy resume method [ 2.352931] usb 2-1: new high speed USB device number 2 using fsl-ehci [ 2.375657] mmc0: new high speed SDHC card at address 0002 [ 2.381539] mmcblk0: mmc0:0002 SD16G 14.9 GiB [ 2.394362] mmc0: Controller never released inhibit bit(s). [ 2.400083] mmcblk0: error -5 sending status command, retrying [ 2.405987] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.421757] mmc0: Controller never released inhibit bit(s). [ 2.427469] mmcblk0: error -5 sending status command, retrying [ 2.433345] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.449103] mmc0: Controller never released inhibit bit(s). [ 2.454805] mmcblk0: error -5 sending status command, retrying [ 2.455623] audio_codec_ac97_cold_reset [ 2.464593] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.480357] mmc0: Controller never released inhibit bit(s). [ 2.486077] mmcblk0: error -5 sending status command, retrying [ 2.491947] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.507689] mmc0: Controller never released inhibit bit(s). [ 2.513391] mmcblk0: error -5 sending status command, retrying [ 2.519266] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.535057] mmc0: Controller never released inhibit bit(s). [ 2.540781] mmcblk0: error -5 sending status command, retrying [ 2.543354] Found Audio codec AC97 vt1613, [ID = 5649 - 4123] [ 2.552411] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.552568] hub 2-1:1.0: USB hub found [ 2.563940] hub 2-1:1.0: 4 ports detected [ 2.563952] end_request: I/O error, dev mmcblk0, sector 0 [ 2.563963] Buffer I/O error on device mmcblk0, logical block 0 [ 2.572047] mmc0: Controller never released inhibit bit(s). [ 2.572175] mmcblk0: error -5 sending status command, retrying [ 2.572206] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.580270] mmc0: Controller never released inhibit bit(s). [ 2.580380] mmcblk0: error -5 sending status command, retrying [ 2.580413] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.588477] mmc0: Controller never released inhibit bit(s). [ 2.588606] mmcblk0: error -5 sending status command, retrying [ 2.588637] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.596700] mmc0: Controller never released inhibit bit(s). [ 2.596822] mmcblk0: error -5 sending status command, retrying [ 2.596854] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.604918] mmc0: Controller never released inhibit bit(s). [ 2.605052] mmcblk0: error -5 sending status command, retrying [ 2.605093] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.613151] mmc0: Controller never released inhibit bit(s). [ 2.613273] mmcblk0: error -5 sending status command, retrying [ 2.613304] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.613358] end_request: I/O error, dev mmcblk0, sector 0 [ 2.613366] Buffer I/O error on device mmcblk0, logical block 0 [ 2.621431] mmc0: Controller never released inhibit bit(s). [ 2.621555] mmcblk0: error -5 sending status command, retrying [ 2.621586] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.629649] mmc0: Controller never released inhibit bit(s). [ 2.629760] mmcblk0: error -5 sending status command, retrying [ 2.629791] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.637851] mmc0: Controller never released inhibit bit(s). [ 2.637981] mmcblk0: error -5 sending status command, retrying [ 2.638023] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.646088] mmc0: Controller never released inhibit bit(s). [ 2.646208] mmcblk0: error -5 sending status command, retrying [ 2.646238] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.654302] mmc0: Controller never released inhibit bit(s). [ 2.654430] mmcblk0: error -5 sending status command, retrying [ 2.654471] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.662536] mmc0: Controller never released inhibit bit(s). [ 2.662661] mmcblk0: error -5 sending status command, retrying [ 2.662692] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.662747] end_request: I/O error, dev mmcblk0, sector 0 [ 2.662754] Buffer I/O error on device mmcblk0, logical block 0 [ 2.662778] mmcblk0: unable to read partition table [ 2.837450] asoc: vt1613 <-> imx-ssi.0 mapping ok [ 2.843744] imx_3stack asoc driver [ 2.848708] asoc: mxc-hdmi-soc <-> imx-hdmi-soc-dai.0 mapping ok [ 2.855401] ALSA device list: [ 2.858372] #0: vt1613-audio [ 2.861436] #1: imx-hdmi-soc [ 2.864694] NET: Registered protocol family 26 [ 2.869655] TCP cubic registered [ 2.872899] NET: Registered protocol family 17 [ 2.877354] can: controller area network core (rev 20090105 abi 8) [ 2.883610] NET: Registered protocol family 29 [ 2.888056] can: raw protocol (rev 20090105) [ 2.892336] can: broadcast manager protocol (rev 20090105 t) [ 2.898106] Bluetooth: RFCOMM TTY layer initialized [ 2.903005] Bluetooth: RFCOMM socket layer initialized [ 2.908146] Bluetooth: RFCOMM ver 1.11 [ 2.911904] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 2.917217] Bluetooth: BNEP filters: protocol multicast [ 2.922453] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 2.922591] lib80211: common routines for IEEE802.11 drivers [ 2.928376] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4 [ 2.928738] Bus freq driver module loaded [ 2.928746] Bus freq driver Enabled [ 2.930479] mxc_dvfs_core_probe [ 2.930678] DVFS driver module loaded [ 2.936928] snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:00:01 UTC (1) [ 2.964575] VFS: Cannot open root device "mmcblk0p1" or unknown-block(179,1) [ 2.971639] Please append a correct "root=" boot option; here are the available partitions: [ 2.980003] b300 15659008 mmcblk0 driver: mmcblk [ 2.985343] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,1) [ 2.993828] [<800455b4>] (unwind_backtrace+0x0/0xfc) from [<8056cb2c>] (panic+0x74/0x19c) [ 3.002028] [<8056cb2c>] (panic+0x74/0x19c) from [<80008cb8>] (mount_block_root+0x16c/0x220) [ 3.010476] [<80008cb8>] (mount_block_root+0x16c/0x220) from [<80008e44>] (mount_root+0xd8/0xf4) [ 3.019293] [<80008e44>] (mount_root+0xd8/0xf4) from [<80008f80>] (prepare_namespace+0x120/0x184) [ 3.028182] [<80008f80>] (prepare_namespace+0x120/0x184) from [<800083dc>] (kernel_init+0x108/0x144) [ 3.037334] [<800083dc>] (kernel_init+0x108/0x144) from [<8003f080>] (kernel_thread_exit+0x0/0x8) [ 3.046229] CPU0: stopping [ 3.048955] [<800455b4>] (unwind_backtrace+0x0/0xfc) from [<8003826c>] (do_IPI+0x120/0x14c) [ 3.057320] [<8003826c>] (do_IPI+0x120/0x14c) from [<8003dfcc>] (__irq_svc+0x4c/0xe8) [ 3.065152] Exception stack(0x80b07f68 to 0x80b07fb0) [ 3.070208] 7f60: 80b6d100 20000193 00000001 00000000 80b06000 80b65c24 [ 3.078390] 7f80: 80571bd4 80b1ef54 1000406a 412fc09a 00000000 00000000 00000000 80b07fb0 [ 3.086571] 7fa0: 8004d35c 8003f124 40000113 ffffffff [ 3.091629] [<8003dfcc>] (__irq_svc+0x4c/0xe8) from [<8003f124>] (default_idle+0x24/0x28) [ 3.099813] [<8003f124>] (default_idle+0x24/0x28) from [<8003f7e0>] (cpu_idle+0xc8/0x108) [ 3.107997] [<8003f7e0>] (cpu_idle+0xc8/0x108) from [<800088a4>] (start_kernel+0x248/0x288) [ 3.116355] [<800088a4>] (start_kernel+0x248/0x288) from [<1000803c>] (0x1000803c) [ 3.123928] CPU1: stopping [ 3.126650] [<800455b4>] (unwind_backtrace+0x0/0xfc) from [<8003826c>] (do_IPI+0x120/0x14c) [ 3.135010] [<8003826c>] (do_IPI+0x120/0x14c) from [<8003dfcc>] (__irq_svc+0x4c/0xe8) [ 3.142842] Exception stack(0xbffadf90 to 0xbffadfd8) [ 3.147897] df80: 80b6d100 60000093 00000001 00000000 [ 3.156080] dfa0: bffac000 80b65c24 80571bd4 80b1ef54 1000406a 412fc09a 00000000 00000000 [ 3.164261] dfc0: 00000000 bffadfd8 8004d35c 8003f124 40000013 ffffffff [ 3.170883] [<8003dfcc>] (__irq_svc+0x4c/0xe8) from [<8003f124>] (default_idle+0x24/0x28) [ 3.179066] [<8003f124>] (default_idle+0x24/0x28) from [<8003f7e0>] (cpu_idle+0xc8/0x108) [ 3.187249] [<8003f7e0>] (cpu_idle+0xc8/0x108) from [<10569c34>] (0x10569c34) [ 3.194387] CPU3: stopping [ 3.197108] [<800455b4>] (unwind_backtrace+0x0/0xfc) from [<8003826c>] (do_IPI+0x120/0x14c) [ 3.205469] [<8003826c>] (do_IPI+0x120/0x14c) from [<8003dfcc>] (__irq_svc+0x4c/0xe8) [ 3.213303] Exception stack(0xbff01f90 to 0xbff01fd8) [ 3.218357] 1f80: 80b6d100 60000093 00000001 00000000 [ 3.226539] 1fa0: bff00000 80b65c24 80571bd4 80b1ef54 1000406a 412fc09a 00000000 00000000 [ 3.234722] 1fc0: 00000000 bff01fd8 8004d35c 8003f124 40000013 ffffffff [ 3.241343] [<8003dfcc>] (__irq_svc+0x4c/0xe8) from [<8003f124>] (default_idle+0x24/0x28) [ 3.249528] [<8003f124>] (default_idle+0x24/0x28) from [<8003f7e0>] (cpu_idle+0xc8/0x108) [ 3.257710] [<8003f7e0>] (cpu_idle+0xc8/0x108) from [<10569c34>] (0x10569c34) U-Boot 2009.08-svn89 (Oct 29 2013 - 16:13:13) CPU: Freescale i.MX6 family TO1.2 at 792 MHz Thermal sensor with ratio = 179 Temperature: 46 C, calibration data 0x56f4dc69 mx6q pll1: 792MHz mx6q pll2: 528MHz mx6q pll3: 480MHz mx6q pll8: 50MHz ipg clock : 66000000Hz ipg per clock : 66000000Hz uart clock : 80000000Hz cspi clock : 60000000Hz ahb clock : 132000000Hz axi clock : 264000000Hz emi_slow clock: 132000000Hz ddr clock : 528000000Hz usdhc1 clock : 198000000Hz usdhc2 clock : 198000000Hz usdhc3 clock : 198000000Hz usdhc4 clock : 198000000Hz nfc clock : 24000000Hz Board: i.MX6Q-UDOO: unknown-board Board: 0x63012 [POR] Boot Device: NOR I2C: ready DRAM: 1 GB MMC: FSL_USDHC: 0,FSL_USDHC: 1,FSL_USDHC: 2,FSL_USDHC: 3 In: serial Out: serial Err: serial Net: got MAC address from IIM: 00:c0:08:88:19:bb FEC0 Hit any key to stop autoboot: 3 2 1 0 mmc2 is current device Loading file "/boot/uImage" from mmc device 2:1 (xxc1) 4120128 bytes read ## Booting kernel from Legacy Image at 10800000 ... Image Name: Linux-3.0.35 Created: 2013-11-11 13:45:30 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 4120064 Bytes = 3.9 MB Load Address: 10008000 Entry Point: 10008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... [ 0.000000] Linux version 3.0.35 (udoo@ubuntu) (gcc version 4.4.4 (4.4.4_09.06.2010) ) #5 SMP PREEMPT Mon Nov 11 14:45:12 CET 2013 [ 0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d [ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine: SECO i.Mx6 UDOO Board [ 0.000000] Kernel ver: v. 92 [ 0.000000] Ignoring unrecognised tag 0x41000901 [ 0.000000] Memory policy: ECC disabled, Data cache writealloc [ 0.000000] CPU identified as i.MX6Q, silicon rev 1.2 [ 0.000000] PERCPU: Embedded 7 pages/cpu @8c008000 s5440 r8192 d15040 u32768 [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 227328 [ 0.000000] Kernel command line: console=ttymxc1,115200 root=/dev/mmcblk0p1 rootwait rw fixrtc rootflags=barrier=1 mem=1024M arm_freq=996 video=mxcfb0:dev=hdmi,1920x1080M@60,bpp=32 [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes) [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) [ 0.000000] Memory: 640MB 256MB = 896MB total [ 0.000000] Memory: 896376k/896376k available, 152200k reserved, 0K highmem [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] DMA : 0xf4600000 - 0xffe00000 ( 184 MB) [ 0.000000] vmalloc : 0xc0800000 - 0xf2000000 ( 792 MB) [ 0.000000] lowmem : 0x80000000 - 0xc0000000 (1024 MB) [ 0.000000] pkmap : 0x7fe00000 - 0x80000000 ( 2 MB) [ 0.000000] modules : 0x7f000000 - 0x7fe00000 ( 14 MB) [ 0.000000] .init : 0x80008000 - 0x80038000 ( 192 kB) [ 0.000000] .text : 0x80038000 - 0x80b04ec4 (11060 kB) [ 0.000000] .data : 0x80b06000 - 0x80b65b40 ( 383 kB) [ 0.000000] .bss : 0x80b65b64 - 0x80bb44c0 ( 315 kB) [ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] NR_IRQS:624 [ 0.000000] MXC GPIO hardware [ 0.000000] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655ms [ 0.000000] arm_max_freq=1GHz [ 0.000000] MXC_Early serial console at MMIO 0x21e8000 (options '115200') [ 0.000000] bootconsole [ttymxc1] enabled [ 0.000000] Console: colour dummy device 80x30 [ 0.223173] Calibrating delay loop... 1581.05 BogoMIPS (lpj=7905280) [ 0.311518] pid_max: default: 32768 minimum: 301 [ 0.316404] Mount-cache hash table entries: 512 [ 0.321623] CPU: Testing write buffer coherency: ok [ 0.326778] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available [ 0.427306] CPU1: Booted secondary processor [ 0.507304] CPU2: Booted secondary processor [ 0.587323] CPU3: Booted secondary processor [ 0.626811] Brought up 4 CPUs [ 0.642638] SMP: Total of 4 processors activated (6324.22 BogoMIPS). [ 0.649444] devtmpfs: initialized [ 0.669642] print_constraints: dummy: [ 0.673610] NET: Registered protocol family 16 [ 0.682297] print_constraints: vddpu: 725 <--> 1300 mV at 700 mV fast normal [ 0.689788] print_constraints: vddcore: 725 <--> 1300 mV at 1150 mV fast normal [ 0.697524] print_constraints: vddsoc: 725 <--> 1300 mV at 1200 mV fast normal [ 0.705189] print_constraints: vdd2p5: 2000 <--> 2775 mV at 2400 mV fast normal [ 0.712953] print_constraints: vdd1p1: 800 <--> 1400 mV at 1100 mV fast normal [ 0.720605] print_constraints: vdd3p0: 2625 <--> 3400 mV at 3000 mV fast normal [ 0.729620] [ 0.729626] > UDOO quad [ 0.733400] > rev C Called set_gpios_direction [ 0.738077] Test and set gpios directions and values by Gionji feat. Ekirei test [ 0.769276] Resetting ethernet physical layer. [ 0.813341] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers. [ 0.820175] hw-breakpoint: 1 breakpoint(s) reserved for watchpoint single-step. [ 0.827531] hw-breakpoint: maximum watchpoint size is 4 bytes. [ 0.833417] L310 cache controller enabled [ 0.837460] l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x02070000, Cache size: 1048576 B [ 0.871123] bio: create slab <bio-0> at 0 [ 0.878569] mxs-dma mxs-dma-apbh: initialized [ 0.883255] print_constraints: vmmc: 3300 mV [ 0.888354] vgaarb: loaded [ 0.891888] SCSI subsystem initialized [ 0.896776] usbcore: registered new interface driver usbfs [ 0.902409] usbcore: registered new interface driver hub [ 0.907938] usbcore: registered new device driver usb [ 0.913008] Freescale USB OTG Driver loaded, $Revision: 1.55 $ [ 0.936811] imx-ipuv3 imx-ipuv3.0: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7) [ 0.956805] imx-ipuv3 imx-ipuv3.1: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7) [ 0.964688] MIPI CSI2 driver module loaded [ 0.969033] Advanced Linux Sound Architecture Driver Version 1.0.24. [ 0.976246] Bluetooth: Core ver 2.16 [ 0.979964] NET: Registered protocol family 31 [ 0.984422] Bluetooth: HCI device and connection manager initialized [ 0.990807] Bluetooth: HCI socket layer initialized [ 0.995701] Bluetooth: L2CAP socket layer initialized [ 1.000850] Bluetooth: SCO socket layer initialized [ 1.006166] cfg80211: Calling CRDA to update world regulatory domain [ 1.013598] i2c-core: driver [max17135] using legacy suspend method [ 1.019897] i2c-core: driver [max17135] using legacy resume method [ 1.026113] Switching to clocksource mxc_timer1 [ 1.045076] NET: Registered protocol family 2 [ 1.049627] IP route cache hash table entries: 32768 (order: 5, 131072 bytes) [ 1.057549] TCP established hash table entries: 131072 (order: 8, 1048576 bytes) [ 1.066891] TCP bind hash table entries: 65536 (order: 7, 786432 bytes) [ 1.074633] TCP: Hash tables configured (established 131072 bind 65536) [ 1.081284] TCP reno registered [ 1.084443] UDP hash table entries: 512 (order: 2, 16384 bytes) [ 1.090410] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes) [ 1.097166] NET: Registered protocol family 1 [ 1.101842] RPC: Registered named UNIX socket transport module. [ 1.107782] RPC: Registered udp transport module. [ 1.112523] RPC: Registered tcp transport module. [ 1.117243] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 1.124582] PMU: registered new PMU device of type 0 [ 1.129698] Static Power Management for Freescale i.MX6 [ 1.134961] wait mode is enabled for i.MX6 [ 1.139259] cpaddr = c0880000 suspend_iram_base=c08fc000 [ 1.144692] PM driver module loaded [ 1.148583] IMX usb wakeup probe [ 1.152321] add wake up source irq 75 [ 1.159573] IMX usb wakeup probe [ 1.163103] cpu regulator mode:ldo_enable [ 1.167375] i.MXC CPU frequency driver [ 1.197612] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc. [ 1.204289] msgmni has been set to 1750 [ 1.209679] alg: No test for stdrng (krng) [ 1.213950] io scheduler noop registered [ 1.217886] io scheduler deadline registered [ 1.222271] io scheduler cfq registered (default) [ 1.228051] MIPI DSI driver module loaded [ 1.232271] mxc_sdc_fb mxc_sdc_fb.0: register mxc display driver hdmi [ 1.238767] mxc_hdmi mxc_hdmi: Detected HDMI controller 0x13:0xa:0xa0:0xc1 [ 1.245691] fbcvt: 1920x1080@60: CVT Name - 2.073M9 [ 1.262960] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines [ 1.280766] imx-ipuv3 imx-ipuv3.0: IPU DMFC DP HIGH RESOLUTION: 1(0,1), 5B(2~5), 5F(6,7) [ 1.314080] imx-ipuv3 imx-ipuv3.0: WARNING: adapt panel end blank lines [ 1.347465] Console: switching to colour frame buffer device 160x64 [ 1.395613] mxc_sdc_fb mxc_sdc_fb.1: register mxc display driver ldb [ 1.402030] _regulator_get: get() with no identifier [ 1.414622] mxc_sdc_fb mxc_sdc_fb.2: register mxc display driver ldb [ 1.426883] fbcvt: 1920x1080@60: CVT Name - 2.073M9 [ 1.432090] imx-sdma imx-sdma: loaded firmware 1.1 [ 1.436162] imx-sdma imx-sdma: initialized [ 1.636579] Serial: IMX driver [ 1.636689] imx-uart.0: ttymxc0 at MMIO 0x2020000 (irq = 58) is a IMX [ 1.637089] imx-uart.1: ttymxc1 at MMIO 0x21e8000 (irq = 59) is a IMX [ 1.745972] console [ttymxc1] enabled, bootconsole disabled [ 1.745972] console [ttymxc1] enabled, bootconsole disabled [ 1.757717] imx-uart.3: ttymxc3 at MMIO 0x21f0000 (irq = 61) is a IMX [ 1.769638] loop: module loaded [ 1.772797] request BOSSA_CLK IRQ [ 1.776114] registering IRQ 419 for BOSSAC Arduino erase/reset operation [ 1.826411] No sata disk. [ 1.830233] GPMI NAND driver registered. (IMX) [ 1.835585] vcan: Virtual CAN interface driver [ 1.840037] CAN device driver interface [ 1.843883] flexcan netdevice driver [ 1.847604] FEC Ethernet Driver [ 1.852982] fec_enet_mii_bus: probed [ 1.861645] usbcore: registered new interface driver rt2800usb [ 1.867482] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.874147] fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller [ 1.880795] fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1 [ 1.910724] fsl-ehci fsl-ehci.0: irq 75, io base 0x02184000 [ 1.930716] fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00 [ 1.936968] hub 1-0:1.0: USB hub found [ 1.940757] hub 1-0:1.0: 1 port detected [ 1.944859] add wake up source irq 72 [ 1.948558] fsl-ehci fsl-ehci.1: Freescale On-Chip EHCI Host Controller [ 1.955203] fsl-ehci fsl-ehci.1: new USB bus registered, assigned bus number 2 [ 2.000715] fsl-ehci fsl-ehci.1: irq 72, io base 0x02184200 [ 2.030707] fsl-ehci fsl-ehci.1: USB 2.0 started, EHCI 1.00 [ 2.036864] hub 2-0:1.0: USB hub found [ 2.040626] hub 2-0:1.0: 1 port detected [ 2.044910] Initializing USB Mass Storage driver... [ 2.049945] usbcore: registered new interface driver usb-storage [ 2.055995] USB Mass Storage support registered. [ 2.060901] usbcore: registered new interface driver usbserial [ 2.066840] USB Serial support registered for generic [ 2.072024] usbcore: registered new interface driver usbserial_generic [ 2.078554] usbserial: USB Serial Driver core [ 2.083027] USB Serial support registered for debug [ 2.088026] usbcore: registered new interface driver debug [ 2.093529] ARC USBOTG Device Controller driver (1 August 2005) [ 2.100253] mousedev: PS/2 mouse device common for all mice [ 2.106857] i2c-core: driver [isl29023] using legacy suspend method [ 2.113142] i2c-core: driver [isl29023] using legacy resume method [ 2.120018] snvs_rtc snvs_rtc.0: rtc core: registered snvs_rtc as rtc0 [ 2.126694] i2c /dev entries driver [ 2.130982] Linux video capture interface: v2.00 [ 2.135971] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video16 [ 2.143600] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video17 [ 2.151270] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video18 [ 2.158890] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video19 [ 2.166518] mxc_v4l2_output mxc_v4l2_output.0: V4L2 device registered as video20 [ 2.174370] vivi-000: V4L2 device registered as video0 [ 2.179515] Video Technology Magazine Virtual Video Capture Board ver 0.8.0 successfully loaded. [ 2.188707] i2c-core: driver [mag3110] using legacy suspend method [ 2.194904] i2c-core: driver [mag3110] using legacy resume method [ 2.201427] imx2-wdt imx2-wdt.0: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=1) [ 2.209534] Bluetooth: Virtual HCI driver ver 1.3 [ 2.214468] Bluetooth: HCI UART driver ver 2.2 [ 2.218915] Bluetooth: HCIATH3K protocol initialized [ 2.223895] Bluetooth: Generic Bluetooth USB driver ver 0.6 [ 2.229602] usbcore: registered new interface driver btusb [ 2.235250] sdhci: Secure Digital Host Controller Interface driver [ 2.241446] sdhci: Copyright(c) Pierre Ossman [ 2.246120] mmc0: SDHCI controller on platform [sdhci-esdhc-imx.2] using DMA [ 2.253448] mxc_vdoa mxc_vdoa: i.MX Video Data Order Adapter(VDOA) driver probed [ 2.264681] VPU initialized [ 2.268466] mxc_asrc registered [ 2.288617] Thermal calibration data is 0x56f4dc69 [ 2.293440] Thermal sensor with ratio = 179 [ 2.311452] Anatop Thermal registered as thermal_zone0 [ 2.316797] anatop_thermal_probe: default cooling device is cpufreq! [ 2.333198] usbcore: registered new interface driver usbhid [ 2.338772] usbhid: USB HID core driver [ 2.343069] usbcore: registered new interface driver snd-usb-audio [ 2.349785] mxc_hdmi_soc mxc_hdmi_soc.0: MXC HDMI Audio [ 2.355270] Cirrus Logic CS42888 ALSA SoC Codec Driver [ 2.360526] i2c-core: driver [cs42888] using legacy suspend method [ 2.366720] i2c-core: driver [cs42888] using legacy resume method [ 2.373866] mmc0: new high speed SDHC card at address 0002 [ 2.379720] mmcblk0: mmc0:0002 SD16G 14.9 GiB [ 2.384216] usb 2-1: new high speed USB device number 2 using fsl-ehci [ 2.398795] mmc0: Controller never released inhibit bit(s). [ 2.404533] mmcblk0: error -5 sending status command, retrying [ 2.410400] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.426170] mmc0: Controller never released inhibit bit(s). [ 2.431882] mmcblk0: error -5 sending status command, retrying [ 2.437745] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.453502] mmc0: Controller never released inhibit bit(s). [ 2.455243] audio_codec_ac97_cold_reset [ 2.463126] mmcblk0: error -5 sending status command, retrying [ 2.468988] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.484754] mmc0: Controller never released inhibit bit(s). [ 2.490457] mmcblk0: error -5 sending status command, retrying [ 2.496330] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.512089] mmc0: Controller never released inhibit bit(s). [ 2.517810] mmcblk0: error -5 sending status command, retrying [ 2.523683] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.526254] Found Audio codec AC97 vt1613, [ID = 5649 - 4123] [ 2.545197] mmc0: Controller never released inhibit bit(s). [ 2.550902] mmcblk0: error -5 sending status command, retrying [ 2.552488] asoc: vt1613 <-> imx-ssi.0 mapping ok [ 2.554087] imx_3stack asoc driver [ 2.556543] asoc: mxc-hdmi-soc <-> imx-hdmi-soc-dai.0 mapping ok [ 2.557199] ALSA device list: [ 2.557206] #0: vt1613-audio [ 2.557210] #1: imx-hdmi-soc [ 2.557413] NET: Registered protocol family 26 [ 2.557924] TCP cubic registered [ 2.557930] NET: Registered protocol family 17 [ 2.557945] can: controller area network core (rev 20090105 abi 8) [ 2.558024] NET: Registered protocol family 29 [ 2.558031] can: raw protocol (rev 20090105) [ 2.558036] can: broadcast manager protocol (rev 20090105 t) [ 2.612609] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.612616] Bluetooth: RFCOMM TTY layer initialized [ 2.612628] Bluetooth: RFCOMM socket layer initialized [ 2.612633] Bluetooth: RFCOMM ver 1.11 [ 2.612639] Bluetooth: BNEP (Ethernet Emulation) ver 1.3 [ 2.612644] Bluetooth: BNEP filters: protocol multicast [ 2.612650] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 2.612793] lib80211: common routines for IEEE802.11 drivers [ 2.656207] VFP support v0.3: [ 2.656283] end_request: I/O error, dev mmcblk0, sector 0 [ 2.656294] Buffer I/O error on device mmcblk0, logical block 0 [ 2.664403] mmc0: Controller never released inhibit bit(s). [ 2.664545] mmcblk0: error -5 sending status command, retrying [ 2.664579] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.672654] mmc0: Controller never released inhibit bit(s). [ 2.672795] mmcblk0: error -5 sending status command, retrying [ 2.672827] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.673086] hub 2-1:1.0: USB hub found [ 2.680899] mmc0: Controller never released inhibit bit(s). [ 2.681036] hub 2-1:1.0: 4 ports detected [ 2.681043] mmcblk0: error -5 sending status command, retrying [ 2.681075] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.689151] mmc0: Controller never released inhibit bit(s). [ 2.689278] mmcblk0: error -5 sending status command, retrying [ 2.689310] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.697388] mmc0: Controller never released inhibit bit(s). [ 2.697521] mmcblk0: error -5 sending status command, retrying [ 2.697552] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.705618] mmc0: Controller never released inhibit bit(s). [ 2.705751] mmcblk0: error -5 sending status command, retrying [ 2.705781] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.705836] end_request: I/O error, dev mmcblk0, sector 0 [ 2.705845] Buffer I/O error on device mmcblk0, logical block 0 [ 2.713942] mmc0: Controller never released inhibit bit(s). [ 2.714078] mmcblk0: error -5 sending status command, retrying [ 2.714119] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.722186] mmc0: Controller never released inhibit bit(s). [ 2.722308] mmcblk0: error -5 sending status command, retrying [ 2.722341] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.730404] mmc0: Controller never released inhibit bit(s). [ 2.730515] mmcblk0: error -5 sending status command, retrying [ 2.730545] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.738607] mmc0: Controller never released inhibit bit(s). [ 2.738735] mmcblk0: error -5 sending status command, retrying [ 2.738766] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.746830] mmc0: Controller never released inhibit bit(s). [ 2.746951] mmcblk0: error -5 sending status command, retrying [ 2.746982] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.755046] mmc0: Controller never released inhibit bit(s). [ 2.755167] mmcblk0: error -5 sending status command, retrying [ 2.755200] mmcblk0: timed out sending SET_BLOCK_COUNT command, card status 0x400900 [ 2.755253] end_request: I/O error, dev mmcblk0, sector 0 [ 2.755261] Buffer I/O error on device mmcblk0, logical block 0 [ 2.755288] mmcblk0: unable to read partition table [ 2.935586] implementor 41 architecture 3 part 30 variant 9 rev 4 [ 2.935979] Bus freq driver module loaded [ 2.935987] Bus freq driver Enabled [ 2.937732] mxc_dvfs_core_probe [ 2.937925] DVFS driver module loaded [ 2.941696] snvs_rtc snvs_rtc.0: setting system clock to 1970-01-01 00:28:09 UTC (1689) [ 2.964802] VFS: Cannot open root device "mmcblk0p1" or unknown-block(179,1) [ 2.971918] Please append a correct "root=" boot option; here are the available partitions: [ 2.980284] b300 15659008 mmcblk0 [ 2.980831] usb 2-1.2: new full speed USB device number 3 using fsl-ehci [ 2.991010] driver: mmcblk [ 2.993807] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,1) [ 3.002291] [<800455b4>] (unwind_backtrace+0x0/0xfc) from [<8056cb2c>] (panic+0x74/0x19c) [ 3.010484] [<8056cb2c>] (panic+0x74/0x19c) from [<80008cb8>] (mount_block_root+0x16c/0x220) [ 3.018950] [<80008cb8>] (mount_block_root+0x16c/0x220) from [<80008e44>] (mount_root+0xd8/0xf4) [ 3.027789] [<80008e44>] (mount_root+0xd8/0xf4) from [<80008f80>] (prepare_namespace+0x120/0x184) [ 3.036681] [<80008f80>] (prepare_namespace+0x120/0x184) from [<800083dc>] (kernel_init+0x108/0x144) [ 3.045829] [<800083dc>] (kernel_init+0x108/0x144) from [<8003f080>] (kernel_thread_exit+0x0/0x8) [ 3.054724] CPU3: stopping [ 3.057451] [<800455b4>] (unwind_backtrace+0x0/0xfc) from [<8003826c>] (do_IPI+0x120/0x14c) [ 3.065816] [<8003826c>] (do_IPI+0x120/0x14c) from [<8003dfcc>] (__irq_svc+0x4c/0xe8) [ 3.073649] Exception stack(0xbff01f90 to 0xbff01fd8) [ 3.078704] 1f80: 80b6d100 20000093 00000001 00000000 [ 3.086887] 1fa0: bff00000 80b65c24 80571bd4 80b1ef54 1000406a 412fc09a 00000000 00000000 [ 3.095068] 1fc0: 00000000 bff01fd8 8004d35c 8003f124 40000013 ffffffff [ 3.101690] [<8003dfcc>] (__irq_svc+0x4c/0xe8) from [<8003f124>] (default_idle+0x24/0x28) [ 3.109874] [<8003f124>] (default_idle+0x24/0x28) from [<8003f7e0>] (cpu_idle+0xc8/0x108) [ 3.118057] [<8003f7e0>] (cpu_idle+0xc8/0x108) from [<10569c34>] (0x10569c34) [ 3.125195] CPU0: stopping [ 3.127916] [<800455b4>] (unwind_backtrace+0x0/0xfc) from [<8003826c>] (do_IPI+0x120/0x14c) [ 3.136277] [<8003826c>] (do_IPI+0x120/0x14c) from [<8003dfcc>] (__irq_svc+0x4c/0xe8) [ 3.144109] Exception stack(0x80b07f68 to 0x80b07fb0) [ 3.149165] 7f60: 80b6d100 60000193 00000001 00000000 80b06000 80b65c24 [ 3.157347] 7f80: 80571bd4 80b1ef54 1000406a 412fc09a 00000000 00000000 00000000 80b07fb0 [ 3.165528] 7fa0: 8004d35c 8003f124 40000113 ffffffff [ 3.170586] [<8003dfcc>] (__irq_svc+0x4c/0xe8) from [<8003f124>] (default_idle+0x24/0x28) [ 3.178769] [<8003f124>] (default_idle+0x24/0x28) from [<8003f7e0>] (cpu_idle+0xc8/0x108) [ 3.186952] [<8003f7e0>] (cpu_idle+0xc8/0x108) from [<800088a4>] (start_kernel+0x248/0x288) [ 3.195309] [<800088a4>] (start_kernel+0x248/0x288) from [<1000803c>] (0x1000803c) [ 3.202881] CPU2: stopping [ 3.205602] [<800455b4>] (unwind_backtrace+0x0/0xfc) from [<8003826c>] (do_IPI+0x120/0x14c) [ 3.213963] [<8003826c>] (do_IPI+0x120/0x14c) from [<8003dfcc>] (__irq_svc+0x4c/0xe8) [ 3.221794] Exception stack(0xbffb5f90 to 0xbffb5fd8) [ 3.226849] 5f80: 80b6d100 60000093 00000001 00000000 [ 3.235032] 5fa0: bffb4000 80b65c24 80571bd4 80b1ef54 1000406a 412fc09a 00000000 00000000 [ 3.243213] 5fc0: 00000000 bffb5fd8 8004d35c 8003f124 40000013 ffffffff [ 3.249835] [<8003dfcc>] (__irq_svc+0x4c/0xe8) from [<8003f124>] (default_idle+0x24/0x28) [ 3.258018] [<8003f124>] (default_idle+0x24/0x28) from [<8003f7e0>] (cpu_idle+0xc8/0x108) [ 3.266201] [<8003f7e0>] (cpu_idle+0xc8/0x108) from [<10569c34>] (0x10569c34)
That's quite weird. I fear this could be an hardware problem. have you tried flashing the mSD only with the Ubuntu image? Just to be sure please try with Android as well and tell me what kind of feedback you'll receive. Cheers.
Delba, I will attempt to boot up Android tonight and get back to you. Regarding hardware, other than the connections from the UDOO, the only other hardware associated is the uSD. I am using a Kingston 16Gb Class 10 uSD, formatted to FAT32. I doubt that this problem is occurring due to the uSD but perhaps you may see a problem with this? I noticed that many people have the HDMI problem, I don't believe that is a problem for me, because I am not getting any warnings regarding the HDMI and additionally, I see my monitor changing to slight shade of grey when attempting to boot up. I hope that Android will boot, which proves to me that there was something wrong with the distro/flashing, but if not I am assuming there will be an exchange of UDOO. Thanks, Daniel
