Udoo GPIO voltage
Discussion in 'General Discussion' started by laptopdude90, Mar 10, 2014.
  1. laptopdude90
    laptopdude90 New Member
    Mar 10, 2014
    I have looked everywhere and I can't find the voltage of the GPIO pins. Does anyone know what they are?
  2. delba
    1,064
    The UDOO I/O pins are 3.3V compliant. Higher voltages (like 5V) would damage the board. http://elinux.org/UDOO
  3. oregon187
    oregon187 New Member
    Feb 26, 2014
    11
    Don't forget that voltage isn't your only concern. Make sure you control the current in and out of your GPIO pins. I'm not sure if the UDOO is the same as the Arduino Due (which has the same Sam3x chip) but the Due cannot handle much current in and out of the GPIO pins at all. But then again, these are control boards and they should really only be sending and receiving signals and not driving sensors. Make sure you use some sort of signal conditioning/buffering circuitry for your I/O; for instance, Darlington transistors are great for driving outputs.
